Old 10-29-2008, 03:10 AM   #1
subaruNV
Member#: 154549
2006 DOM 3 Powered
WHITE/ EQ Tuned 350Whp
Default EQ tuning Dom 3 wrx limited
elv..5000 ft
mods...
dom3
tgv deletes
aps inlet and intake
spearco tmic
one step colder plugs
injen down pipe
invidia N1 catback
gruppe-s UEL headers
perrin uppipe
snow performance
cobb V2
255 fuel pump
750 DW injectors
Ed custom EQ tune
Car made 350 whp and 356 wtq on 91 tuned conservative to help save the tranny....boosting 23 and taper to 20-19
I hope to get to a track soon to get a trap speed...I hope to possibly see 11's depending on how hard i want to push my 5 speed
subaruNV is offline   Reply With Quote
Old 10-29-2008, 03:29 AM   #2
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
your tranny is gonna blow. but those are good numbers. just about the same setup as me. but im running fmic and stock header.
i just blew my 3rd gear.
bhhamblin is offline   Reply With Quote
Old 10-29-2008, 03:32 AM   #3
subaruNV
Member#: 154549
2006 DOM 3 Powered
yes i no only a matter of time.... im saving up over the winter for a 6speed, prob a six speed out of an 07....I hear the 4th gear in the 07 is longer then 05-06
Old 10-29-2008, 04:16 AM   #4
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
cool, i will be doing a PPG 5spd so i can have the longer gears.
Old 10-29-2008, 11:01 AM   #5
mantra1
Member#: 23568
'08 Forester STi
Shaggin' Wagon Thrice
Damn, good numbers for TMIC and piss water for gas.
mantra1 is offline   Reply With Quote
Old 10-29-2008, 11:09 AM   #6
Stames_wiltz
Member#: 143264
2006 WRX TR
Obsidian Black Pearl
I wouldn't call 23 psi conservative for 91 octane. And tapering to 19-20 psi at redline again is not conservative by any means. Most are Peak boosting at 19-21 psi and tapering to 17-18 at redline and this is with 93 octane. I don't mean to send out red flags, but I would Log my car and watch for Knock/DET.
Nevada/Cali/Arizona are renound for having worse gas then the rest and we are also approaching the winter with the Crappy winter gas starting to hit our pumps. I am now mixing race gas in my car with 91 octane to keep my octane rating up a bit. Just be careful.
Congrats on the new found power, I am sure it feels Sweet!
Stames_wiltz is offline   Reply With Quote
Old 10-29-2008, 11:56 AM   #7
Zumble
Member#: 34860
2005 Forester CGM
Amount of boost is really only part of the picture though. We don't know the timing associated with the boost or AFRs.
Zumble is offline   Reply With Quote
Old 10-29-2008, 12:02 PM   #8
subaruNV
Member#: 154549
2006 DOM 3 Powered
I know the AFRs 11.2-11.3 at fool boost i will try to get a log post on here soon.... and the dyno sheet from ed
Old 10-29-2008, 01:09 PM   #9
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
elv..5000 ft
mods...
dom3
tgv deletes
spearco tmic
injen down pipe
invidia N1 catback
perrin uppipe
cobb V2
255 fuel pump
750 DW injectors
Ed custom EQ tune
PPG's and C16 = mid 11's in your future
STi Mikey is offline   Reply With Quote
Old 10-29-2008, 04:34 PM   #10
fatcircles
Member#: 142310
Those are some pretty high numbers for your setup.
fatcircles is offline   Reply With Quote
Old 10-29-2008, 04:51 PM   #11
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
elv..5000 ft
mods...
dom3
tgv deletes
spearco tmic
injen down pipe
invidia N1 catback
perrin uppipe
cobb V2
255 fuel pump
750 DW injectors
Ed custom EQ tune
randy didn't you forget meth, forged pistons, and i think a p&p head...
anyway the meth is why boost is that high, is 21 on regular 91. Back to the OP
The car is amazing and pulls very hard! the #'s are amazing!!!
renosubby is offline   Reply With Quote
Old 10-29-2008, 08:54 PM   #12
subenerd
Member#: 72630
2004 STi
^^Haha, I knew it had to have meth or higher octane for those numbers on Ed's dyno software!
Paging Dr. Ed for the dyno graph.....
subenerd is offline   Reply With Quote
Old 10-29-2008, 09:48 PM   #13
downsti
Member#: 63179
2006 Stock Turbo STi
[email protected] VF39
Congrats bro for the new found power. that should be able to get you in the 11s if tranny lets you
Props to ED for another badass Tune.
its longer, at that power level youll goin to need into shift into 5th gear with the 07
shorter gear is way easier to accelerate than taller gears but taller gears tends to give you less shift( so it has its advantage and disadvantage )
but if your still shifting into 5th gear with the 07 STi and 5th gear for 04-05-06 STis are the same on 07 STi, The taller 3rd and 4th on 07 STi ..vs.. shorter 3rd - 4th on 04-05-06 STi
the 04-05-06 will have better a acceleration due to shorter 3rd and 4th,
downsti is offline   Reply With Quote
Old 10-29-2008, 10:21 PM   #14
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Also, don't rely on the 07 STI tranny having longer gears. There is a thread around here somewhere, but a lot of guys are reporting the shorter 4th...obviously, they are quite pissed about it.
aboothman is offline   Reply With Quote
Old 10-29-2008, 10:22 PM   #15
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Nice numbers, pretty much the setup I will be running soon
Any info on injector duty cycles would be great, especially if you have a purely 91 map.
I want to see what IDCs I will be seeing with a similar setup.
Old 10-29-2008, 10:52 PM   #16
subaruNV
Member#: 154549
2006 DOM 3 Powered
I got the car tuned on only 91 before this and i believe my IDC was 82 or so % but i can recheck to make sure
Old 10-31-2008, 05:24 AM   #17
subaruNV
Member#: 154549
2006 DOM 3 Powered
car made 315 and 300 wtq on only 91 ...conservative cuz of the tranny and this tune was way nice but still conservative with meth so when the tranny comes we will have some fun with it
Old 10-31-2008, 07:12 AM   #18
Iflysti06
Member#: 156955
2006 STI
UR GT35R w/ mad bolt ons
dyno sheet?
Iflysti06 is offline   Reply With Quote
370WHP alternative to Dom 3.0XT-R turboICE Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 06-07-2010 12:04 AM
EQ Tuning Stage 1 Shortblock + Blouch DOM 3.0R + 91 Octane + Meth = 384whp! Equilibrium Tuning Proven Power Bragging 34 03-19-2009 08:52 PM
07 WRX VF39 Tuned By EQ Tuning Boost_Creepin Proven Power Bragging 24 03-10-2009 01:55 PM
Want advice on my tuning idea for the Dom 3 ndubz Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 03-07-2009 01:27 PM
Blouch Dom 3 on EJ205, 96ish Octane, Tuned by [email protected] PC tuner Proven Power Bragging 14 07-08-2008 10:34 PM
