Old 03-22-2002, 01:49 PM   #1
cool13b
Member#: 16708
1999 Legacy
Wine
Default Brakes Brakes Brakes
Alright here is the question:
I have a 1999 legacy L and it has single piston front breaks and rear disc. Now it is time to do the brakes on the car and since they suck I figured that I would upgrade. So what are my options? I have 15 inch wheels right now but I have been thinking about going to the 16 gold rs wheels (I like them for some reason) Anyway what are my options can I bolt up the GT's dual piston calpiers and stay with my 15 rims? And if they do not bolt up what do I need to get at the junkyard? I want to get better rotors so I was not going to get those from the junkyard? Also I keep reading about a big brake conversion what is the story with that? And also the 4 pot fixed calipers that I have seen??? Basically I want to know everything :-) But seriously if anybody can point me in the right direction or has any opoion's of their own I wouldlove to hear them
Thanks
99 legacy
#814 Club rally grp2 VW GTI
cool13b is offline   Reply With Quote
Old 03-22-2002, 04:58 PM   #2
Oquipah
Member#: 9689
1998 Legacy GT
Post some info..
Well, if you are thinking about going to bigger brakes (larger than stock GT brakes) you will need at least 17" rims. I had inquired about the 4 pot Subaru system and was informed that 17" min wheel size is needed.
As far as upgrading from your stock brakes to GT brakes goes...I'm sure someone else will help.
Peace,
Oqui
Oquipah is offline   Reply With Quote
Old 03-22-2002, 05:08 PM   #3
Herbie
Member#: 415
2002 WRX Wagon
2002 BMW Z3 3.0i Coupe'
Not quite. Wheel/brake fitment is the same as the Imprezas, so there are a few options:
STi 4-pots will work with 1998-2001 2.5RS wheels (16"x7"), but NOT Legacy GT or 2002+ Impreza wheels (16"x6.5"). Most 17" wheels will clear, as will a 15" RL-7 (but no other 15" we know of).
WRX 2-pot "big brake" system using WRX caliper brackets, WRX rotors, and WRX or 1998-2001 2.5RS Calipers will work with all of the OEM 16" wheels (including Legacy GT and 2002+ Impreza 16x6.5" wheels). Reportedly the RL-7 will NOT clear this caliper as its wider in "different" places than the 4-pots
I think for the Legacy GT brakes you need at least 16" wheels again.
You could check with "Neuromancer" to see what Legacy brakes he transplanted onto his "L" model Impreza but he was able to fit those under a set of OEM 5-spoke 15" wheels. I THOUGHT they were 2pot front, 1pot rear, and they were definitely an upgrade over the "L" stock system. Might not be an upgrade for a late model Legacy though. Are you SURE you have 1pot fronts? I thought by the 3rd Gen all Legacies had 2pot fronts.
Other "non-OEM" braking kits will most likely require 17" wheels for sure.
Herbie is offline   Reply With Quote
NEW AMS Brake kit, Brake bleeder. BRAKES BRAKES AND MORE BRAKES! AMS MWSOC Vendor Classifieds 10 09-10-2007 10:43 AM
NEW AMS Brake kit, Brake bleeder. BRAKES BRAKES AND MORE BRAKES! AMS Suspension/Brakes/Handling 10 08-13-2007 01:43 PM
STi Brake Pads / SS Brake Lines / Brake Fluid TicketsForMePlease Private 'Wanted' Classifieds 4 11-30-2006 10:47 AM
i need 4wd impreza with disc brake E-brake Cables. can i modify my cable? supermoose Brakes, Steering & Suspension 0 09-30-2001 09:43 PM
Brake Lines, Brake Lines, Brake Lines: Rate malaki Brakes, Steering & Suspension 0 05-03-2001 06:55 AM
Message Board Statistics All times are GMT -4. The time now is 11:02 AM.
