Old 10-31-2008, 01:16 AM   #1
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Default '05 STI with full Cosworth long block and Buschur FS635 cracks 600 on pump gas with m
This is a really well sorted full Cosworth build up we just completed
Cosworth Long Block
Cosworth Cams
Magnus Intake
P & K Fuel system
Periin Gt35 turbo kit and fmic set up
Perrin header and Perrin exhuast
Aqumist HFS 1
AEM EMS tuned by Dyno Flash
93 octane pump gas and alchy !
This dyno sheet is compared to me car which apparently spools up mush harder and pulls the same up top (but with more boost)
The Coswirth block is kept under 30 psi as the unit is not sleeved
Its amazing how well thet cosworth engine revs out - it really is smooth and revs fast.
This is the FS635 on this car vs my car with GHT86
alfriedesq is offline   Reply With Quote
Old 10-31-2008, 01:55 AM   #2
vhalin
Member#: 21445
08 STI
beastly. not bad spool for a 35r
vhalin is offline   Reply With Quote
Old 10-31-2008, 01:57 AM   #3
lethal.adv
Member#: 95652
'12 Outback 2.5i
'10 Legacy 2.5i ltd.
nice numbers and powerband!
lethal.adv is offline   Reply With Quote
Old 10-31-2008, 01:59 AM   #4
sti_777
Member#: 166793
2007 Toaster SC
Root Beer Metallic
Flipping sweet! Cosworth FTMFW!
sti_777 is offline   Reply With Quote
Old 10-31-2008, 11:24 AM   #5
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
It was interesting to note the variation between the power band of my stock intake HTA85 STI and the Magnus FS635 STI above
Remains to be seen how much the intake manifold is effecting the low end spool or if it is more a result of the turbo
Old 10-31-2008, 11:31 AM   #6
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
^^curious about this also...
How do you intend to find out definitively though?
jigga is offline   Reply With Quote
Old 10-31-2008, 11:56 AM   #7
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
You would need to do A- B testing on the same car with just changing the part you are testing
Here we are running two 05 STI's with totally different parts - hard to reach any conlcusions
Old 10-31-2008, 12:32 PM   #8
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
what is a fs365 turbo? never heard of it.
So we don't have any info on the magnus intake and if it's really worth it?
D Money is offline   Reply With Quote
Old 10-31-2008, 01:05 PM   #9
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
one of buschurs new turbos.....
FS635: fast spool and 635whp was the number they first put down with it
Old 10-31-2008, 01:09 PM   #10
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
It's pretty much a HTA86 with a smaller back housing I think witch will help condone faster spool. Work done on exhaust side of the turbine will dramatically improve spool over the compressor side. Both would be dominate!
Al talk to your customer and see if you could barrow his turbo for a pull on your car and swap them out with no tuning to see some result's. That would be very interesting to see.
spoolinsti05 is offline   Reply With Quote
Old 10-31-2008, 02:33 PM   #11
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Video of the Cosworth car and some video of my STI on the road
http://www.youtube.com/watch?v=NF-T7Gnq3lY
Old 10-31-2008, 03:08 PM   #12
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
wow looks like 300ft/lbs under 4k rpm and it's just starting to turn on. That is no joke! That powerband would make for an incredible street car.
I thought the perrin headers get a little restrictive at these power levels?
Steve.804 is offline   Reply With Quote
Old 10-31-2008, 03:16 PM   #13
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
We want to remove the Perrin headers for sure - too many things to do too little time !
Old 10-31-2008, 03:28 PM   #14
sean18337
Member#: 135588
2007 STI *SOLD*
Which headers are you going to put on?
sean18337 is offline   Reply With Quote
Old 10-31-2008, 04:01 PM   #15
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
I like the Agency Power 4 - 1 units - they are very reaonably priced and mine never cracked
Old 10-31-2008, 04:23 PM   #16
Pops
Member#: 80412
nice numbers
Pops is offline   Reply With Quote
Old 10-31-2008, 04:54 PM   #17
wuuusaa
Member#: 92894
2015 Wrx
Why did he choose the magnus intake manifold? Aren't they junk? as far as the welds and build quality?
Old 10-31-2008, 06:03 PM   #18
garboplateNY88
Member#: 134113
05 LEGACYGT
247hp 300tq retuned STM
Post
"The Coswirth block is kept under 30 psi as the unit is not sleeved"
Isn't that to much psi for non sleeved block it can cause bore distortion at that power level?
garboplateNY88 is offline   Reply With Quote
Old 10-31-2008, 06:19 PM   #19
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
This customer selected many of his parts
While fittament on the Magnus is tough, our master Ferrari tech ported, adjusted and modified it to a perfect fit.
There is no doubt in my mind that the Magnus intake does make significant top end power
NOTE * We have our pre-orders in for the new Cosworth cast manifold which is said to make only top end power power and not loose any low end power. I am sure that anythng from Cosworth is made perfect (except the cams LOL)
Al
Old 10-31-2008, 06:25 PM   #20
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Personally, I would not build a Subaru motor without sleeves
This block was the customer's choice before he came to us and it has lasted a long time with his previous set ups including the FP Green and Gt35 in previous trims.
After lots of discussion of risk vs power the customer has elected to stay at 28 psi as a daily driver
If the block distorts then we'll take it out and add the Darton Sleeves
I pushed my stock block to 39 psi before the bores started to slightly oval
Al
Old 10-31-2008, 06:26 PM   #21
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
I just wanted to add that after 7 1/2 years tuning and modifying Subarus I am just as excited as ever and very optomistic about the new large billet wheel Gt35's and the new stand alones
Subaru FTW !
Old 10-31-2008, 06:30 PM   #22
garboplateNY88
Member#: 134113
05 LEGACYGT
Post
"If the block distorts then we'll take it out and add the Darton Sleeves"
How you know if that happens you can't see inside the block?
Old 10-31-2008, 06:33 PM   #23
AVCSKIDD
Member#: 179372
I never understand why people limit boost on stock sleeves the boost doesn't even matter. Its cylinder pressure which is more of a function of Horsepower than it is boost level.
Either way those are good numbers guys, what were the numbers on straight pump gas.
AVCSKIDD is offline   Reply With Quote
Old 10-31-2008, 07:01 PM   #24
norexyet
Member#: 39149
11 elantra
yea i said elantra
good numbers al. Thats a noisy motor though.
norexyet is online now   Reply With Quote
Old 10-31-2008, 07:51 PM   #25
Redline927
Member#: 77622
Sleeve it and see what it can really do!
Any track time in the future with this thing? looks like an animal.
Redline927 is offline   Reply With Quote
feeler thread: fs cosworth long block and much more, or take the whole car!! silverwerx MAIC Private Classifieds 19 04-11-2010 10:56 AM
feeler thread: fs cosworth long block and much more. or take the whole car silverwerx Private Vehicle 'For Sale' Classifieds 5 04-03-2010 07:21 PM
'05 STI with FP Green - massive 515 TQ with Aquamist on Pump Gas ! Dyno Flash Proven Power Bragging 351 02-02-2008 08:02 AM
Daily driven FP Green STi... 11.9 on pump gas at full weight x99percent Proven Power Bragging 56 05-04-2006 06:36 AM
Buschur Racing goes 12.96 at 106 mph on pump gas... David Buschur Proven Power Bragging 25 11-12-2003 06:20 PM
