Old 10-28-2008, 07:59 PM   #1
mywifesSTi
Member#: 142709
07 STi Limited
FP HTA Green 372whp
Default 295whp not enough
I had my sti tuned recently. My #'s were 295whp. I was a little dissappointed with the top end power. The car feels like its got nothing after 5500. My tuner said he had trouble getting the car to hold boost & to check for an exhaust leak. After investigation I found I was missing a stud on the dp and plenty of soot. I scheduled another road tune. With the leak fixed will I see a gain in whp? Or can I do something like a cai before the road to gain a little more top end?
My mods are:
maddad unequal length headers & up pipe
maddad catted dp
maddad 3" whisper cb
K & N Typhoon Intake
walbro 255 fuel pump
ap V2
mywifesSTi is offline   Reply With Quote
Old 10-28-2008, 08:34 PM   #2
Gray Ghost
Member#: 162790
Probably feel alot better after the next tune. Wait and see. Make sure to post results
Gray Ghost is offline   Reply With Quote
Old 10-28-2008, 10:34 PM   #3
sysfailur
Member#: 135993
08 AW STi GTX3071
V-Mount, 18x12, 335 R888
If it's your wife's STi I doubt she'll enjoy a CAI lol
sysfailur is offline   Reply With Quote
Old 10-29-2008, 05:27 PM   #4
mywifesSTi
Member#: 142709
07 STi Limited
FP HTA Green 372whp
I might do the phenolic spacers, p&p the intake manifold & turbo inlet.
Old 10-29-2008, 05:34 PM   #5
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
If the leak is post-turbo, you likely won't notice a huge difference. It's going to be hard to improve the top-end on that turbo, but EWG/methanol, and some other goodies can help. Ever thought about a better turbo? A 20g will spool up nearly as fast as the 39 but have WAY better midrange and top-end.
Audiosavvy is offline   Reply With Quote
Old 10-29-2008, 05:41 PM   #6
mongoosaroo
Member#: 115056
2002 psm now w/ 2.5
jesus tuned my hot rod
Td0620g Ftw!
mongoosaroo is offline   Reply With Quote
Old 10-29-2008, 05:43 PM   #7
TurboWRX32
Member#: 107557
2006 WRX
Steel Gray
Bigger turbo get rid of that little vf39. 18g w/8cm or 20g. Get tuned on a dyno not street tune.
TurboWRX32 is offline   Reply With Quote
Old 10-29-2008, 05:44 PM   #8
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
Originally Posted by mongoosaroo View Post
Td0620g Ftw!
TD06 wheel in a 20g is arguable for efficiency's sake. Go Dom3
ErasureWRX is offline   Reply With Quote
Old 10-29-2008, 06:04 PM   #9
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
The midrange would be about the same, the 20g would shine in the 5K rpm and above range. On pump gas they are pretty close, especially on CA91.
Infamous1 is offline   Reply With Quote
Old 10-29-2008, 06:46 PM   #10
mywifesSTi
Member#: 142709
07 STi Limited
FP HTA Green 372whp
I know the vf43 is not a top end monster, but I know it's capable of more than 295whp. I will eventually put a bigger turbo on, prob fpgreen when I can afford it.
Old 10-29-2008, 09:08 PM   #11
lev98
Member#: 140529
01 Ferrari 360 spy
295 is actually a pretty good number with that turbo. As most wll say it has very little topend and once you step up to a bigger turbo you will see how little it actually had.
lev98 is offline   Reply With Quote
Old 10-30-2008, 12:17 AM   #12
sleepersti04
Member#: 146554
2004 STi WRB
30R
I'm selling my Green, If your interested
sleepersti04 is offline   Reply With Quote
Old 10-30-2008, 12:34 AM   #13
oldmansan
Member#: 17877
Midnight Pearl
Get a real tune (dyno). How do you know what your car put down with a road tune? When you get a real tune, be sure to post as to what type of dyno and smoothing for comparison purposes. Regardless, your numbers aren't bad, but you definately have room for improvement.
San
oldmansan is offline   Reply With Quote
Old 10-30-2008, 01:19 AM   #14
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Look up the 12.0 stock turbo 07 thread by STIMIKEY
07 STI with just stage 2 and a good tune can be a solid low 12 sec car. While still maintaining the stock like manners.
Junior2JZ is offline   Reply With Quote
Old 10-30-2008, 09:58 AM   #15
PerformanceAutoSolutions
Member#: 853
2011 STI Sedan
Satin White Pearl
07 sti which those glass pistons could be the issue--but 295 is not that bad
dave
PerformanceAutoSolutions is offline   Reply With Quote
Old 10-30-2008, 10:29 AM   #16
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
Originally Posted by oldmansan View Post
Get a real tune (dyno). Regardless, your numbers aren't bad, but you definately have room for improvement.
San
A road tune is better than a tune on a dyno, with the exception of the speeds you must get to. I really don't see much more room for improvement on this set up.
OP what kind of dyno was the car run on? That may be why the number was lower than expected. If you've ever looked at other vf39/43 setups they usually fall flat around 5500 as well.
domestic_abuser is offline   Reply With Quote
Old 10-30-2008, 10:53 AM   #17
bebesito21
Member#: 176128
5862 ...baby boosted
^^^^^beat me to it!!!!
San
street tunes are just fine....think about it....the car is performing in the actual enviroment it will once you get OFF the dyno. You can tune throughout the rpm band in different gears and get a better overall driveable tune. no worrying about loads and correction factors etc. The best way is to start on the dyno then go fine tune on the street.
OP, get a gt30 and make sure your tuner is watching for knock no matter what turbo you get.
bebesito21 is offline   Reply With Quote
Old 10-30-2008, 03:48 PM   #18
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
My mods are:
maddad catted dp
ap V2
Get rid of the headers, get rid of the catts, get a mbc. Check for leaks, get tuned, you'll be much happier with the results.
STi Mikey is offline   Reply With Quote
Old 10-30-2008, 04:00 PM   #19
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Why get rid of the headers, they will only HELP his midrange and top end?
Old 10-30-2008, 04:13 PM   #20
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Glass pistons? Wha? I thought the motor in the 04-07 STI is the same with the 07 having "better" heads and the VF-43. What is the difference between the pistons?
To the OP, like already said, those numbers might not be low depending on what a baseline STI does on that dyno. I cannot see a chart if you posted one because I'm at work, but what kind of torque did you make?
Also, I'd recommend picking up a Hallman Pro MBC for when you go in for the fixed tune. I would think that will help hold boost better than the factory 2-port solenoid.
If you really want to get the most out of your stock turbo, have an exhaust shop fab an EWG mount onto your uppipe and just route it back into the downpipe to keep it "sleeper". I'm not sure if the MadDad uppipe has a flex section but that would be a good idea too if you plumb it back into the downpipe.
Can't wait to see the results, I have an 07 STI also and have yet to get it pro-tuned. I have a few more parts to pick up.
Steve.804 is offline   Reply With Quote
Old 10-30-2008, 04:30 PM   #21
STi-MAN
Member#: 70252
05 STI
blue
top end? isn't it the turbo that is holding us back top end?
STi-MAN is offline   Reply With Quote
Old 10-30-2008, 04:42 PM   #22
mywifesSTi
Member#: 142709
07 STi Limited
FP HTA Green 372whp
San
It was dyno tuned. The tuner said he could take me out for a road tune to see how I drive it and maybe get some more power out of it.
Old 10-30-2008, 04:52 PM   #23
mywifesSTi
Member#: 142709
07 STi Limited
FP HTA Green 372whp
I made 360wtq @3k. This was on a Dyno pak. The tuner has been very professional and I have nothing bad to say about him. Hopefully he can turn up the boost a liitle more than 19.3 when I go
Old 10-30-2008, 05:51 PM   #24
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Honestly, it may seem crazy but the headers will not help on the stock snail.
On a dyno jet my car makes 390whp and 462wtq. Area under the curve is rediculous. My buddy CTracer makes 400whp and 480wtq, even more rediculous. This shows the stocker can be maxed out on the stock set up with no flow issues (considering a TBE has been installed).
There are 5 STi's in the united states on the stocker that trap between 115-116. I believe to the best of my knowledge not one has headers. Not positive of the science behind it, but the stock headers flow just fine.
Old 10-30-2008, 07:02 PM   #25
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
Just because they are fine or make big power doesn't mean there isn't room for improvement. It is possible to gain power with aftermarket header even on the stock turbo, however it might not show up in peak power numbers. The reason I don't run them on my setup is because of the reliabily issue. BTW I trapped close to 111mph on my vf39 with a Dynamic Altitude of over 3K feet in my heavy ass LGT.
Too Many Rotors.. Not enough info BJamerican Legacy Forum 1 01-06-2002 06:18 PM
Too much equip and not enough space spshultz Car Audio, Video & Security 3 10-29-2001 04:34 AM
Not enough autocrossers!!! skidplatez South East Region Forum 13 04-12-2001 07:25 AM
Not enough members Jarrod Li General Forum Archive 5 08-31-2000 10:55 AM
