Old 10-30-2008, 01:07 AM   #1
00boostedRS
Member#: 115317
1992 Legacy SS
Default Twin turbo EJ20 heads on a ej22t
from what Ive heard the twin turbo heads flow really well and I was just curious how much harness modding is needed to make these heads work? Also you have to use a different intake manifold to right?
00boostedRS is offline   Reply With Quote
Old 10-30-2008, 08:30 AM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
What kind of harness modding? You own a 2.5RS. Are you putting these heads into an old Legacy Turbo? If not, you're asking in the wrong forum and should be looking for answers and ideas down in the AFI forum. Reddevil's supercharged my car today would be a good place to start. He uses those heads.
The short answer is legos. The things mechanical are like legos. The things electrical need to stick to what the car thinks. With a 2.5RS you will need to figure out a way to not only make your wiring harness work but to get your TB and related sensors mounted to the Ej20H intake manifold. The challenge will be the IAC.
Old 10-30-2008, 07:57 PM   #3
00boostedRS
Member#: 115317
1992 Legacy SS
i think one of the heads on my ss might be cracked so im thinking i might see if i can find some 20R heads and just install those because they flow really well. I just wondered what kinda harness modding is involved with this. Im not actually doing the harness modding on my RS, I dont have the time or the electronic background to have the confidence to achieve it. Im waiting on a Link G4
Old 10-30-2008, 10:54 PM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
If they are going on a 91-94 ss, then its plug and play.
Old 10-30-2008, 11:00 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
Ed Zachary. Put your intake manifold harness on the EJ20 manifold. If you can get an Ej25D manifold, then it's really easy because you can bolt your coil pack to the manifold, but any early Ej20 manifold will work with those heads.
Old 10-30-2008, 11:28 PM   #6
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I am also running a 19??/200? 2.5 intake on some twin turbo heads. Working fine. This in one of the intake manifolds that has the mounting bolts inline.
Old 11-01-2008, 04:42 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
That's the 1996-1999 DOHC Ej25 manifold. None of the SOHC Ej22 or SOHC EJ25 manifolds will work with those heads.
Old 11-01-2008, 05:24 PM   #8
00boostedRS
Member#: 115317
1992 Legacy SS
sweet I didnt know the twin turbo heads were plug and play. I just know the 22t heads dont flow very well and are known for having cracking issues. so basically i just need to find some dohc heads off an outback of 96-99 year range and they'll bolt right up? Also will the Perfect Power SMT6 work with those heads? What is the CC rating of the SS injectors?
Old 11-01-2008, 05:31 PM   #9
dropdfocus
Member#: 89756
1992 Legacy Sport
1997 Impreza L sedan
The JDM greys are 440cc on the early WRX EJ20 intakes.
dropdfocus is offline   Reply With Quote
EJ20 heads on an EJ22t block? sheepdog Built Motor Discussion 3 08-04-2008 08:31 PM
Question on a Legacy twin turbo EJ20 engine???? AXA Legacy Forum 6 10-19-2005 12:25 PM
Question on a twin turbo EJ20 engine???? AXA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-23-2004 08:59 AM
Twin Turbo EJ20 on E-bay! is2scooby Hawaii Impreza Club Forum -- HIIC 28 06-21-2002 07:04 PM
Twin turbo ej20 on e-bay il96 Normally Aspirated with bolt-on Forced Induction Powertrain 1 05-04-2002 01:14 AM
