Old 11-04-2008, 01:02 PM   #51
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
As long as I'm dong this, might as well share thing as I learn them along the way.
I was rescaling my maf in CL and it seemed to be off (I had to adjust it a lot) and there were a lot of outliers:
Then I searched through the car and found two leakks on the turbo inlet nipples and now the plot looks like:
The outliers are much smaller and the data is more closely packed. I think once I fix the other leak, it should be pretty good. Then I'll need to rescale from there.
Bad Noodle is offline   Reply With Quote
Old 11-04-2008, 01:03 PM   #52
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
never mind... somehow double posted
Old 11-04-2008, 01:05 PM   #53
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
It's also VERY important to clean your MAF BEFORE MAF scaling.
Old 11-04-2008, 01:47 PM   #54
breezeby
Member#: 132658
07 TR vf39ed
RomRaided!!!! Oh Yeah!!
so can someone post up a pic of what a scaled maf should look like
breezeby is offline   Reply With Quote
Old 11-04-2008, 01:49 PM   #55
breezeby
Member#: 132658
07 TR vf39ed
so can someone post up a pic of what a scaled maf should look like ?
sorry for the double post!
Old 11-04-2008, 01:52 PM   #56
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
No pics, but all the pink dots should be evenly distributed above and below the 0% line.
Old 11-04-2008, 02:26 PM   #57
Scout255
Member#: 173115
Just wanted to say thanks for the guide. I've found lots of information on basic tuning strategies, but nothing that goes into this much depth. Definately a good read to see one method of tuning a car.
Scout255 is offline   Reply With Quote
Old 11-07-2008, 10:03 PM   #58
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Well... fixed all the leaks and the car runs much better. (The ebay catch can was just crap, leaked at every joint, I just threw it out) Pressure tested everything and now everything is good, but my maf scaling looks like:
It's way off, but the outliers are not as severe:
Here's what it looks like after the first revision to the table using the RR tool:
And then after the 2nd, it's all good.
I'd like to see it all clumped together more, but I don't think it's possible due to the physical limitations of my setup. That and the temps outside as well as gas have a huge influence.
Old 11-07-2008, 10:05 PM   #59
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Your "it's all good" picture looks like it's still pulling a significant amount of fuel across the entire range. Are you sure you're done?
Also, are you using unmodified stock injectors? Your first picture is a classic example of having the wrong injector latency.
Old 11-07-2008, 11:00 PM   #60
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I'm running stock injectors. Not modified. And a Cobb SR intake
The first picture is of the maf scaling I used from one of the protunes I've gotten. I started with it since it's from a reputable tuner.
The second picture is from a different protune I've got. It's actually using stock scaling. I moved to it because I saw that the suggested tweaks to the first map would put me at this setting.
The third pic is after a slight tweak of the stock setting.
I know it's not perfect, but I really don't know what else to do. Adjusting the scaling changes the shape of the curve, it doesn't move the points closer together. It seems to be better than both of the protunes I've gotten, so I guess it's good enough. I'm just happy it's centered around 0. Do you have any ideas how to bring the corrections closer together?
Old 11-09-2008, 02:35 PM   #61
BBBsti LTD
Member#: 71682
2007 WRX Sti LTD.
From what I read, I understand that mostly during the WOT pulls, the car will be in FBKC, so it will be difficult for the ECU to learn to pull any timing in those areas if knock is present. Most of the FLKC happens during a steady driving conditions and not during a quick pull.
Am I correct?
BBBsti LTD is offline   Reply With Quote
Old 11-09-2008, 03:12 PM   #62
eminehart
Member#: 11205
2015 WRX
Am I correct?
After driving the car for a while the car will learn FLKC in higher loads where there is repeated knock but not as much as lower rpms. Mostly because you spend more time there then anything else.
eminehart is offline   Reply With Quote
Old 11-10-2008, 06:42 PM   #63
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Well, found out my front 02 sensor was leaking. (thanks for the advice gabedude) Had to dremel off the crush washer and replace with copper gasket. Car drives much smoother now and the scaling looks like:
Old 11-10-2008, 07:48 PM   #64
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
much better.
You still don't have enough data from 1.3-1.8 though. Try driving around a big open car park (or other large open area) in low gears at walking pace - but at a constant throttle %. Try aiming for 1.3, then increase throttle % a touch till you are at 1.4 - then repeat until you have all the data for 1.2-1.8.
Try spending at least 5-10 min at each point.
wrxsti.l is offline   Reply With Quote
Old 11-14-2008, 12:11 AM   #65
MMWRX
Member#: 175558
1993 Nissan 300ZXTT
1995 4Runner 4x4 5spd V6
I have found my bible. thanks for this BN
MMWRX is offline   Reply With Quote
Old 11-14-2008, 02:24 AM   #66
WReXd
Member#: 114101
93 Impreza L Swap
WOW, I have been waiting for someone to do this for years. Glad someone's finally stepped up so I can finally graduate from n00b status.
WReXd is offline   Reply With Quote
Old 11-14-2008, 05:04 PM   #67
jiggles
Member#: 99032
I vote sticky =)
jiggles is offline   Reply With Quote
Old 11-17-2008, 10:49 AM   #68
kevpotts
Member#: 170156
2010 370z
white
how come this isnt a sticky?
kevpotts is offline   Reply With Quote
Old 11-17-2008, 02:15 PM   #69
WReXd
Member#: 114101
93 Impreza L Swap
He's probably still working on it and getting feedback from other members. I'm sure it will become a sticky in the near future.
Old 11-17-2008, 02:16 PM   #70
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Hey guys, I've been tuning my boost for the past week or so and it's been going very well. I think I made significant progress. With my old tune, boost would hit suddenly and peak boost would be around 4250rpm, now it's smoother and more linear peaking at 3500 and holding steady. I still have some work to do on it so I though I'd mention what I do.
1.) Log boost error, turbo dynamics immediate and integral, throttle plate angle, rpm, and FBKC just in case.
2.) Go for a 45min drive, taking every safe opportunity WOT it. Usually in 3rd and 4th gear.
3.) Come back and let an excel macro sort the data and show me what the average TD correction was at what throttle and RPM.
4.) Go back to the initial WGDC map and add/subtract where needed.
5.) Copy and paste the initial map over to the map and raise each non 0 value by 10%
6.) Go out and do it again.
I'm on my 6th iteration now and so far this has been working out for me. I'll see what happens when I start fine tuning the boost map
Old 11-18-2008, 11:05 AM   #71
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Though I'd update:
Finally got around to hitting my boost targets. Now the fine tuning starts.
My boost is oscillating quite a bit and i want full boost sooner. So I need to stabilize and tone. I noticed that I'm getting huge negative TD corrections early on <25% throttle, which is bad because those negative correction carry over to > 25% throttle (due to TD integral) which is causing my late spool, but once i hit full boost it oscillates badly because my TD proportional drops right away while my TD integral stays at max value.
One way to tune is to always have max td corrections applied (integral and proportional). It prevents oscillation, but doesn't give your ECU the ability to add more WGDC if needed.
So I'm going to try and tune for 0 TD corrections, that way the ecu has some authority to compensate for different conditions.
What that also means is that my boost targets are too low at <25% throttle, so I'm going to have to raise those, that way I spool sooner and have less TD applied. My thinking is the less TD integral I have the less oscillation I'll see.
I'll see how it works out
Old 11-18-2008, 11:16 AM   #72
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
I'm more and more glad that I switched to full MBC. Plug it in, fire up the car, hit the gas, flatline at 18 psi with no oscillation, 0 tuning.
Old 11-18-2008, 11:55 AM   #73
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
nice write up, I love it!
medamullet is offline   Reply With Quote
Old 11-18-2008, 12:18 PM   #74
TRAPSTI
Member#: 83312
05 WRX STi
CGM
I second this. Since the switch to MBC, boost is ALWAYS rock solid. Its simple and it works.
TRAPSTI is offline   Reply With Quote
Old 11-18-2008, 03:30 PM   #75
eminehart
Member#: 11205
2015 WRX
Another option is to go with a parallel boost control system. All the advantages of a mbc with no part throttle full boost and the ability to taper boost towards redline in a controlled way. It also requires very little tuning at all.
My Swap: 1999RS to 2002WRX. Complete Wiring Guide Inside 99 rs Subaru Conversions 235 01-29-2016 03:33 AM
A complete n00b's guide to changing the oil in your WRX (with pics!) perret318 Service & Maintenance 153 11-28-2013 01:17 AM
Complete open source tuning guide shutupnshift04 Commercial ECU Reflashes 19 05-10-2007 05:16 PM
Updated StreetTUNER Tuning Guide and Tuning Guide Worksheets... Christian. AccessPort 0 04-17-2007 05:24 PM
Complete Price Guide. Diabolical1 CC Canada Region Forum 0 06-20-2006 02:40 AM
