Old 10-31-2008, 10:11 PM   #1
front runner
Member#: 121603
2001 legacy BH
blue
Default 450cc inj max?
Off the top of your heads, does anyone know how moch power you can put down before maxing them out? I currently have dsm450cc peak and holds, phaseII block and heads. They are fine right now(8psi w/ 10:1 comp.) But I am building a new shortblock with Sti internals. Anyone have experience?
front runner is offline   Reply With Quote
Old 11-01-2008, 03:13 PM   #2
Soef
Member#: 184648
1999 Impreza GTT
450cc will get you safe to approx. 320/330 bhp. That is if your fuelpressure is right.... If you use a wideband you will see until wenn your afr is good enough.
Soef is offline   Reply With Quote
Old 11-02-2008, 12:24 PM   #3
VIsubi
Member#: 187834
06 2.5i impreza
Red
u say phase II block and heads so I'm assume its an STI block or is this still an N/A block..bump on this thread...I need to know if an sti block will bolt up to our heads or more readily 05+ heads.
VIsubi is offline   Reply With Quote
FS - (CNJ) PE 850cc Inj, Stock STi Inj, TGVs, Walbro 255, Perrin Intake + more! PartySTi Engine/Power/Exhaust 33 08-23-2009 02:00 PM
FS (CA): BNIB PE 450CC Injectors sidefeed asdad Engine/Power/Exhaust 3 07-28-2009 08:14 PM
750cc RC Racing inj. & 1260 Ultimate Racing inj. BallzToTheWallz Engine/Power/Exhaust 35 11-10-2008 11:12 AM
Keep the STi inj or use my UR 785 inj on my JDM Engine? Need4Boost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 11-03-2003 01:01 PM
headlights? max style max light itsallgookx51 Interior & Exterior Modification 1 02-21-2002 02:03 PM
