Old 10-28-2008, 04:17 AM   #1
bereda
Scooby Scammer- Do Not Buy From User
Member#: 192034
2004 2.5rs
red
Default is this pushing it
i can buy a set of wheels and the size is 17 by 8 with a positive 40 offset ...i hve an 04 latter model 2.5rsti (sti eng trans) stock everything besides gauges... also what size tires should i run
bereda is offline   Reply With Quote
Old 10-28-2008, 10:37 AM   #2
NOboostSUBIE
Member#: 163322
2002 PSM Impreza RS
DD & Weekend Auto-x'r
17x8 typically calls for a 235/40 series tire. depending on suspension mods, you can go taller/wider and not have to worry about rubbing.
NOboostSUBIE is offline   Reply With Quote
Old 10-28-2008, 05:09 PM   #3
Scooba Stimpy
Member#: 187721
XX Scoobyless
i have 17x8" +48 with 225/45. the rear struts bearly clear the tires by 8mm
Scooba Stimpy is offline   Reply With Quote
Old 10-28-2008, 08:30 PM   #4
SOHCEJ25
Member#: 135013
'17 WRX Hatch ; )
Should work , if your low they may rub on the fenders .... may stick out a tad ...
Thats the exact wheel specs I want for my Forester ... currently on 17x7 +35 ... 17x8 + 40 would be more flush and have the width I want !
Shawn
GerBrock.net
My Site
SOHCEJ25 is offline   Reply With Quote
Old 10-28-2008, 09:54 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
bad bad idea to put such performance on all stock suspension and brakes
hope ya dont crash it cuz the brakes and suspension suck
Old 10-28-2008, 09:56 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
do NOT post on vehicles that DO NOT HAVE ANY RELEVANCE TO THE OP
IT IS MISLEADING AND CAUSES UNNECESSARY CONFUSION!!!!!!!!!!!!!1
Old 10-29-2008, 08:09 PM   #7
bereda
Member#: 192034
2004 2.5rs
red
I might try the wheels because according to the wheel offset thread 43-48 is ideal for an 8inch wide wheel how much could 3mm do
Old 10-30-2008, 12:55 AM   #8
JLW2007RS
Member#: 162089
2008 G37S IPL
3mm, the difference between rubbing and not rubbing
JLW2007RS is offline   Reply With Quote
Old 10-30-2008, 01:15 AM   #9
bereda
Member#: 192034
2004 2.5rs
red
yea but heres another difference the lower the off set the farther the wheel is off set the hub so it will be pushed out further than say a 17 by 8 with a positive 45 offset that is rubbing it will be. instead of a positive 45 that rubs im getting a 40 that might not because its 5mm away from where it was rubbing with the positive 45 offset.... atleast thats what i got out of the offset thread...
Old 10-30-2008, 01:32 AM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
ya got that backwards
you arent likely gonna rub the strut.....ya likely gonna rub the fender lip
higher number offset moves the tire closer to the strut.......lower number closer to the fender lip
lower number = more rub on the fender lip
and tire choice also must be considered
some tires, when mounted, are wider(sone a LOT wider) for the same size, than other tires...meaning some 245/40's will clear with no problem, some wont without 'help'
Old 10-30-2008, 01:59 AM   #11
bereda
Member#: 192034
2004 2.5rs
red
hmmm im so confused grrr its frustrating
Old 10-30-2008, 02:11 AM   #12
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
You will most likely rub with that setup, or at least once you take a hard turn with another passenger in the car. When I ran a 17x8 +44 wheel with 235/40/17 tires on stock fenders I rubbed, a simple roll in the rear fixed the rubbing issue though.
-Dan
suby_dude is offline   Reply With Quote
Old 10-30-2008, 02:22 AM   #13
bereda
Member#: 192034
2004 2.5rs
red
mine are the 05 type which are pre rolled i think.. ill take a pic
Old 10-30-2008, 08:22 AM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
something tells me that you just arent quite up to speed on all of this
'rolled' is a term used to describe the process of using a baseball bat or similar item to bend or 'roll' the inner lip of the fenders(or rear quarter panels in this case) up so the tires dont hit and rub there.
this has nothing to do with the wheels or tires and subaru fenders and not 'pre-rolled' and it is unlikely that your 04 has 05 fenders or quarter panels
Old 10-30-2008, 10:51 AM   #15
bereda
Member#: 192034
2004 2.5rs
red
thats what i think it is also i didnt mean pre rolled i ment theres nothing there to roll...
how would a 16 by 7 by positive 40 do?
Old 10-30-2008, 03:13 PM   #16
CatfaceType-R
Member#: 81102
<----found where teh uncle scotty was hiding...
CatfaceType-R is offline   Reply With Quote
Old 10-30-2008, 11:02 PM   #17
bereda
Member#: 192034
2004 2.5rs
red
the 16 by 7 with 40 offset they are konig quiz wheels off treaddepot.com
Is this where it goes? (oil pressure sender) Mrfairlady Interior & Exterior Modification 2 06-05-2005 03:56 PM
Is this why it was done?? 5min now 100... Sephro Off-Topic 26 04-01-2005 10:09 AM
Is this worth it? CatchMyDrift General Community 7 03-12-2005 07:32 AM
is this worth it? cobb surfer.tech Normally Aspirated Powertrain 6 11-11-2003 12:41 AM
HELP !what senser is this unpluged it and cant find where it plugs suprasingle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-25-2002 10:59 PM
