Old 11-04-2008, 09:06 AM   #1
MarylandWRX
Member#: 186720
2002 Subaru WRX
Default i have an A/F gauge on its way to me.
but what i hear from people around me is that for some reason it wont work on my 2002 WRX. (Its The Auto Meter Ultra Lite Boost Gauge, and Auto Meter Ultra Lite A/F Gauge)
MarylandWRX is offline   Reply With Quote
Old 11-04-2008, 09:20 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
it is useless
you need a true wideband o2 sensor....the wrx uses a narrowband sensor
so you will need a different input than the stock o2 sensor
there are several ways to do this and none are cheap
PLXDevices
Innovate
AEM
Search for it
Old 11-04-2008, 10:10 AM   #3
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
If it isn't a 1-wire O2 sensor, I was under the impression that it is a wide-band.
indytruckboy is offline   Reply With Quote
Old 11-04-2008, 10:45 AM   #4
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
The way that subaru uses its sensors is called narrowband because they limit the operation of the sensor. I believe the sensor is actually capable of reading as a wideband if its location is changed and you use special software to configure and read it.
BUT, for all intensive purposes, the stock sensor should be considered narrowband and should not be considered a replacement for a wideband. (basically, its useless to have a gauge on this sensor)
gto7419 is offline   Reply With Quote
Old 11-04-2008, 12:07 PM   #5
MarylandWRX
Member#: 186720
2002 Subaru WRX
ok so well i got the gauges for 30 bucks shipped (cuz guy had no use for them) so ill keep the boost and sell the A/F one to a friend.
Old 11-04-2008, 12:47 PM   #6
gto7419
Member#: 44256
05 outback xt
lol - thats what good friends are for!!! hehe...
Old 11-04-2008, 01:49 PM   #7
MarylandWRX
Member#: 186720
2002 Subaru WRX
haha, yea, so when i get this gauge, anyone on here want first dibs on it, if my friends dont want it?
Old 11-04-2008, 02:22 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
paperweight
Old 11-04-2008, 02:26 PM   #9
smurfwrx
Member#: 151928
09 Triumph S3
Innovative LC-1. Check it out. That's the one I decided on. Josh at Importimageracing.com usually has some good prices.
smurfwrx is offline   Reply With Quote
Old 11-04-2008, 05:05 PM   #10
efjellanger
Member#: 64152
Midnight Blue
Narrowband and wideband sensors are of totally different construction. Narrowband sensors are constructed so that they swap from very low output to very high output at a specific AFR. They don't tell you actual AFR, just "rich" and "lean". The ECU tunes the AFR by intentionally causing the tune to oscillate between too rich and too lean, and watching the response from the sensor. More info.
Wideband sensors have an output corresponding to a real AFR value.
"intensive purposes"... read these two words and ask yourself what they mean. Then ask yourself if they make sense to use this way.
efjellanger is offline   Reply With Quote
Old 11-04-2008, 05:59 PM   #11
gto7419
Member#: 44256
05 outback xt
Actually, there was an interesting thread on romraider where someone used a stock subaru o2 sensor (post turbo) as a wideband and it functioned relatively well...
Old 11-04-2008, 07:15 PM   #12
efjellanger
Member#: 64152
Midnight Blue
Interesting. Do you have a link?
Old 11-04-2008, 08:59 PM   #13
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
Well, as long as you are pulling the signal before the cat(s), you should be fine. No matter what the ECU uses, it's still a wideband. Downstream would be affected by the cat(s), so that one would not give you a proper signal.
***This is all my 14 years of prof. tech. work talking. And it's my opinion. Use it if you want, or don't. I don't care. I have a A/F gauge coming and I am pulling it off the upstream. Besides. It's a freakin gauge. The ECU is using the same signal to keep itself stoicheometric. If I was making a 400whp F4, I would use a couple of EGT probes.
Old 11-04-2008, 09:12 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
lemme guess
you are new to subarus
you'll blow up a couple before you get it right, if you are lucky
and GL using the front o2 for any kind of usefull AF......oh yeah
if you splice the front o2 wiring....do a REAL good job of it cuz borking THAT will blow these up REAL quick and oh yeah....
Old 11-04-2008, 09:31 PM   #15
gto7419
Member#: 44256
05 outback xt
^^^ +1 - I wouldnt use the stock o2 sensor as a wideband - Im just saying its been done. Just for clarification, even a wideband will not reliably function in the stock o2 location...
Im trying to find that link btw...
Old 11-04-2008, 09:34 PM   #16
gto7419
Member#: 44256
05 outback xt
For your viewing pleasure - I never read BOTH threads (one is linked to the other), but it appears that the stock sensor is accurate until about 11:1
http://www.romraider.com/forum/topic3979.html
Old 11-05-2008, 09:33 PM   #17
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
Originally Posted by Uncle Scotty View Post
lemme guess
pics of my bugeye, on its way to being finished for auto-X rockyhirak Member's Car Gallery 5 03-30-2008 03:56 PM
I had an R8 in front of me on my way to work today 24 Off-Topic 32 12-14-2007 04:54 PM
Bottom end on its way heads may be shoot tell me what you think perrin247 Built Motor Discussion 15 08-15-2007 05:17 PM
COBBaccessECU on its way...anyone have 411? SleepyRex North West Impreza Club Forum -- NWIC 9 03-29-2004 05:49 AM
Gauge bezel on its way from Autometer GM991 Interior & Exterior Modification 3 02-01-2002 10:51 AM
