Old 11-04-2008, 01:11 PM   #1
bObby
Member#: 66959
04 STi and E46
M3
Default How do you adjust rear camber?
Just as the title reads. How do you go about doing that? I want to run a little bit more negative camber.
bobby
bObby is offline   Reply With Quote
Old 11-04-2008, 01:33 PM   #2
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
lower it or get a camber kit from Napa.
Kawikid20o2 is offline   Reply With Quote
Old 11-04-2008, 01:55 PM   #3
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
Is there a reason why you want to do this to the rear?
You will have to do a little customizing with what you have, or buy smaller dia. camber bolts.
Slotting the upper strut mount and using a front camber bolt in there, rather just a regular bolt would also work.
runninstrong is offline   Reply With Quote
Old 11-04-2008, 05:34 PM   #4
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
the napa kit is like 40 bucks
Old 11-05-2008, 09:36 PM   #5
bObby
Member#: 66959
04 STi and E46
M3
Im putting on 18x9 +35 wheels on the car and need to run like -2 in the rear. Im using Tein Flex coilovers so the fronts are no problem
how do you adjust camber after new install ? si12j12 Brakes, Steering & Suspension 1 01-01-2007 09:43 PM
How do you adjust rear wing? Lightning Jack Newbies & FAQs 3 06-16-2002 04:53 PM
How do you adjust adjustable sways? JNaubur Brakes, Steering & Suspension 7 09-06-2001 06:38 PM
('93-'01) How do you adjust the hand brake? 2yLiTe Impreza Forum 3 06-11-2001 06:50 AM
how do you adjust fog angle? popnGEAR Vancouver Impreza Club Forum -- VIC 2 05-13-2001 03:40 PM
