Old 11-04-2008, 12:49 AM   #1
jdm_wrex
Member#: 191247
2001 Impreza 2.5RS
Default ej20g common problems
ok so does anybody know what problems commonly occur with the ej20g?
jdm_wrex is offline   Reply With Quote
Old 11-04-2008, 03:20 AM   #2
Rabbit042
Member#: 80685
1998 98 Forester S
Black & Gray
I'll take giggling like a school boy for $1,000 Alex.
Rabbit042 is offline   Reply With Quote
Old 11-04-2008, 09:25 AM   #3
suberdave
Member#: 101865
88 GL-10 STi
cracked coil packs.
tiny little TMIC heat soak.
IAC sticking on cold start. or something like that.
hard to find some parts.
all of witch can be fixed with ease
thats about it...
-=Suberdave=-
www.suberdave.com
suberdave is online now   Reply With Quote
Old 11-05-2008, 05:11 PM   #4
RA Limited
Member#: 171249
2009 Chaco Z1 flip
Black/Blue
one of the most common problems is not using the forum search function i think.
RA Limited is offline   Reply With Quote
Old 11-19-2008, 05:57 PM   #5
jdm_wrex
Member#: 191247
2001 Impreza 2.5RS
How Can Not Using A Forum Search Be An Actual Problem With The Motor?
Old 11-19-2008, 09:08 PM   #6
Arctic Assassian
Member#: 91875
91 legacy TD04
04 WRB/carbon fibre STI
Tread lightly... If you want information, you have to play by the rules...
Arctic Assassian is offline   Reply With Quote
Old 11-24-2008, 11:57 PM   #7
94 GT
Member#: 193676
94 legacy GT
silver (grey soon!!)
Default what kinda info getting rules are thwere???
I don't know how things work round here yet but I plan on learning how!!
cause I swapped a 20g into my 94 GT so info is gooood thanx for the help you guys have already helped me with just by reading som stuff?!>
so hopfully I can get some pics to through on here (if thats okay cause its a legacy) but this site is damm good cause some of the 4A-GE sites for my corolla did'nt help me out to much (oh well I just suck at using comps)
94 GT is offline   Reply With Quote
Old 11-25-2008, 07:39 AM   #8
subaruwrx
Member#: 1818
03 1996 Impreza Wa
Soon to be a v3 STI
subaruwrx is offline   Reply With Quote
Old 11-25-2008, 01:25 PM   #9
Chewy
Member#: 5917
95 Impreza Type L
That blueish color
Basically when trying to find info, use the search as much as you can, because most likely it is in there. I know sometimes the answers might not be clear or if you even you the corect key words to find it.
I know on club4ag they have a FAQs section. They seem pretty harsh on the newbies, but some of the questions have been answered a bunch of times. You can also go to ectoyotas.com and hachiroku.net
Good luck in your quest for more info.
Chewy is offline   Reply With Quote
Old 11-26-2008, 04:15 PM   #10
thad
Member#: 176616
1994 impreza
white
Originally Posted by subaruwrx View Post
that's hilarious.
mostly because this thread is the first result.
maybe we can stop flaming and adress the topic.
I'll go with hard to find parts as well.
especially electrical.
thad is offline   Reply With Quote
Old 11-26-2008, 08:29 PM   #11
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Originally Posted by suberdave View Post
cracked coil packs.
thats about it...
-=Suberdave=-
www.suberdave.com
AWIC eliminates the heatsoak...but that means either finding a 20G from an RS/GT or getting your hands on one. Coil packs are the only real issue, IAC has been sweet so far.
i_c_the_light is offline   Reply With Quote
Old 11-28-2008, 04:41 AM   #12
fengrr
Member#: 169160
03 WRX
Black on WRB
Originally Posted by thad View Post
that's hilarious.
lmao...
Anyways, check out this site: http://swapstarproductions.blogspot.com/
Some interesting stuff here if you look around, but you kind of have to pretend you suck at english.
I would say the hardest part is finding some parts. Some parts only work with other 20g parts. So if you blow something in the motor, you either have to find the exact hard to find part, or you have to replace more than just one thing, and it kind of sucks.
fengrr is offline   Reply With Quote
Old 12-28-2008, 08:31 PM   #13
thad
Member#: 176616
1994 impreza
white
OK I'll admit the coils can be problematic,
time for me to jump on the coil conversion bandwagon
EJ20G Compression ratio/common problems WRX_RA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-03-2007 10:18 PM
Common problem with steering on STi's? Zoso STi Forum Archive 44 07-30-2003 10:52 PM
WRX's most common problem .... way to remedy it? WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 03-05-2003 11:34 AM
common problems in MY98 2.5RS? dalesd Normally Aspirated Powertrain 4 06-01-2002 11:21 PM
