Old 10-29-2008, 07:07 PM   #1
jetfan2207
Member#: 61950
2008 Outback
big blue wagon
Default 1/4 mile gurus- drag slick question
Hey all,
I have offically fallen in love with drag racing. I don't race, I just watch but I have noticed at the local strip that a lot of rear drag slicks have a white line colored in on the sidewall. Does this measure/do anything, or is it just how the tire is made?
I'm talkign about the thicker line which runs from the rim to the end of the sidewall.
Thanks in advance,
Steve
jetfan2207 is offline   Reply With Quote
Old 10-29-2008, 07:21 PM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
The one all the way around the edge of the tire is there to check the contact patch of the tire. Where it wears off will tell you how much of the tire is making contact with the track.
The one from the rim to edge of the tread is to make it easier to spot wheel spin. When they watch the replays of the run, it's easier to see the white mark turning.
Old 10-29-2008, 07:31 PM   #3
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
eBay racing edition!
The line on the tire is one tool that tells the pit crew or driver whether the tire is gripping the track properly. It's typically chalk that they rub on the tire before a pass. They can see how far down the sidewall the chalk is worn off to see if they need to add more air, and the line also is an indicator of how fast the tire is spinning. If the line is going around faster than the car is moving, then you have some grip problems, and a power, clutch, suspension, or tire adjustment is needed. This isn't the only way they determine this either. Pro drag race teams use all kinds of data logging and video recording to improve future passes.
IMPREZive 02 WRX is offline   Reply With Quote
Old 11-02-2008, 09:52 PM   #4
hkerekes
Member#: 66310
2015 korean muscle
As stated before its to see if the tire is slipping on the rim. Then run low air pressures, usually in the 9 - 12 psi range.
Most of the time they drill the rims and put screws in the tires so the chalk is kind of pointless then.
hkerekes is offline   Reply With Quote
Old 11-03-2008, 06:32 AM   #5
Silver_Bell_WRX
Member#: 7677
2005 WRX
I dont drag race but I have and do run drag tires on one of my vehicles. I can say that 9-12 psi is on the high side for some drag tires since 20psi is the max inflation. I ran 5psi in a set of MT sportsman pros for 2 years without any trouble. Most of the time tubes are run in the tire a long with a bead lock rim to prevent spinning on the rim. I didnt run tubes in mine but never fully heated the tires up either as I blew the rear end out of the truck with a quick shift.
Silver_Bell_WRX is offline   Reply With Quote
My 1/4 mile times and few questions rstlss Proven Power Bragging 1 04-17-2006 12:43 PM
Guaging Interest: 1/4 mile drag with On-Site Tuning Shop nomadtw Off-Topic 11 10-24-2003 01:45 AM
Ennis Saturday February 8th 1/4 mile Drag Racing AWDball Texas Impreza Club Forum -- TXIC 9 02-08-2003 11:50 AM
No more drags at PIR until April... any other 1/4 mile track nearby Portland? Ichiro North West Impreza Club Forum -- NWIC 2 10-21-2002 09:05 PM
Tyler/CNN/1/4 mile drag race Darryl Southern California Impreza Club Forum -- SCIC 11 09-12-2001 12:42 AM
