Old 10-06-2011, 12:02 PM   #301
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
It sounds like your missing the point of TD. As written in the guide, TD is meant to correct for overboosting or underboosting after you have your WGDC dialed in correctly. So if you are tuning in the current weather conditions, you should be able to get your boost correct by adjusting the WGDC tables only and have TD set to 0. Adjust both WGDC tables. If your initial value is 30 and your max is 50 and you are overboosting, move them to 25 and 45. That leaves the gap between them for TD corrections when you start using them again.
If you tune your car now with your WGDCs dialed in and everything is working with the TD zeroed out, in July you won't be hitting your target boost because the atmosphere has changed and the air has become less dense. Then TD should step in and work to correct for the boost error. Otherwise you'd have to retune your boost every time the weather changes.
It sounds like you're expecting to see a direct correlation between 1 table and 1 effect when it doesn't work like that. It's a dynamic self correcting system and you need to understand it's individual parts as well as the whole to really know what to change. Otherwise you make a change, you don't see the effect you were expecting, and end up getting frustrated because there isn't a directly cause-effect relationship.
Bad Noodle is offline   Reply With Quote
Old 10-06-2011, 12:15 PM   #302
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Originally Posted by AB-737 View Post
One other question on tuning in the WGDC tables... Should my Target primary wastegate be my the value in my initial table? Or between the Initial and Max? this is where I'm still slighly confused on what table should read what.
I'm guessing the Initial should be the lowest WG value needed to reach that target boost in any of the gears since that varries, and then your max is the highest WG necessary to reach the target boost in any of the gears. Am I correct in that thinking?
Under ideal conditions, your car would always run the initial WGDC, and TD Int and TD Pro would be 0, because your boost error would be zero. The WGDC max table is just there as a safety net to keep things from going out of control, you should never actually have to use it. You want it to be high enough where it doesn't interfere with TD Int and TD Pro as they're doing their job fixing any boost problems you might have, but you don't want it to be so high where if something goes wrong, your WGDC isn't allowed to push all the way to 100 and cause a huge boost spike. Your WGDC max table should never actually be used for tuning, just as a safety net.
Without per-gear WGDC compensations, I would probably tune the initial WGDC table in 3rd or 4th, and let the turbo dynamics modifiers do their job in the other gears.
Old 10-06-2011, 12:24 PM   #303
AB-737
Member#: 236196
I'm understanding how it works and see how it works, but when I read this
"Look at the TDI being added in at the RPM you want to achieve full boost. Add that amount to your 100% WGDC column.
9) Rinse and repeat.
a. As you do this, you will start getting a better idea of how the turbo is working and that will help you find exactly where the turbo is happiest in the RPM range. Seeing how the turbo is behaving will help you confirm the RPM you want full boost at or revise it.
b. Do this until you reach your target boost (this was set at 75% of your theoretical) at some rpm
c. Once you are hitting boost value you have in your boost map, your TDIC should start building up and your TDI should be maxed out as your spool.. Then as you hit the target boost, your TDI should drop to 0 and your TDIC should stay constant."
I get confused again because its telling me to leave that correction system in place while I'm trying to dial in my WGDC
I new to boost tuning yes, but not new to tuning as a whole so I understand where corrections come into play and why they are needed in climates where your weather changes drastically.
From what I'm reading, I'm gathering that I need to dial in my WGDC's WITHOUT any correction being done so I know what they need to be to hit a target boost and then re-enable that correction system to keep that boost stable when the air changes. With reading the guide it reads as if you are USING the correction system to reach target boost all the time since you never disable it, you only use it's numbers to add to your WGDC till you hit target and if you ask me the correction system will get you to target WELL before your WGDC table is close enough to do it on its own... Right?
My biggest issue is I have 3 different explanations as to how to tune it and none match what the guide reads, and you stated to have the WGDC at 30 and 50 and if you over boost to drop to 25 and 45, now where did you come up with the 20 split between the two tables? thats not noted anywhere and really can drive someone nuts if they can't figure out where people are getting these values from. Especially when terms used don't match any tables or pids that you can scan for your model year.
TD is a correction system to stabilize boost when air conditions change and get you to target boost when there is a drastic change in TP? simply answer that as a yes or no question.
WGDC is a range of where your wastegate needs to be for a lower gear and a higher gear to produce X boost at X RPM. Is that also right?
Right now TD is off, so why shouldn't a change done to the WGDC table directly affect my boost levels? Is there another table thats correcting for something else that I'm not aware of and isn't stated anywhere?
I feel that there is tons of knowledge on the tuning of these cars but a lot of the basics are just left out, or some of the stuff may of the advanced users just take as common knowledge isn't noted so those starting out have to dig and "ask stupid questions" to figure out whats going on, and at that point in time they just keep getting told they don't understand this or that, when really its lack of information causing their confusion.
AB-737 is offline   Reply With Quote
Old 10-06-2011, 12:31 PM   #304
AB-737
Member#: 236196
That helps in explaining my boost levels in different gears... But I can only assume that I would have to tune my WGDC max table higher if I'm not reaching target boost but hitting that max level right? Or the other way, overboosting and the WGDC is below that Max number.
Once again maybe It's terms I'm lost at again...
My map has
Initial WGDC
Max WGDC
MAX WGD Limit Post-Compensation
Initial/Max WGD Compensation IAT
Initial/Max WGD Compensation ECT
Initial/Max WGD Compensation Atm. Pressure
When you say Max WGDC shouldn't be tuned, which table from the above are you referring to? Your statment of that contradicts what Bad Noodle said about changing from 30-50 down to 25-45.
Both the Initial and Max WGDC tables say that wastegate compensation tables are applied to those values, so in my map I'm guessing MAX WGDC is not as high as it can go. But the Max WGD Limit table is the one that does that.
Old 10-06-2011, 12:35 PM   #305
Member#: 51961
2005 STi
2012 WRX
The problem is you'll find a million different opinions of how one should go about tuning boost, just like any other part of the system. I prefer to tune my MAF by disabling the closed loop fueling system and directly observing the AFR error while logging, then applying that % error to whatever MAF cell is active at the time. Other people never disable closed loop, and instead USE the closed loop system to tell them what their error is at any given time (the closed loop system is adding 10% fuel to hit stoich, so I need to add 10% to my MAF at that spot), etc. Both approaches are valid and have their advantages and disadvantages.
My approach stems from my [limited] experience with designing closed loop control systems. Trying to tune the system while the entire thing is active can be a HORRIBLE pain in the butt, and will often leave you chasing your own tail, trying to correct issues at one time using values that were derived a second and a half earlier, etc. You can really only do that IF the system is at steady-state, which the boost control system never will be unless you're tuning on a dyno that has the ability to hold RPM constant while you sit there at WOT. For that reason, I always prefer to turn off the closed loop corrections, get it working properly in open loop first, then add the feedback system back in just to keep the system on target in the future. That's not the only way to do things though.
Old 10-06-2011, 12:41 PM   #306
Member#: 51961
2005 STi
2012 WRX
My map has
Initial WGDC
Max WGDC
Both of the max tables are safety nets, Max WGDC and Max WGDC Limit Post-Compensation. Max WGDC is a lower level safety net that's directly tied to your initial table, and is modified by your compensations just like the initial table. Max WGDC Limit Post-Compensation is more of a "Thor's Hammer" global limit on WGDC, regardless of anything.
I find the "Max WGDC" table is more useful as your safety net, while "Max WGDC Limit Post-Compensation" is more useful as a tool to globally limit your WGDC for doing special tests. For example, if you wanted to check your boost with no boost control system, all you need to do is change the single value in Max WGDC Limit Post-Comp to 0, that's it. If you want to limit boost for some reason, but not necessarily drop all the way to spring pressure, you can just set your Post-Comp Limit to say 20, or 30. Say you change your MAF housing, and you want to re-tune your MAF scaling, but you don't want to jump straight into full boost in case your scaling is not perfect right off the bat. You don't have to re-tune your entire boost control system every step of the way, just set your Post-Comp Limit to 0 to hold you at wastegate spring pressure, tune your MAF, turn the Post-Comp Limit to 5, tune the MAF for the new cells you're hitting, etc. You can use the Post-Comp Limit to slowly step into full boost, without having to re-tune the entire boost control system each step.
Old 10-06-2011, 12:49 PM   #307
AB-737
Member#: 236196
Ok then I'm apparently reading two different ways on how to do this and getting "You're not understanding how this works" when I quote the other person.
I agree with you in disabling the closed loop system to dial in the car and then to re-enable it to keep things under control, that makes 100% perfect sense to me since I was already trying to tune it with TD enabled and was doing exactly what you were talking about I was chasing my tail.
I guess what I need to know is whats a good split between the min and max tables? Bad Noodle quoted 20... If thats a good rule of thumb then I have something I can work with and I can build my own tables with that number. Without having that number then I have no idea what to set the max at. I also see no reason in worrying about having that range large enough for TD to work with, since TD is a compensation so according to whats written on the table the TD control system should be able to add above what's in the MAX WGDC table but as noted the Thor's hammer of the LIMIT is the stopping point.
Old 10-06-2011, 01:47 PM   #308
Member#: 51961
2005 STi
2012 WRX
I believe Max WGDC includes all compensations except for TD (IE: IAT, atmospheric pressure, etc).
I'd say start with a separation of 20, see how it works. If you find your WGDC goes out of control sometimes (it shouldn't if you have your initial table tuned well), you can try lowering max to put a cap on things.
Old 10-06-2011, 01:54 PM   #309
AB-737
Member#: 236196
My biggest problem is I've been fighting with these WGDC tables for someone else's application. I smartened up and just put the stock tables back in there with all of the stock compensations and such TD still disabled and I'll try to reach my target boost with those rather than trying to correct for overshooting. I just went for a ride and didn't hit my target at all so now I'm working with something I can better control and understand.
Thank you for bearing with me on this one since there are so many different paths you can take, and theories on which is best.
Old 01-31-2012, 04:00 PM   #310
1hotsubaru
Member#: 244748
2002 WRB Impreza WRX
"aka" NGRY REX
I think my head is about to explode from all this reading! So much info to take in in one day lol... but hey great guide!!
1hotsubaru is offline   Reply With Quote
Old 02-28-2012, 11:10 AM   #311
02wrex69
Member#: 311840
Default need my 02 wrx tuned in nyc anybody?
Does anybody know any tuners or someone to reflash my evil in New York city area ?
02wrex69 is offline   Reply With Quote
Old 02-28-2012, 11:13 AM   #312
02wrex69
Member#: 311840
Ooops I meant ecu ! Lol
Old 11-24-2012, 09:05 AM   #313
garrett113
Member#: 270444
2003 WRX
Great write up bad noodle, lot of great info!
I had a problem with the link on page 6 "Cobb Tuning Guide". I got a message saying "No thread specified". Is this information still available?
garrett113 is offline   Reply With Quote
Old 08-06-2013, 05:33 PM   #314
greenplates
Member#: 239162
Is this info still current?
greenplates is offline   Reply With Quote
Old 01-08-2014, 11:24 PM   #315
JBD5057
Member#: 320478
2012 WRX
ISM
JBD5057 is offline   Reply With Quote
Old 04-30-2014, 10:31 AM   #316
some dude
Member#: 100300
06 WRX
CGM
On page 7 if the 1.0 PDF Tuning Guide, there is a link to Cobb forums so the reader can learn more about boost. The link is dead: There is a post saying that Cobb closed their forums on July 2013...
some dude is offline   Reply With Quote
Old 04-30-2014, 11:44 AM   #317
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Ask for the info in the Accessport section. Cobb likely has this documentation backed up
wgr73 is offline   Reply With Quote
Old 04-30-2014, 11:49 AM   #318
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I would read cobb's racetuner documentation. They're always updating their info. They're good like that...
Old 06-13-2015, 09:29 AM   #319
shinbusu
Member#: 419109
awsome!!!
shinbusu is offline   Reply With Quote
Old 06-14-2015, 01:04 AM   #320
shinbusu
Member#: 419109
awsome!!!
Old 07-02-2015, 08:34 PM   #321
T-Hutch
Member#: 398317
Hey Bad Noodle quick question. I want to know if I should be seeing some knock while just driving normally. I occasionally see a FBKC of -2 or -1 for a split second and maybe even FKL of -1.4 under certain loads. Today again on my way home I hit -4 on FBKC and I noticed my FKL of -1.05 was staying pretty constant if I stayed at the certain rpm. Under WOT these all go to zero, it's only when I'm cruising and hit a certain load range in whatever gear I'm in that I see this. My DAM is still at 1, however it did drop to .7 early this week. Turns out I was running the wrong MAP cause I live in CA, octane booster did the trick for the time being but since then I'm running the correct MAP and I'm still seeing the same stuff. I'm trying to figure out if I have some sort of a boost or intake leak, or maybe the summer heat is affecting it this bad? I don't currently have an AOS so maybe that's an issue as well? Basically I want to know if there are other people out there running Cobb OTS Maps and who also see FBKC and FKL values occasionally. Though I feel like i'm seeing them more than occasionally.
I just replaced my short block a little more than a month ago and I'm starting to get worried....more pissed off actually. Any input would be greatly appreciated! Cobb isn't really much help...found that out this week. :/
T-Hutch is offline   Reply With Quote
Old 07-02-2015, 09:30 PM   #322
Brodan
Member#: 372655
2011 WRX
Just a heads up T-Hutch stay away from that octane booster crap. It fouls up your plugs pretty bad and only raises your octane level fractions of a point.
Brodan is offline   Reply With Quote
Old 07-02-2015, 11:28 PM   #323
T-Hutch
Member#: 398317
Default octane booster
I was aware of the misleading advertising. however I trust lucas Oil and it says 30pts which is 3 octane. I never heard of it fowling plugs before but I don't know much about it so thanks for the heads up. It was more for testing to see if the tank of gas I got was bad...and it worked. But yeah I won't be using it...it's way too expensive.
do you have a STi? if so have you noticed any trends with knock?
Old 07-02-2015, 11:46 PM   #324
Brodan
Member#: 372655
2011 WRX
WRX. Yeah I get quite a bit of false knock which is what it seems like you described above. I'm no tuner and in no way should I be telling anyone what to do with their car in regards to tuning but my understanding is not to worry about the -1.4s and slightly above especially when not in boost. I would definitely keep an eye on that DAM to see if it stabilizes after you get a new batch of gas in though. Do some logs and post them up or send them to your tuner. I'm sure some more knowledgeable people than I would take a look at them on here.
Old 07-03-2015, 12:41 AM   #325
T-Hutch
Member#: 398317
Default false knock?
Yeah I've read a lot and come across opposite things. It's frustrating. Cobb on their website says to look for knock under HIGH load which makes total sense. That would be an issue. But then I've read people saying knock under low load is the real issue. I've just noticed this is consistently happening while cruising and only while cruising...which I know cruising is the worse time to take logs and can produce false knock so I was looking for reassurance.
I didn't own an AP when my last block melted cyl #4 piston...which would have been great to see cause I would know what to look for now. lol
My Swap: 1999RS to 2002WRX. Complete Wiring Guide Inside 99 rs Subaru Conversions 238 09-26-2016 11:35 AM
A complete n00b's guide to changing the oil in your WRX (with pics!) perret318 Service & Maintenance 153 11-28-2013 02:17 AM
Complete open source tuning guide shutupnshift04 Commercial ECU Reflashes 19 05-10-2007 06:16 PM
Updated StreetTUNER Tuning Guide and Tuning Guide Worksheets... Christian. AccessPort 0 04-17-2007 06:24 PM
Complete Price Guide. Diabolical1 CC Canada Region Forum 0 06-20-2006 03:40 AM
