Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Drivetrain
Old 10-30-2008, 09:06 PM   #1
99RSTurbo
Member Sales Rating: (9)
Member#: 53459
99 Impreza
Twin Turbo'd V8
Default Subaru to GM transmission adapter plate
$350 plus shipping.
Made out of 1/2" 6061 T6 Aluminum, this will adapt any subaru motor to any GM transmission.
Here are some pics
99RSTurbo is offline   Reply With Quote
Old 10-30-2008, 09:39 PM   #2
javastiwagon24
Member Sales Rating: (18)
Member#: 144372
0407 STIwag & 01 STI
Rotated!Widebodied!RaLLY
nice going. looks really good.
javastiwagon24 is offline   Reply With Quote
Old 10-31-2008, 03:47 AM   #3
06wrxlbart
Member Sales Rating: (37)
Member#: 154013
2012 S4
Monsoon Grey
wow this is odd what kind of tranny can you run and what rear end?
06wrxlbart is offline   Reply With Quote
Old 10-31-2008, 04:52 AM   #4
99RSTurbo
Member#: 53459
99 Impreza
Twin Turbo'd V8
Any GM tranny, and whatever rearend you want. With fabrication of course.
Old 10-31-2008, 05:51 AM   #5
Dugansti
Member#: 177683
1998 JDM RHD Integra
bump for a sick sand rail setup! i would put that in my **** if i had any extra money
Dugansti is offline   Reply With Quote
Old 10-31-2008, 09:08 AM   #6
Derek King
Member Sales Rating: (2)
Member#: 131182
03 cookie
monster
pm'ed
Derek King is offline   Reply With Quote
Old 11-01-2008, 09:51 PM   #7
99RSTurbo
Member#: 53459
99 Impreza
Twin Turbo'd V8
Still available.
Old 11-02-2008, 09:45 AM   #8
sick1.8t
Member Sales Rating: (5)
Member#: 22345
2003 RSX
black
how does the input shaft from the tranny connect to the motor? what torque converter/clutch setup do you use?
sick1.8t is offline   Reply With Quote
Old 11-03-2008, 08:34 AM   #9
99RSTurbo
Member#: 53459
99 Impreza
Twin Turbo'd V8
You have to make a hub adapter. This is just the plate that will bolt the trans to the motor. Then you'll have to machine a hub adapter and starter to complete it. We just changed our plans and had no reason to finish it.
Old 11-14-2008, 09:22 AM   #10
99RSTurbo
Member#: 53459
99 Impreza
Twin Turbo'd V8
Still available
Old 11-24-2008, 05:07 PM   #11
jetfan8178
Member Sales Rating: (24)
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
So, if someone was to want to do a T56 from a camaro, what else would need to be fabricated?
jetfan8178 is offline   Reply With Quote
Old 11-25-2008, 12:08 AM   #12
99RSTurbo
Member#: 53459
99 Impreza
Twin Turbo'd V8
Hub adapter, and starter.
This plate will bolt the trans up to the motor, then you have to have a adapter hub machined, and figure out the starter setup.
Old 11-25-2008, 11:40 AM   #13
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
Im just wondering if on a manual setup I can pull it off by having a custom clutch setup made or pieceing something together to use a pressure plate for the T56, Flywheel for the subie and custom clutch disc...
Thinking out loud I guess. ill have to do more research befor ejumping on anything
Old 11-25-2008, 11:47 AM   #14
99RSTurbo
Member#: 53459
99 Impreza
Twin Turbo'd V8
Yeah, either way, this is one step closer to making it work. There are other pieces needed to complete the swap. You'll have well over $600 at least to buy the material, and have the plate machined, centered, cut, drilled, and tapped.
The clutch setup really doesn't have anything to do with it. You just need to adapt a T56 flywheel to the subaru crank bolt pattern, which would included just machining a hub. We were going to complete this, but I decided to just swap a V8 into the car instead.
Old 11-25-2008, 01:49 PM   #15
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
My goal would be to adapt the standard Subaru flywheel into the setup. this would make the starter setup alot easier to deal with.
V8 was also my first choice, LS1 would be a easy fit and the weight difference is very small compared to a turbo'ed EJ series engine. I just wanted to make it harder on myself by going EZ30 I guess LOL
Old 12-05-2008, 01:20 PM   #16
charliew
Member#: 125304
I see no way in H**L that a starter can be worked into this unless you use a very old cast iron 55 chev. manual tranny bellhousing to mount the starter.
charliew is offline   Reply With Quote
Old 12-05-2008, 01:22 PM   #17
99RSTurbo
Member#: 53459
99 Impreza
Twin Turbo'd V8
Then you aren't thinking very hard. There are several ways to make the starter work, you might have to think outside the box though. We have a couple ideas of what we were going to do, but since we decide to go with a SBC, no adapter was needed, or needed to be finished.
Old 12-22-2008, 12:08 AM   #18
99RSTurbo
Member#: 53459
99 Impreza
Twin Turbo'd V8
Still available, make offer.
Old 12-24-2008, 01:12 AM   #19
99RSTurbo
Member#: 53459
99 Impreza
Twin Turbo'd V8
Still available
Old 12-30-2008, 11:50 PM   #20
99RSTurbo
Member#: 53459
99 Impreza
Twin Turbo'd V8
Make offer
Old 01-15-2009, 11:42 PM   #21
99RSTurbo
Member#: 53459
99 Impreza
Twin Turbo'd V8
Old 03-11-2009, 08:50 PM   #22
mad1577
Member#: 95343
2000 2.5 RS
white
pm sent
mad1577 is offline   Reply With Quote
Old 03-16-2009, 12:52 PM   #23
bkotzman00
Member#: 181735
tried to pm but you are full
bkotzman00 is offline   Reply With Quote
Old 03-16-2009, 02:29 PM   #24
99RSTurbo
Member#: 53459
99 Impreza
Twin Turbo'd V8
Just cleared out my inbox, please resend.
Thanks
Old 04-01-2009, 10:38 PM   #25
99RSTurbo
Member#: 53459
99 Impreza
Twin Turbo'd V8
Still available. Make offer.
Subaru GM Bellhousing Adapter JustinOlson Drivetrain 19 03-06-2015 08:08 PM
Need an Adapter (OS Subaru to NS Chevy) Keiji22 Car Audio, Video & Security 8 06-17-2008 08:24 PM
Where to install iPod Adapter, Sirius Adapter and HD Radio Adapter?? CO2.5i Car Audio, Video & Security 13 03-05-2008 07:50 AM
Need to locate Burton 3D to 4x adapter plate QuickSilverSTi Off-Topic 0 10-11-2004 10:37 AM
What does Subaru get for selling out to GM? Rev News & Rumors 38 04-14-2003 11:26 AM
