Old 10-28-2008, 07:10 PM   #1
leonwrx13
Member#: 183021
05 STI Parts
Default Rs to sti
has any one her done an STI swap on a 2 dr RS. if so how much fabrication is needed? and what all needed for the swap? also what would be a rough estimate on a swap?
leonwrx13 is offline   Reply With Quote
Old 10-28-2008, 08:20 PM   #2
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
there have been quite a few swaps, it would cost pretty much the same as swapping it into any other non sti vehicle do a search i know there are some good write ups, but its basicly just taking out what you got and putting in better stuff
seanathanq83 is offline   Reply With Quote
Old 10-28-2008, 08:31 PM   #3
EuroScuby
Member#: 146056
2004 Subaru WRX STI
I know a few people that have done this but most of them end up having trouble with their cars. I'm not sure if thats because it was put together poorly or not. I am thinking about doing this myself if I sell my 04 STi. The GC8 is the best bosy style Subaru ever came out with. Living in Europe, I have seen my share of 22B's but unfortunately I can not bring one back to the states with me when I move back.
EuroScuby is offline   Reply With Quote
Old 10-28-2008, 08:40 PM   #4
Dipp
Member#: 127907
99RS 9.54 @ 146
2.65L & FOBIA fab & S374
Not much fabrication but many parts don't fit due to the RS being more narrow and shorter. My swap took a month due to lots of parts not fitting correctly.
Dipp is offline   Reply With Quote
Old 10-28-2008, 09:32 PM   #5
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
just finished my swap everything fit just fine . I even had to convert it from fwd to awd !
sense of nature is offline   Reply With Quote
Old 10-28-2008, 09:34 PM   #6
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
icard:
I wish you kids would post in the right damned forum.
Old 10-28-2008, 10:41 PM   #7
sense of nature
Member#: 112759
SexyRP
Old 10-29-2008, 05:39 AM   #8
VIsubi
Member#: 187834
06 2.5i impreza
Red
does anyone know if an STI block of the same year will bolt up to the RS heads or say 2.5i....thats my biggest problem seeing as I'm going with an AVO kit on order but also thinknig of going with an STI block later down the road..once I get my money saved up from the AVO kit.....
VIsubi is offline   Reply With Quote
Old 10-29-2008, 09:43 PM   #9
leonwrx13
Member#: 183021
05 STI Parts
so if i get an RS with a blown motor, and a wracked sti.
1. what else would i need for the swap?
2. what all has to be switched from the sti to the rs? engine tranny drive shaft diff etc.. ?
3. can i steal the dash gauges, and the big brambo breaks and bolt them up?
Old 10-30-2008, 06:52 AM   #10
JMack
Member#: 183773
1997 Legacy GT Wagon
Red
The answer to this question would be easier to determine if you put what exactly that you want to swap. If you want the interior, just engine, etc... I know that the guage cluster will be determined by the year ECU that you wind up with. They changed the connectors on a couple of the years, and some are not compatible with some ECU's.
The engine and tranny will fit, no problems really.
The rear and center diffs will fit, no problem.
The parts that I am actually researching prior to attempting a swap myself is the Axles and Driveshafts. The rear diff and tranny determine the axles, and I'm still unsure about the driveshafts.
The ECU and wiring harnesses will need to be swapped or merged depending on what type of swap that you are going to go with.
See #1, I kinda addressed that issue already for the guages.
About the BREMBOs, they will bolt up as long as you are using the correct knuckle and axles I believe.
I hope I helped a little...
JMack is offline   Reply With Quote
Old 10-30-2008, 12:09 PM   #11
silentt
Member#: 119995
2004 Outback XT
Peachy
Exactly. If you plan on using STI suspension, you need rear top hats from a 90-91 legacy.
The STI driveshaft bolts right up and I used stock STI axles as well as the hub/knuckle set up. If you want to use RS hubs/knuckles, you'll need to do some piecing together - something I wanted to avoid with my swap.
If you use the STI hubs/knuckles, you can use the brembos. Otherwise you'll need an adaptor-braket-type-thing for the rears (IIRC). Axles have nothing to do with it.
silentt is offline   Reply With Quote
Old 10-30-2008, 09:55 PM   #12
leonwrx13
Member#: 183021
05 STI Parts
thanks guy that helped a bit and also created another millions questions. i know u sad about the ecu. but i see people swap wrx dashboard in there RS's. i always thought that the wrx were wider. can that be done with a sti dash. and i wont to use everything from the wracked sti. i want the engine, tranny, and brakes and everything else to make it work.
Old 10-31-2008, 08:44 PM   #13
leonwrx13
Member#: 183021
05 STI Parts
oh and also i read some where that to make the sti swap work im gonna need a legacy crossmember
Old 10-31-2008, 08:55 PM   #14
leonwrx13
Member#: 183021
05 STI Parts
oh and i also read somewhere that to make the sti swap work im gonna need a legacy crossmember. is that true?
Old 11-01-2008, 12:37 AM   #15
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
If you mean engine cross member you will need a turbo cross member. If its a pre MY2000 unit it will be direct bolt in. After MY01(jp) or MY02(US) you'd need to shim the control arms.
Old 11-02-2008, 08:59 AM   #16
leonwrx13
Member#: 183021
05 STI Parts
so its better to get a 99 rs, is that what u saying?
Old 11-03-2008, 04:13 PM   #17
ciper
Member#: 15543
90BJ Legacy LS ABS
Not at all. I'm talking about the cross member donor car. It has to be a turbo cross member and if its prior to my01 it will be direct bolt in to any US my93-my01 Impreza.
Old 11-25-2008, 06:24 AM   #18
arfrce
Member#: 126130
06 Subaru STi
Here you may want to contact http://www.licmotorsports.com go there are start reading then call them and chew their ears off. lol. Cause no matter how many questions we answer it will raise 10 more that you have. I could list all the question you will have but that doesn't mean you will understand how I explain it. Unless your a mechanic then I can answer away. But, from what I have read your not a day to day mechanic. So check these guys out. Also there are few companys like these guys that will convert your car for you. Just search around the net.
I personaly like the idea of a 01 RS STi running gear that is 2 wheel drive. And I don't mean by taking out the front drive shafts, thats the crappy way to do it.
arfrce is offline   Reply With Quote
STi Strut bar... RS to STI? PSI87 Brakes, Steering & Suspension 4 02-14-2006 11:44 PM
05 Rs to sti conversion?? zmaster Normally Aspirated Powertrain 47 10-23-2005 10:27 AM
01 RS to STi 6 speed conversion question/info needed Texas25RS Transmission (AT/MT) & Driveline 2 05-17-2005 01:43 PM
Who went from GC RS to STi PRODRIVEN General Community 8 08-08-2004 01:58 PM
RS to STI tranny swap. jeffg Transmission (AT/MT) & Driveline 17 02-13-2002 10:53 PM
