Old 10-29-2008, 03:08 PM   #1
subaruwrx
Member#: 1818
03 1996 Impreza Wa
Soon to be a v3 STI
Default EJ20G CEL Code 45 - Pressure Duty Solenoid
Has anyone run into this problem? The only thing I found was this
http://www.uklegacy.com/forums/index...1&#entry105161
But it has no informationl. I need to know what the symptoms of this thing failing are and what I can do to fix it. The car cuts at 4500 RPMs and this is the only code it gives.
subaruwrx is offline   Reply With Quote
Old 10-29-2008, 05:30 PM   #2
bobjr94
Member#: 6176
15 WRX, 04 wrb STi
85 wrb BRAT
This is what I can find about testing it. If its not working, the ecu is probably doing a fuel cut to save it self from to much boost.
bobjr94 is offline   Reply With Quote
Old 10-30-2008, 12:01 AM   #3
Rikshaman
Member#: 90817
Hey man,
do you have an ej20g in sf? is it rhd?
Jw.
Rikshaman
Rikshaman is offline   Reply With Quote
Old 10-30-2008, 01:19 AM   #4
subaruwrx
Member#: 1818
03 1996 Impreza Wa
Soon to be a v3 STI
Originally Posted by Rikshaman View Post
Hey man,
Jw.
Rikshaman
nope. 1996 Outback Sport. Newly swapped. CEL and wiring short. :-/
But I am in San Francisco.
Old 10-30-2008, 02:40 AM   #5
Rikshaman
Member#: 90817
Sick, and another ej20g joins the ranks. I know how wiring goes man.Stay true. Let me look into that for you...
Old 10-30-2008, 11:12 AM   #6
subaruwrx
Member#: 1818
03 1996 Impreza Wa
Soon to be a v3 STI
cool, thanks bro!
GC8 CEL Code 24: Idle Air Control Solenoid Valve pr1nce Pre-2002 Factory Turbo Powertrain 15 01-29-2011 03:34 PM
ej20g code 45 CEL gc8awdsti Pre-2002 Factory Turbo Powertrain 16 03-29-2009 12:20 PM
Pressure Duty Solenoid from STi ver5 Llama Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-23-2005 01:37 PM
CEL code P0106 Pressure sensor circuit range/performance problem (low input) crk4 Normally Aspirated Powertrain 4 07-17-2005 02:40 PM
CEL code p0245 - Turbo Waste Gate Solenoid Hank3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 07-23-2002 06:03 PM
