Old 11-04-2008, 10:02 PM   #1
91turbosedaan
Member#: 135144
1991 legacy turbo
white
Cool Looking for Ej22T tork specs!!
so i have searched and cant find the tork spec's for my 92 turbo legacy's head gasket anywhere on the bbs.legacy centeral or the nasioc form, can someone please post them for me thank you guys :-)
91turbosedaan is offline   Reply With Quote
Old 11-04-2008, 11:47 PM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
***********Reassembly of block.... semi quoted from book...
Carefully lower the right crancse section into position on the left crankcase and install the rightside bolts (the two long 12point, the two short point, and the 7(?) other bolts.. Tighten them to aproxx 14-22 ftlbs. Turn over and install the 6 12point bolts, tighten to 20 ft lbs. go back to the other side and retorque all bolts to 22 ftlbs. Then torque the 4 12point bolts to 37lbs. flip back over and tight the 6 12-point bolts to 37 lbs. then install the 10mm bolt inside and the 12mm bolt on the back where the flywheel mounts. I just hand tighten these with a open ended wrench.
Make sure to get the 4 o-rings in place (3 black and 1 orange), and use Fujibond sealant.
Cylinder head sequence. this is what I do.
Going in a diagonal motion,
tighten to 22 ftlbs.
Tighten to 51 lbs
Loosen all bolts 180 degrees
Loosen all bolts 180 degrees (yes, you do this twice)
Tighten middle bolts to 27 lbs.
Tighten outer 4 bolts to 170 in-lbs !!!!!!!!! Thats about 14 ft lbs.
tighten all bolts 90 degrees
tighten all bolts 90 degrees (yes you do this twice.
Done.
Old 11-04-2008, 11:48 PM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
PLEASE NOTE!!!! This is not quite the specification!!!!! But I have done this about 20 times with no failure.....
Old 11-05-2008, 12:54 AM   #4
91turbosedaan
Member#: 135144
1991 legacy turbo
white
Cool
thank you
Old 11-05-2008, 01:08 AM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Lube both faces of the head bolt washers
I personally replace the "tighten all bolts 90 degrees (yes you do this twice." step of head bolts to "tighten all bolts 90 degrees or 80 foot pounds, whichever is more" to prevent future leaks.
Old 11-05-2008, 01:22 AM   #6
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Confusing.... Explain please! seriousley, not sure what you are saying.
Old 11-05-2008, 01:47 AM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
Put oil on the washers or the torque readings will be inaccurate.
The last step of tightening should be at least 80 foot pounds. Usually this is more than 90 degrees. A big reason the DOHC 2.5 leaks is from a crappy torque sequence and inaccurate torque wrenches. The low torque specs before the 90 degree turns have a HUGE effect on final torque.
edit: Here is the specs from the 92 turbo service manual (which match yours) with my modified last step
middle top bolt is #1, middle bottom is #2, front upper is #3, front lower is #5, rear upper is #6, rear lower is #4
lube all washers with engine oil
tighten all bolts to 22ftlb
tighten all to 51ftlb
back off all by 180
back off all by another 180
tighten 1 and 2 to 27
tighten rest to 14 in order of 3 4 5 6
tighten all by 90 degrees in numerical sequence 123456
tighten again to 80ftlbs or 90 degrees WHICHEVER IS MORE
I have tightened head bolts by 360 degrees by mistake which you shouldn't do but nothing bad happened.
Old 11-05-2008, 06:10 PM   #8
91turbosedaan
Member#: 135144
1991 legacy turbo
white
Cool
you said "tighten all by 90 in numerical sequence 123456"
do you mean 90 foot lbs or degrees?
back off all by 180
Old 11-07-2008, 03:12 PM   #9
ciper
Member#: 15543
90BJ Legacy LS ABS
Oops lol degrees!
Old 11-08-2008, 09:14 AM   #10
leftho0k
Member#: 177589
trade in for a honda civic. you most likley dont have the mechanical appitude to be able to understand and sucessfully repair a subaru. have yer heads regasketed by a trained perfessional-cheapo! (wishes you had a "whacker" to destroy fixing!)
leftho0k is offline   Reply With Quote
Old 11-12-2008, 04:12 PM   #11
ciper
Member#: 15543
90BJ Legacy LS ABS
Even ARP headstuds now updated their install instructions to use 85 ftlbs
http://forums.nasioc.com/forums/show...php?p=24440750
I'd assume he has better mechanical aptitude than you. Asking a question when you don't know the answer shows more intelligence that pretending to know it all.
Old 11-29-2008, 09:52 AM   #12
leftho0k
Member#: 177589
umm a$$ume... all you want my 25th anniv Subaru legacy sport sedan performs a simphony at 1.1kgcm2 (str8 piped 2.5 welded tbe, sits on "special d" koni dampners n' eiebach pro kit springs,17x7.5 wheels and things like that see)
Old 11-29-2008, 09:59 AM   #13
leftho0k
Member#: 177589
What is a tork anyway?,lol
"heres some of my mechanical handy work.....now sits with fmic and rotated manifold and that is on a gc platform and with a boosted ej22na/
Last edited by leftho0k; 11-29-2008 at 10:12 AM. Reason: ....not only do I fix turbo subarus I make them!
Old 12-02-2008, 02:30 AM   #14
91turbosedaan
Member#: 135144
1991 legacy turbo
white
Wink progress
I have ordered a FSM from ebay, the seller decided to ship it media mail could take up to 2-3 weeks before i see it from what im told darn usps.
But i need to get my ej22t reassembled, so i need to find out the torque specs for the ROD bearings. I am using all new ACL race bearings, Should I plastic gauge these and if so what is the thickness / spec the last thing i wanta do is spin a rod or main bearing?
Should I use subaru black sealant on both the block halfs and or should i use subaru greay sealant, should i use some to hold the main bearings in place?
Or better yet has anyone created a rebiuld video!!
Old 12-07-2008, 02:16 PM   #15
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
I would use plastigauge. Dont worry about buying specific subaru sealant. I use Ultra Grey (3m or threebond I think, get it @ Joes). Never use sealant for the bearings/ rod caps. Make sure to get an assembly lube of some sort. I reccommend Lucas Oil Oil additive, sticky as hell and works well.
~Josh~
looking for ej22t block taossti Pre-2002 Factory Turbo Powertrain 22 03-08-2011 01:59 PM
Looking for Blitz Nur Spec R exhaust... Gooichimotors Private 'Wanted' Classifieds 3 12-29-2005 03:33 PM
Looking for a UK-spec 2002 wagon tailights The Vanishing Boy Private 'Wanted' Classifieds 0 11-29-2005 08:45 PM
If anyone is looking for a Legacy Spec B.... UKscooby Mid West Subaru Owners Club Forum -- MWSOC 11 11-22-2005 10:57 AM
looking for blitz nur spec r axleback awdguy Private 'For Sale' Classifieds 0 10-08-2004 03:46 PM
