Old 10-28-2008, 09:32 PM   #1
bcWRX-02
Member#: 181780
2002 WRX Sedan PSM
'01 CBR 600 F4i
Default Wiring Prosport gauge illumination to a fuse
I've had my boost gauge wired for illumination to the headlights since I first installed it about 6 months ago. It's been a constant problem, the connection keeps coming loose and then my gauge glows a weak amber, not white, until the headlights are switched on. So I've decided to tap the illumination wire directly to a fuse source. Which fuse should I use for it to glow white when headlights are off, and green when they are on? I was thinking the 10A ILLUM, can't remember which fuse # it is. Will this work?
bcWRX-02 is offline   Reply With Quote
Old 10-28-2008, 10:49 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Since the lighting system uses a switched ground to turn the lights on you may need to install a relay to supply power to the gauge. If the gauge has an isolated ground lead for the light then you should be able to tie that to the light switch and the power lead to a power source. When the light switch is turned then the ground will be made and the light will turn on.
Old 10-28-2008, 10:53 PM   #3
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Why not wire it to the stereo illumination wire? Its closer than your headlights. There is also an illumination wire going to your clock pod.
Noah is offline   Reply With Quote
Old 10-28-2008, 10:57 PM   #4
bcWRX-02
Member#: 181780
2002 WRX Sedan PSM
'01 CBR 600 F4i
Was thinking about that too. Can you somehow point out which wires those are? Or even the colour? I think illumination to the stereo is purple?
Old 10-28-2008, 11:03 PM   #5
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
if it comes lose... why dont u solder it .. i soldered all of mine..
azn0boi04 is offline   Reply With Quote
Old 10-28-2008, 11:06 PM   #6
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Your easiest bet is going to be pull the clock pod as the plug going into the clock is labeled.
It should be labeled as ILL and the wire is most likely orange. Soldering would be the best connection method, or you could use a vampire tap for something easier but still rather secure.
Old 10-29-2008, 09:34 AM   #7
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
Clock pod FTW. Works perfect.
ThreeEleven is offline   Reply With Quote
Old 10-29-2008, 01:02 PM   #8
Cougar4
Member#: 53443
Winestone
The violet wire for the illumination system is tied to the hot side of the circuit. The orange is tied to the controlled ground side. Do not tie to the orange wire or you will have illumination problems.
Reducing prosport gauge illumination, is it possible? Ziggyrama Electrical & Lighting 26 02-16-2013 08:50 AM
help with wiring/prosport gauges JSA Electrical & Lighting 1 05-23-2008 03:19 AM
Need Exact Wires to Attach Prosport Gauge Wires To Idaho Electrical & Lighting 1 09-12-2007 06:15 PM
Just got my Prosport Gauges....time to get creative B00st3dWRX Interior & Exterior Modification 1 04-22-2007 11:36 PM
To All Looking For Gauge Illumination Wiring Setup daytontp Interior & Exterior Modification 7 04-17-2002 10:38 AM
