Old 11-22-2008, 09:13 PM   #101
korhan
Member#: 103202
09 sti09&00gc8
black&grey
perfect write up
thanks for your effort.
korhan is offline   Reply With Quote
Old 11-23-2008, 01:27 PM   #102
Bullwinkle1983
Member#: 172332
2006 WRX
Originally Posted by Bad Noodle View Post
Here's mine:
Should I add more WGDC at the beginning? I'm hitting full boost at 2800 rpm but that's with full TD correction applied. Should I add more early wgdc so that I won't need the full correction?
You could try a couple things. First, try bringing your WGDC in that 2800 RPM cell down a couple percent. Second, if you're really hitting peak boost at 2800 RPM, change that 2800 RPM value to 2600. This will bring WGDC down before you hit boost. You may lose a tad bit of spool, but if done correctly, the boost will hit and be rock solid.
Bullwinkle1983 is offline   Reply With Quote
Old 11-23-2008, 10:16 PM   #103
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Thanks for the advice. I spent all day tuning this and now that I'm my 36th revision, my map is much closer to yours, but slightly lower values. Past 3500, my boost is rock solid. But my spool is a little rocky. Sometimes I hit full boost like 2900 sometimes 3100, I'm having a little trouble with consistency. It might be the onramp I'm currently going on or the exact rpm I'm in before I start the pull.
The thing I'm trying to nail down right now is right after I hit full boost, my boost takes a 1 psi dip, then steadies out a little later on.
Since my WGDCs are the lowest at 3200, and I'm trying to hit full boost at 2800, i'll set that row to 2600rpm and see if that smooths it out like you say. I think it's a great idea
here's my log now:
Code:
Time     RPM Throttle Manifold Target  WGDC     TDI  TDP
9547	2008	100.02	4.15	8.33	85.88	9.93	3.71
9750	2094	99.87	4.55	9.51	84.71	9.93	3.71
9969	2130	100.02	5.08	10.56	84.31	9.93	3.71
10172	2199	99.87	5.61	11.52	83.53	9.93	3.7
10375	2239	100.02	6.27	12.22	81.96	12.24	3.7
10594	2324	100.02	7.06	14	81.18	12.24	3.69
10797	2383	99.87	8.08	15.01	80	12.24	3.69
11016	2481	100.02	9.28	16.36	79.22	12.24	3.68
11219	2555	99.87	10.62	16.94	76.08	12.24	3.68
11422	2619	99.87	12.28	18.16	75.29	14.54	3.67
11641	2737	99.87	14.44	18.64	71.76	15	3.67
11844	2816	100.02	17.03	19.78	68.24	15	3.66
12047	2922	100.02	19.78	19.96	63.92	15	0.85
12266	3076	100.02	19.3	19.96	58.82	15	0.11
12469	3182	99.87	20.33	19.96	57.65	14.79	-0.35
12672	3342	100.02	17.89	19.96	60	14.66	2.21
12891	3397	100.02	18.97	19.96	58.43	15	0.3
13109	3486	100.02	18.96	19.96	58.43	15	0.23
13313	3654	99.87	19.49	19.96	58.82	15	0.14
13516	3727	100.02	19.66	19.96	59.22	15	0.1
13719	3862	100.02	19.94	19.96	59.22	14.98	-0.03
13938	3951	100.02	20.02	19.96	58.82	14.76	-0.17
14141	4037	99.87	20.12	19.96	58.82	14.5	-0.13
14344	4138	100.02	20	19.96	59.22	14.32	-0.11
14563	4269	100.02	19.98	19.96	59.22	14.12	-0.09
14766	4381	99.87	19.83	19.96	59.61	14	-0.08
14969	4436	100.02	19.79	19.96	60	13.96	0
15188	4587	99.87	19.72	19.96	60.39	13.96	0.06
15391	4670	100.02	19.77	19.96	60.78	14.03	0.03
15594	4775	100.02	19.77	19.96	61.18	14.03	0.02
15797	4864	99.87	19.61	19.96	61.96	14.07	0.09
16016	4980	100.02	19.59	19.96	62.35	14.2	0.1
16219	5103	99.87	19.43	19.96	63.53	14.41	0.15
16422	5156	100.02	19.31	19.96	64.31	14.64	0.2
16641	5292	99.87	19.09	19.9	65.1	14.95	0.27
16844	5372	99.87	18.92	19.7	65.49	15	0.26
17047	5459	100.02	18.65	19.47	65.88	15	0.29
17250	5560	99.87	18.5	19.24	66.67	15	0.25
17469	5633	99.87	18.27	19.05	66.67	15	0.24
17672	5720	100.02	18.02	18.74	67.06	15	0.09
17875	5822	100.02	17.78	18.37	67.06	15	0.14
18094	5900	99.87	17.62	17.93	67.06	15	0.07
18297	5982	100.02	17.33	17.46	67.06	14.9	-0.11
18500	6026	99.87	17.21	17.11	67.06	14.75	-0.13
Bad Noodle is offline   Reply With Quote
Old 11-24-2008, 12:54 PM   #104
Bullwinkle1983
Member#: 172332
2006 WRX
Yeah, here's what my boost and WG looks like with my 18g. Ignore the reference WGDC numbers. The higher boost is from a run recently when I turned up the boost now that it's colder here in MN.
Old 12-06-2008, 10:57 PM   #105
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
Default boost trim error
Tip-in-enrichment (boost error)
This is the extra fuel added to tip in enrichment at a particular boost error (so it's a tip in enrichment enrichment). This will only need to be adjusted if you added larger injectors or a fmic.
1.) For a fmic, set all cells to 0 (the much longer ic piping eliminates the need for this table)
2.) For larget injectors on a tmic, multiply each value by (new injector size / original injector size)
** 2.)is a best guess base on the info from the cobb tuning guide. It's a guess since cobb's fuel multipliers seems to be the inverse of romraiders. The raw ecu values seems to have an inverse relationship with the units used by romraider
I believe there is an error about the "tip-in enrichment compensation (boost error)", "Fuel Iinjector Boost Trim Error" in street tuner here
romraider seem to allow -99.22 to 99.22 values in this table
street tuner alows 0-255
looking at both stock tables it seems that -99.22 in romraider would = 0 in street tuner which would = no boost trim compensation
I think that they are liner just different values
using Sreet Tuner and their instructions I rescaled this table fo 650cc injectors from 550 stocks
this is what it ends up as in the same map I pulled with ECU flash
my math is +100*(old/new)= X -100 = (new value)...but thats not right
I am trying to scale this for 1100cc injectors in romraider any one want to do the math .....I'm tired
a6n6d6y is offline   Reply With Quote
Old 12-06-2008, 11:12 PM   #106
Tea cups
Member#: 103136
It appears ST is using the raw ECU value. The conversion from the raw ECU value using RomRaider's conversion would be (x*.78125)-100.
-100 in RomRaider would be 0 raw value.
Also, not that it matters for this table, but you are using old ECU defs. I suggest you update to the latest ECU/logger defs for additional table/parameter/ROM support.
Tea cups is offline   Reply With Quote
Old 12-06-2008, 11:33 PM   #107
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
thank you for the math
how did you determine the old defs from the pics ?
Old 12-07-2008, 07:51 AM   #108
Tea cups
Member#: 103136
Well, they are my defs - so I'm intimately familiar with them.
Old 12-07-2008, 05:02 PM   #109
paul_p1
Member#: 77372
2005 Spec C
WR Blue
Since I can't post on the RR forum for some reason....
Can anyone give me an idiots guide on how to use the rescaler tab on Airboys spreadsheet?
Is there any reason why the AFR tab didn't get the same rescaling function that the Ignition Timing table has?
I'm not ungrateful, just wondering.
Thanks,
Paul
paul_p1 is offline   Reply With Quote
Old 12-19-2008, 12:33 PM   #110
boostdog
Member#: 149752
2017 wrx
ICE ICE BABY SILVER!
Bad Noodle...not sure if it's been mentioned or added yet but you need to add a section explaining how to raise/lower the redline level.
boostdog is offline   Reply With Quote
Old 12-19-2008, 01:26 PM   #111
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
Great writeup. I am a UTEC user myself and love it! I have just recently started using romraider with my UTEC. I love how I have infinate possibilites.
emsmap is offline   Reply With Quote
Old 01-01-2009, 01:26 PM   #112
flimflamman
Member#: 147328
2007 WRX
FlimFlamRacing
Thanks for the info. Subscribing...
flimflamman is offline   Reply With Quote
Old 01-12-2009, 07:25 PM   #113
AWDboostADDICT
Member#: 196257
02 wrx 354 whp RIP
10' genesis coupe
Wow 5 stars.
this is one of the greatest writeups / guides ever.
AWDboostADDICT is offline   Reply With Quote
Old 01-13-2009, 02:33 AM   #114
in1t
Member#: 184965
hey, Bad Noodle, thanks for this GREAT job!!! and I want to translate it to russian lang, if you approve it!
in1t is offline   Reply With Quote
Old 01-13-2009, 07:47 AM   #115
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
It's all good to with me. I say go for it as long as merchgod and teacups are good with it. I used a lot of their info
Old 01-13-2009, 02:51 PM   #116
weps
Member#: 183495
Bad Noodle, think you could post the original google doc or a pdf to make for easier printing? I already made a word doc for myself, but I would have appreciated one so I didn't miss anything...
weps is offline   Reply With Quote
Old 01-13-2009, 02:59 PM   #117
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Hey, I made some mistakes in the original that I corrected in these posts. So the posts are all up to date. I didn't bother updating the original docs, which is why I didn't want to post them.
Old 02-06-2009, 02:26 PM   #118
D-NaSty
Member#: 156456
2005 92x aero
needs to be a sticky
D-NaSty is offline   Reply With Quote
Old 02-07-2009, 05:09 PM   #119
pilotstephen
Member#: 155145
2004 WRX STI
Bruised
Great post.
pilotstephen is offline   Reply With Quote
Old 02-16-2009, 01:14 AM   #120
Chevarian113
Member#: 148415
1991 MR2 turbo
05 Outback XT
It has been said, but I have to add to it. AWESOME POST! Thanks so much for your research and time you took to put this together.
Chevarian113 is offline   Reply With Quote
Old 02-18-2009, 08:16 PM   #121
iahtnoob
Member#: 179340
weird question: when you say you should use a virus free laptop; can a laptop with lots of viruses transfer a virus to the car ecu when loading maps or data logging?
iahtnoob is offline   Reply With Quote
Old 02-18-2009, 08:18 PM   #122
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
no, but if the virus halts or slows your comp while flashing, you might damage the ecu or completely break it
Old 03-16-2009, 10:41 AM   #123
hklatte
Member#: 131234
2007 WRX Wagon
bump!
Why don't we just make this thread sticky? I just started learning all this tuning thing and I personally look at this thread at least once a day LOL!
hklatte is offline   Reply With Quote
Old 03-16-2009, 04:09 PM   #124
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
i cant tell you how much this helped me at the end of last year when i was first getting into tuning my own car. THANK YOU! i have since sent every person that has tuning questions to read this its a great starters guide and i just realized that i should probably thank you for it! and i agree, it should be a sticky, im tired of telling people to search for it or pasting a link
elevenpoint7five is offline   Reply With Quote
Old 03-16-2009, 11:26 PM   #125
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
another nomination for sticky!!!
MikeWRX-NJ is offline   Reply With Quote
My Swap: 1999RS to 2002WRX. Complete Wiring Guide Inside 99 rs Subaru Conversions 238 09-26-2016 11:35 AM
A complete n00b's guide to changing the oil in your WRX (with pics!) perret318 Service & Maintenance 153 11-28-2013 02:17 AM
Complete open source tuning guide shutupnshift04 Commercial ECU Reflashes 19 05-10-2007 06:16 PM
Updated StreetTUNER Tuning Guide and Tuning Guide Worksheets... Christian. AccessPort 0 04-17-2007 06:24 PM
Complete Price Guide. Diabolical1 CC Canada Region Forum 0 06-20-2006 03:40 AM
