Old 04-26-2001, 05:01 AM   #1
mykrrrr
Member#: 733
'13 Focus ST
Question Emissions after motor swap
Has anyone had to do an emissions test after they did an WRX/STi swap???
When did OBDII come into existance??? Mid-90's right??? Is OBDII worldwide or just NA???
just wondering
-myk
mykrrrr is offline   Reply With Quote
Old 04-26-2001, 06:29 AM   #2
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Post
I'm kind of wondering the same thing. I wonder what they had to do to make it legal.
I'm also wondering how the jap spec and aussie spec EJ20 does with our American lower octane gas. They run like 98 octane over there, right?
Thanks
Brad
MY99 2.5GT is offline   Reply With Quote
Old 04-26-2001, 11:34 AM   #3
CosmoTheCat
Member#: 3409
1996 OBS
Green.
Post
IIRC their octane ratings are calculated differently.
CosmoTheCat is offline   Reply With Quote
Old 04-26-2001, 11:43 AM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Post
Brad,
I've done a bit of research on this on the UK WRX sites, since they grey market import J-Spec WRX's as well as do engine swaps. Supposedly the ECU is pretty smart and what it does it restrict the boost and advance to prevent detonation. I've seen dyno numbers posted that indicate that the 276hp JDM WRX's drop to around 245hp on 95 octane UK gas.
And then for track day, you buy race fuel(100-102) at the track, reset the ECU and are off to the races, so to speak.
Old 04-26-2001, 12:42 PM   #5
Cacophony
Member#: 213
2004 Mazda RX-8
Post
Once again, Sunoco 94 is equivalent to 98 RON gas throughout the rest of the world.
Of course, you could always fill up with 100 octane Sunoco GT
Cacophony is offline   Reply With Quote
Old 04-26-2001, 02:27 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
Post
Cacophony,
Unfortunately, us poor fools in Nor-Cal can't get anything better than MBTE loaded 93 octane piss without going to the track.
As far as the emissions question, it should burn clean enough to pass even CA's smog. The trick is the visual( and it is a whole lot more than that here in CA). I used to run a JDM engine swapped civic, and it is some work to make it truly legal. But not all states are Nazi like CA. Best to research your local laws about transplants. Feel free to send me a PM if you want to pick my brain.
Old 04-26-2001, 02:47 PM   #7
subarurabbit
Member#: 4083
2011 OB 3.6R
Post
My '95 Legacy LSi has ODB II. It was the first year for Subaru.
Roger
subarurabbit is offline   Reply With Quote
Old 04-26-2001, 04:26 PM   #8
mile hi
Member#: 6129
1995 coupe
green metalic
Post
Some states will allow a older engine in a newer car I have a '94 turbo motor in a '95 Imprezza and it passed. All it has to do is pass '95 standards but I am sure this varies state to state so it would be wise to check
mile hi is offline   Reply With Quote
Old 04-27-2001, 01:31 AM   #9
RS ING
Member#: 2928
Post
As far as being Emissions legal. You are aloud to drop in a new motor to an older car but not the other way around. As far as passing emissions with a JDM motor I have no idea. Hope for a blind emission station if you have get smogged. May be that honda forum might be a better place to ask this question as there seem to be loads of JDM engines being swapped there.
RS ING is offline   Reply With Quote
motor swap help STI longblock into a Legacy gingertooth Legacy Forum 6 06-01-2010 10:16 PM
Fuel Cut After Motor Swap mtskibum16 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-27-2010 09:55 PM
no start after motor swap ejpowerguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 03-22-2009 10:56 AM
Trouble w/ emissions after engine swap. Need Help SubaruPreza Subaru Conversions 14 12-02-2004 11:55 AM
Emissions problem after motor swap jdmgc8 Subaru Conversions 15 09-25-2004 03:56 PM
