Old 11-01-2008, 10:16 PM   #1
boxer4power
Member#: 163545
2002 impreza 2.5ts
Green
Default 02 2.5l rough idle sputters...
so i noticed it first while i was coming home one night up this big mountain. the motor or something else would cut out for a second every time i would ease up on the gas a little. also when the car is at idle and i give it some gas it hesitates, sputters for a second and then revs up. once its up in the RPM's it runs ok. Sometimes it kinda cuts out when i shift but rarely. Today i was on my way up the mountain and the car barley made it. I had no power and had to stop the car and take off again keeping the revs up just to have a little power. I can't figure out what's causing it. any of you guys had a similar problem? thanks
boxer4power is offline   Reply With Quote
Old 11-02-2008, 01:44 AM   #2
warpspeedwrx
Member#: 36318
2002 wrx
sold :(
are you up to date with your maintenance? if not i would start with a tune up . spark plugs , fuel filter etc and go from there
warpspeedwrx is offline   Reply With Quote
Old 11-02-2008, 10:37 AM   #3
soulhassorrow
Member#: 150732
2011 WRXXXX
LRP
yea sounds like you need a tune-up!!!unless you already did one, it could be your throttle position sensor!!!
soulhassorrow is offline   Reply With Quote
Old 11-02-2008, 07:27 PM   #4
boxer4power
Member#: 163545
2002 impreza 2.5ts
Green
yeah thats what i figured it probably is. I replaced the fuel filter not that long ago... couldve just been a bad tank of gas or something. ill start with that.
Old 11-04-2008, 11:18 AM   #5
bobko
Member#: 64646
1995 Legacy wagon
Green
A leaky vacuum line will cause the engine to run rough at idle and can cause the engine to stall. Check all the rubber vacuum lines to see if there is a leak. With the engine running, flex the hoses and listen for hissing air. The fix can be as cheap as a new $1 length of hose.
Good luck!
--Bob
bobko is offline   Reply With Quote
Old 11-04-2008, 09:04 PM   #6
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
If you still have problems after the tune-up I would suspect the A/F sensor. I'd hook it up to a scan tool and check the Short term and long term fuel trims. If either is +/- 10% or more then thats probably going to be the calpret. There is also a reprogram for some 02's, you would have to go to a dealership to check if it applies to your car.
Burnout is offline   Reply With Quote
1995 2.2 liter rough idle and an occasional stall stevefazek Normally Aspirated Powertrain 2 09-20-2009 11:16 PM
2.5L Hybrid Idle Problem cn4m Built Motor Discussion 4 05-03-2009 10:37 AM
'99 RS 2.5L - Erratic Idle, CEL code P0106 ?? w chapman Service & Maintenance 0 06-04-2006 08:35 PM
99-02 2.5L Service Information OKRS25 Alaskan Impreza Club Forum -- AKIC 2 02-25-2004 02:42 PM
00-02 2.5L ecu recall? inpreza kid Canada Region Forum 7 10-30-2002 11:19 AM
