Old 11-02-2008, 11:09 AM   #1
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
Default Junior Tuned 06STI with FP20G
I finally got my car tuned by one of the best tuners i have come across. I want to give credit to Junior and Jimmy @ THE SHOP CT for doing a good job on my car yesterday. The car was in the dyno for about an hour. Final numbers were 360whp and 360wtq on 93 octane. I will like to post the graphs but don't know how to. The car runs like never before. It idles perfect and runs through the gear with ease. Car hits 22.5psi at 3400rpm and it tapers to 19psi. The list of mods is the following:
-FP TD06 20G with 8cm exhaust housing
-PE 850cc injectors
-Ebay TMIC
-APS 65mm CAI
-APS EL Headers
-APS 3" TBE catless
-SAMCO Inlet
-Hallman Manual boost controller
-Walboro fuel pump
-one step colder ngk iridium plugs
The tune is very conservative. I think we could of gotten higher numbers but i wanted a safe tune. I'm going to install the SMC methanol kit in the spring to make some more power safely.
ADDED
wil06STI is offline   Reply With Quote
Old 11-02-2008, 11:38 AM   #2
i50caL
Member#: 94899
91 GTR, 75 S30Z,
97 STI, EVO X?
Good numbers
i50caL is offline   Reply With Quote
Old 11-02-2008, 11:49 AM   #3
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Great #'s!!!
I cant wait, once im done putting my 2.5 hybrid in. Ill be driving down so Junior can tune her up...
rexworx is offline   Reply With Quote
Old 11-02-2008, 12:02 PM   #4
bulgarianfreak55
Member#: 135691
2004 Subaru WRX STi
333 WHP, 325 WTQ AGILE!
good numbers, my future set up with an EWG
bulgarianfreak55 is offline   Reply With Quote
Old 11-02-2008, 02:25 PM   #5
Ultimateone
Member#: 48025
15 Mustang GT
Great job on pump!
Ultimateone is offline   Reply With Quote
Old 11-02-2008, 02:45 PM   #6
CVR STi
Member#: 127428
Your a smart man for going to JR , post up some vids
CVR STi is offline   Reply With Quote
Old 11-02-2008, 03:19 PM   #7
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Nice. This is what STi's were made for. This is what the 2010 STi needs!
Dave D. is offline   Reply With Quote
Old 11-02-2008, 03:22 PM   #8
toutanje
Member#: 153465
2004 Suzuki GSXR 600
WRX now FS!
Congrats, hope you enjoy the new setup! Also how do you like having that EL header on?
toutanje is offline   Reply With Quote
Old 11-02-2008, 06:10 PM   #9
team trucha racing
Member#: 118484
04 sti RotatedGT35
wrb harman motive tunned
what kind of dyno was this on? i have an 04 sti similar set up but with external wastegate setup. the car was tuned by dan @ harman motive on their mustang dyno and made 300awhp and 357awtq on 91 oct. at 19psi and 323 awhp and 409 awtq on 110 oct. @ 24psi.
mods are-
fp20g 8cm
pe 850 cc injectors
wlabro fuel pump
harman big maf cai
blitz nur spec cbe
titek catless d/p
perrin el header
turbo xs up- tial 44mm ewg
perrin inlet
ngk one step colder plugs
stock top mount
team trucha racing is offline   Reply With Quote
Old 11-02-2008, 06:41 PM   #10
Blacksails192
Member#: 142686
back to european
i believe the shop has a dyno dynamics
Blacksails192 is offline   Reply With Quote
Old 11-02-2008, 07:15 PM   #11
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Thanks for the kind words and enjoy the car. Very clean car! If you pm me your vin I can post the graph for you.
Junior2JZ is offline   Reply With Quote
Old 11-02-2008, 07:19 PM   #12
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
mods are-
fp20g 8cm
pe 850 cc injectors
wlabro fuel pump
harman big maf cai
blitz nur spec cbe
titek catless d/p
perrin el header
perrin inlet
stock top mount
DynoDynamic
Judging by your TQ numbers I bet that stock TMIC was killing you power up top. That and 91 octane. This car was on 93 and had an upgraded TMIC. No heat soak.
Old 11-02-2008, 08:05 PM   #13
wRxbeater11
Member#: 12682
Congrats on the car dude, I bet that car feels awesome.
Melo
wRxbeater11 is offline   Reply With Quote
Old 11-02-2008, 08:51 PM   #14
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
Default Thanks guys!!
Junior the VIN# is JF1GD70686L512599. The car is fun to drive a lot of fun actually. I will be turning the boost down a bit because I got a High input MAF voltage cell on a 4th gear pull earlier tonight. On Romraider I'm logging 23 psi. Junior let me know if i should increase my g/s for those voltages or what needs to be done to avoid that cell.
Old 11-02-2008, 09:02 PM   #15
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
toutanje "Congrats, hope you enjoy the new setup! Also how do you like having that EL header on?"
I like the EL Headers a lot. It takes away the boxer rumble but i think it helps the turbo spool a lot. 22.5 psi by 3400 rpm is pretty good. The only problem is avoiding the APS EL from cracking. Already cracked twice before but i guess the last welder added enough weld material to avoid them from cracking again.
Old 11-02-2008, 09:38 PM   #16
team trucha racing
Member#: 118484
04 sti RotatedGT35
Originally Posted by Junior2JZ View Post
DynoDynamic
not so much killing it up top but i was happy with the way it turned out car feels super good. but im now changing my setup this week. going rotated with a custom harman motive gt28rs kit perrin fmic perrin injectors etc.. and going back to iwg. so we'll see how that turns out, i know im probably going to go with a 30r or 35r soon after. but thats the good thing about going roatated i can always just upgrade the turbo and it's so much easier to work on the car.
Old 11-03-2008, 04:58 PM   #17
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
First, you're probably maxing the romraider Man Rel Press reading. Try logging Man Abs Press instead and do MAP-ATM = MRP. Just get the atmospheric pressure from romraider before or after you do the run.
I have the AEM MAP sensor in my WRX and it still pegs the MRP in romraider, this is just a limitation in romraider and really doesnt have anything to do with the sensors. However the MAP reading works like its supposed to.
Regarding the MAF CEL. You cant simply just raise the MAF, that will just cause you to run richer.
You can trick the ECU to read lower by changing the injector scalar and the MAF.
IMO, the best solution is to upgrade to the 70mm. Not a very expensive deal...you should be able to sell your 65mm for a good amount. Then you wont have to play any tricks and you will have room for a race gas tune.
Old 11-03-2008, 06:16 PM   #18
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
Default WHP and WTQ Curves
graph was moved to the 1st post
Old 11-03-2008, 06:16 PM   #19
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
Default AFR and Boost Curves
graph was moved to the 1st posty
Old 11-04-2008, 09:01 PM   #20
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
Default ///
to the top!!!!!
Old 11-05-2008, 03:29 PM   #21
PerformanceAutoSolutions
Member#: 853
2011 STI Sedan
Satin White Pearl
junior ftw!!
PerformanceAutoSolutions is offline   Reply With Quote
Old 11-06-2008, 02:50 PM   #22
zakSti
Member#: 118551
2007 SOLD
White Satin Pearl
Junior is the MAN!! he tuned my 07 ST with a GT35R. couldnt be happier!
zakSti is offline   Reply With Quote
Old 11-06-2008, 05:32 PM   #23
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
That's a killer looking powerband, nice job! 8cm^2 FTW!
Steve.804 is offline   Reply With Quote
Feeler: Cobb v1 accessport 06sti with 3 harman tunes sdkenny SCIC Private Classifieds 1 03-19-2009 01:48 PM
East Coast Swappers GC8 Junior Tuned.. Sr55 Junior2JZ Proven Power Bragging 20 01-28-2007 08:41 PM
FS: NY Junior tuned 2006 WRX w/ VF39 deblas66 Tri-State Area Private Classifieds 8 01-17-2007 09:21 AM
My old dyno reading..Junior tuned newstiturbo Proven Power Bragging 10 12-13-2006 06:37 PM
South Florida Junior tuning day at Twilight Performance VideoGameWrx South East Region Forum 3 04-28-2006 01:09 PM
