Old 10-30-2008, 03:05 PM   #1
Hoak
Member#: 176182
1997 Legacy
Default Crank options
I snapped the pully bolt off in the crank of my EJ22T. I was wondering if I have different options on what to replace it with and what the benifits would be. I haven't looked too hard yet for any sort of aftermarket crank, I was thinking more OEM upgrades from different motors. Also, if thats not an option, I need to know if the EJ22 crank is the same as the turbo blocks crank. Thanks in advance!
Hoak is offline   Reply With Quote
Old 10-30-2008, 04:05 PM   #2
bobjr94
Member#: 6176
85 Brat,95 Impreza
05 Baja- Blue,Red& Purple
You might be able to drill the bolt out, get an extractor in it and unscrew it still. Depends on how stuck it is. Might need a right angle drill and to pull the rad but still beats buying a motor.
Depends on how much HP you plan on making and how much you want to spend. If your doing a reasonable amount of HP and dont have boat loads of money I would just get a ej18 or ej22 core for pretty cheap and use the crank. I believe everything phase 1 (90-98) would work fine.
bobjr94 is offline   Reply With Quote
Old 10-30-2008, 08:54 PM   #3
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
cheapest thats for sure. might be hard to get in there, youll prolly have to take off a lot of the front end or just pull the engine out at least halfway to easily get to the crank
check yards or just craigslist for a car or engine thats blown for something cheap then youll have a lot of other stuff too that you might need down the road, or stuff you can sell back
elislider is offline   Reply With Quote
Old 10-30-2008, 09:26 PM   #4
Hoak
Member#: 176182
1997 Legacy
The motor is out of the car, I have a 98 RS with an EJ22t and WRX heads, and a menniam stage III kit. I'm looking for the most benifitial upgrade. I was going to just get an old block out of this all subaru yard in town, but I wanted to be sure I could use a crank from a 1.8-2.0-2.2-2.5
Old 10-30-2008, 11:04 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
If you are looking to 'upgrade' get a phase I Ej25 crank and stroke your Ej22 up to 2.35l.
Old 10-30-2008, 11:13 PM   #6
Hoak
Member#: 176182
1997 Legacy
Would that require any sort of head spacing?
Old 10-31-2008, 06:59 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
No it requires custom internals from wiseco
Old 11-23-2008, 02:12 PM   #8
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
I thought you could swap crank and rods and call it a day, using your own pistons, do you HAVE to use the Wiseco's?
~Josh~
Old 11-24-2008, 07:48 PM   #9
charliew
Member#: 125304
On a lot of broken bolts that are flush with the surface, I've taken a slightly larger nut and laid it on top of the bolt shaft and taken a ac stick welder or a wire feed and welded the nut to the bolt shaft and it comes out pretty easy. I know for sure this works on chev sb heads and aluminium blocks but I haven't tried it on a steel crank but what do you have to loose?
With the stick welder I use the ground clamp to hold the nut in place and it works pretty easy, you just fill up the inside of the nut with maybe a small blob on top. Don't mess up the outside of the nut if you can help it but if you do just use a vise-grip on it. The bolts usually aren't very tight and maybe the heat helps to loosen them.
On one chevy head still in a k5 blazer the back exhaust manifold bolt on the pass. side had a 3/8 tap and a ezout in the same hole. Only a helicoil would fix that. I did get them out with about 5 1/2 nuts and the welder. They are neat conversation pieces.
charliew is offline   Reply With Quote
Old 12-01-2008, 06:42 PM   #10
ciper
Member#: 15543
90BJ Legacy LS ABS
Yes you have to. The stock 2.2 pistons are too "tall" for the 2.5 stroke/rods.
EJ 205 Crank Options Pavoni8297 Built Motor Discussion 15 07-19-2010 11:51 PM
I will trade my perrin crank pulley for a stock crank pulley NITROS Mid West Subaru Owners Club Forum -- MWSOC 8 07-21-2006 10:51 AM
Sti 2.5 Crank, rod and crank bearings DJIMPREZA Private 'Wanted' Classifieds 1 09-05-2005 09:19 AM
Perrin Crank Pulley Vs Unorthodox Racing Ultra S lightened underdrive crank pulley west_minist Normally Aspirated Powertrain 3 02-21-2005 11:56 PM
Pistons,Rods,Balance Crank, Crank Bearings for turbo EJ25 3BadHabbits Normally Aspirated with bolt-on Forced Induction Powertrain 14 01-10-2004 04:04 PM
Message Board Statistics All times are GMT -4. The time now is 10:39 PM.
