Old 11-03-2008, 09:52 AM   #1
tasteItheIvalue
Member#: 103712
2002 Impreza 2.5RS
premium silver
Question What model/year gauge clusters will work in a 02 Impreza RS?
Ive read that 05+ STI can be used with little modification, however since I have an Automatic RS I don't think the boost gauge will do me much good. I've seen plenty of clusters on e-bay from baja's, legacy's, and foresters and the plugs all look very similar. Anyone know what years are compatible?
Thanks.
tasteItheIvalue is offline   Reply With Quote
Old 11-03-2008, 10:41 AM   #2
Phreaker
Member#: 169914
2002 WRB WRX Wagon
2011 MBP Forester XT
Is yours working or is it broken?
I'm trying to figure out what you are trying to get out of the swap.
04 STI cluster fits the best as far as dirrect swap goes.
Phreaker is offline   Reply With Quote
Old 11-03-2008, 10:48 AM   #3
tasteItheIvalue
Member#: 103712
2002 Impreza 2.5RS
premium silver
Mine is broken, the only gauge that works is the engine temp. Im looking to swap entire cluster for a working one (with little modification if possible.)
Also, if anyone has one that will work please let me know.
Old 11-03-2008, 10:52 AM   #4
Phreaker
Member#: 169914
2002 WRB WRX Wagon
You should be able to direct swap any 02-03 2.5RS cluster, maybe WRX cluster as well (I'm not possitive) but there are a bunch of people who have old ones from swapping out to STI, you might want to go post in the want to buy forum looking for a direct replacement.
Old 11-03-2008, 10:58 AM   #5
tasteItheIvalue
Member#: 103712
2002 Impreza 2.5RS
premium silver
Good point, will do. Will I have any problem switching my automatic cluster to a manual cluster? I know that it wont have the 'P R N D 3 2 1' between the fuel/temp, but that doesn't bother me as long as everything else works.
Old 11-03-2008, 11:02 AM   #6
Phreaker
Member#: 169914
2002 WRB WRX Wagon
I'm not exactly sure if the pinout is the same, you could always look up the part #'s online, if you can pull your old cluster you can call a dealership and get a price quote for a new cluster.
The one thing you're going to have to worry about is: Your odometer reading is stored in your cluster itself not your ECU, you need to have a professional shop calibrate it to reflect the correct amount of miles, then they give you a cert.
Old 11-03-2008, 11:09 AM   #7
tasteItheIvalue
Member#: 103712
2002 Impreza 2.5RS
premium silver
I am aware of the mileage issue, not a big worry of mine. Just want to make sure I buy a compatible one.
There is an 06 WRX cluster in the FS forums - anyone know if its compatible?
Old 11-04-2008, 09:43 AM   #8
tasteItheIvalue
Member#: 103712
2002 Impreza 2.5RS
premium silver
Old 11-04-2008, 12:55 PM   #9
MNsuby
Member#: 186530
02 Bugeye
MBP
i want to nknow that to^
MNsuby is offline   Reply With Quote
Old 11-06-2008, 10:30 AM   #10
tasteItheIvalue
Member#: 103712
2002 Impreza 2.5RS
premium silver
I just put a cluster from an 02 wrx manual in my02 automatic RS; works perfect. Couple differences: speedometer raised from 120MPH to 140MPH, tach's redline is at a higher RPM, and there is no light between fuel and temp that tells you what gear your in. Everything else seems to work 100%
Does anyone know if an 08-10 WRX gauge cluster will go in a 02-07 WRX? 100_Percent_Juice Interior & Exterior Modification 32 04-04-2010 02:33 AM
Wtb: 02 Impreza Rs Gauge Cluster tasteItheIvalue Private 'Wanted' Classifieds 0 11-03-2008 11:01 AM
will this shift knob work in an 04 impreza RS? fastwrxdriver Newbies & FAQs 5 12-20-2006 01:06 PM
How can I tell what model years my AccessPort will work with? 6655321 Engine Management & Tuning 2 01-09-2006 07:32 PM
what year legacy's springs or struts will work with 93-01 impreza? scobaru Outback Forum 0 11-23-2004 12:25 AM
