Old 10-29-2008, 11:54 PM   #1
silentt
Member#: 119995
2004 Outback XT
Peachy
Default Heater core doesn't turn on after swap?
Hey guys,
I most likely just missed plugging this in (dash isn't in yet though) but my HVAC system doesn't turn on now that I have swapped. Am I forgetting to plug something in? Which plug would be involved with this? I double checked last night and plugged in the brown plug on the bottom of the black unit (passenger side) and plugged in the white plug on the top of the unit. Am I missing anything else?
99 RS body/interior, mechanically 07 STI.
silentt is offline   Reply With Quote
Old 10-30-2008, 12:37 AM   #2
sidewayz
Member#: 5810
2001 S366 2.5RS
did you plug in the heater controls?
sidewayz is offline   Reply With Quote
Old 10-30-2008, 01:42 AM   #3
silentt
Member#: 119995
2004 Outback XT
Peachy
Yeah, sorry.. I guess that leaving out that bit of information would lead everyone to think I'm retarded. Yes, the controls are plugged in.
Old 10-30-2008, 07:13 AM   #4
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
When you say 'doesn't turn on' do you mean the blower motor doesn't come on? the a/c switch doesn't light up? the cluster backlighting doesn't work?
If it's just the blower motor, check the blower motor relay, blower motor resistor and the fuses.
Dan Cech is offline   Reply With Quote
Old 10-30-2008, 11:46 AM   #5
silentt
Member#: 119995
2004 Outback XT
Peachy
Sorry, it's just the blower motor doesn't turn on. I turn on the AC and my rad fans start spinning (don't have my AC system running yet, just needs a tensioner and a belt) and it lights up. Where is the relay and resistor for the blower motor?
There should be no wiring for this in the swap, right? I did the wiring so long ago (trouble-free too! ) that I can't remember what was done.
Old 10-30-2008, 06:43 PM   #6
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
The blower motor resistor plug should be on the center part of the HVAC unit if I recall correctly, it'll be a 4-pin plug. If the fan comes on when you turn the blower switch to max then you don't have the resistor plugged in.
If it doesn't come on at all then most likely it's the blower motor relay or a fuse.
Old 10-30-2008, 08:51 PM   #7
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
check your fuses and if necessary start pulling the passenger side dash apart to make sure things are plugged in
elislider is offline   Reply With Quote
Old 10-30-2008, 11:13 PM   #8
silentt
Member#: 119995
2004 Outback XT
Peachy
Alright, I'll start to hunt down the relay and fuse. Thanks.
What/where are the plugs on that? I have 2 or 3 things plugged in to there right now, can't remember off hand.
Old 11-03-2008, 03:39 AM   #9
silentt
Member#: 119995
2004 Outback XT
Peachy
Problem solved :roll: The relay wasn't plugged in all the way. It tapped it, it clicked into place and the HVAC worked again.
Old 11-03-2008, 07:27 AM   #10
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
good to hear it was something simple!
New amp will not turn on after swap... DreddRS25 Car Audio, Video & Security 8 06-29-2005 07:24 PM
passenger side HID doesn't turn on? ASpec818 Electrical & Lighting 10 05-11-2005 06:59 PM
Heater fan won't turn on Marquis Service & Maintenance 19 04-07-2005 03:05 PM
Help: Installed Alpine 9827 and now amp doesn't turn on kitbar Car Audio, Video & Security 10 07-30-2004 01:31 PM
Stock Stereo doesn't turn on. silverwagon Car Audio, Video & Security 2 09-09-2002 02:08 PM
