Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 10-29-2008, 10:32 PM   #1
DjKlown
Member#: 167104
Default 2.0 to 2.5L with blown 2.0 ecu????? AUTO
ok here is the lay down.
04 wrx auto with Utec. has blown B84 24 connector/internal (BCS), im doing the 2.5 hybrid setup(with all supporting mods), so i need a new stock ECU.( i beleive) i get 6.45 Volts coming out of the ECU and something over 10 V coming out of the piggy back.( i will re test over the weekend to confirm). so over 10V is good according to ALLDATA. to do the hybrid do i need to get a new UTEC that is meant for 2.5L or can i keep the UTEC i have now, and there is a setting in there to change displacement?
AUTOMATIC TRANS
so here the questions lazy ones....
1. do i need to change UTEC to a 2.5 L one or can i keep it and change a setting?
2. does the UTEC up the voltage for certain drivers? BCS specific...
3.could the piggyback been damaged at all from this bad connector...?
4. ANy other INFO be great...
Thanks
Mike
DjKlown is offline   Reply With Quote
Old 11-20-2008, 07:58 PM   #2
DjKlown
Member#: 167104
Update: Everything keeps checking out ok. all connectors(2) are all good.= blown ecu...
am able to go to 2.5l setting in the software.
any other info folks...
mike
o snap!! heads up to you guys with turbo 2.5's kumanchu Mid Atlantic Impreza Club -- MAIC 19 04-08-2008 11:15 AM
Newbie to this site with Stg 2 07 Sti Rollin07Sti Newbies & FAQs 7 10-07-2007 01:09 AM
Ok to run vf39 with stage 2 map? swiftwrx06 AccessPort 7 01-04-2007 01:07 PM
Where to find STI with blown motor? rebos123 Newbies & FAQs 9 05-02-2006 06:58 PM
what is the difference between a 2.5rs and the ts with the 2.2 engine for the gc8 bebeGDB Subaru Conversions 8 01-26-2004 10:08 AM
