Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 11-05-2008, 04:12 AM   #1
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Default whats the best Manual boost controller for 94 ej20g
im looking to buy a manual boost controller.. because i dont feel like buying a PFC or electronic boost controller.... or something expensive like that.
i heard some cheap MBC have a spike in psi and then drops like 3 or 4 psi..
that true?
well if u have suggestions let me know..or if u have one of your own.
pros/cons of a MBC.
Do u still have to Tune? or is everyone running stock ECU
how much higher can i turn the boost before i need a tunable ECU. im running about 11.5 PSI right now...
thanks.
azn0boi04 is offline   Reply With Quote
Old 11-05-2008, 04:35 AM   #2
mannyOlicious
Member#: 173829
04 dom3 +meth pyah
09 triumph daytona 675
i never see many pros coming from the MBCs... they leak, are unstable, fail, etc etc...
i would keep the one you have... your car came with one so why add or replace boost controllers? just go to your tuner and have them set it for you.
you will hear this a lot, but a spending 200-400 on a nice tune is so much better than 4000+ on a new motor...
mannyOlicious is offline   Reply With Quote
Old 11-05-2008, 09:18 AM   #3
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
i have a JoeP mbc that has been very reliable for many years, holds boost rock steady. It outlasted my expensive Blitz dual sbc controller. Its long been a favorite in the DSM crowd before the wrx hit the US. It relatively cheap compared to the newer Hallman mbc's which i hear perform well too.
You will need a tune to complement the mbc or ebc you choose.
fastnoypi is offline   Reply With Quote
Old 11-05-2008, 09:32 AM   #4
litebrite2001
Member#: 41656
2002 WRX Wagon
I liked the turbosmart boost tee. It clicks as you move it, so it is easier to dial in a given boost. I didn't see much spike, but that was on a stock turbo.
litebrite2001 is offline   Reply With Quote
Old 11-05-2008, 01:52 PM   #5
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
dang.... i have to tune it?
thats what im trying to get away from... i have stock ECU. and i dont wanna spend a grand or so on a tunable ECU.
i can still use a MBC without tune right? what will happen without a tune?
Old 11-05-2008, 02:15 PM   #6
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
HALLMAN FTW, never ha d a problem with it in 2 years.
gc8awdsti is offline   Reply With Quote
Old 11-05-2008, 02:30 PM   #7
mannyOlicious
Member#: 173829
04 dom3 +meth pyah
well one of the problems is that if you up the boost, and not adjust the fuel to compensate for the larger amount of airfow, you will run lean and that could soon result to engine failure
Old 11-05-2008, 02:43 PM   #8
DSM_Outback
Member#: 56345
93 Swapped L
Green
MBC=yuk on factory ECU.
That said I love the Hallman.
DSM_Outback is offline   Reply With Quote
Old 11-05-2008, 02:46 PM   #9
Blacksails192
Member#: 142686
back to european
halman pro ftw!
Blacksails192 is offline   Reply With Quote
Old 11-05-2008, 04:24 PM   #10
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
i want to up the boost from 11.5psi to 15psi... is that too much?
and isnt it, if u turn it down u run a lil more fuel efficient.
Old 11-05-2008, 08:07 PM   #11
Arctic Assassian
Member#: 91875
91 legacy TD04
04 WRB/carbon fibre STI
I use the hallman pro on one SS, and the pro rx on the swapped L.
Arctic Assassian is offline   Reply With Quote
Old 11-05-2008, 08:15 PM   #12
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Old 11-05-2008, 08:23 PM   #13
Arctic Assassian
Member#: 91875
91 legacy TD04
what year and model ej20g do you have? what color are your injectors? what turbo are you running? depending on these factors, you may be able to tune with a piggyback timing controller, and RRFPR, as long as you have a good wideband 02 sensor.
Old 11-05-2008, 08:27 PM   #14
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
i heard that there is no piggyback system for my car... its a 94 WRX. i think the injectors are Grey... no 100% sure. i have TD05 turbo... no wideband yet.
the only way to tune my car is going with a Pfc.. or link ... something like those. standalone
Old 11-05-2008, 08:47 PM   #15
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
i have the same exact 260 ps ej20g with the td05 16g and z4
i assume no piggybacks work
JDMFLCL is offline   Reply With Quote
Old 11-05-2008, 08:52 PM   #16
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
yeah... i dont have Z4 tho... i have U8... how is the Z4? ... worth buying one?
Old 11-05-2008, 10:09 PM   #17
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
I'm not a fan of throwing on a MBC w/o tuning, it's just too risky IMHO and for some of the reasons outlined above, but I completely understand your pain regarding the cost of tuning. I was considering the Z4 for my '96 EJ20G based on a number of things I've read, but decided to go with the Power FC. You may have seen this, but here is the link just in case... http://forums.nasioc.com/forums/show...ghlight=Z4+ECU.
All that said, I've used the Perrin, GFB and Turbosmart and by far the Turbosmart was the best of the bunch. Easy to adjust the boost (after you've dialed it in, simply count the clicks for the desired boost level). However, each MBC was used on a car that had been tuned. I used the Turbosmart for the Texas Mile run and it held 28psi for the last 1/4 mile without a bobble or spike.
beaviscih is offline   Reply With Quote
Old 11-05-2008, 10:23 PM   #18
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
yeah i saw that.. thanks for the thread... but i think if i wait a lilbit i can find one cheaper. i remember seeing some before that were cheaper... but back then i wasnt interested in Z4 ecu... or maybe ill save up and get a PFC. that would be better in the long run...
Old 11-05-2008, 10:27 PM   #19
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
mbc's are 100% more stable and fail resistant then any EBCS or EBC..
mxpunk is offline   Reply With Quote
Old 11-09-2008, 03:14 AM   #20
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
sent you a PM.
rob is offline   Reply With Quote
Old 11-09-2008, 08:09 AM   #21
RA Limited
Member#: 171249
2009 Chaco Z1 flip
Black/Blue
a million PSI.
RA Limited is offline   Reply With Quote
Old 11-09-2008, 01:14 PM   #22
suberdave
Member#: 101865
88 GL-10 STi
shoot me a PM i have a Dual stage TurboXS boost controler that i will sale you for $50. this is the one i ran on my car, now i have a Blitz EBC.
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 11-25-2008, 10:38 PM   #23
94 GT
Member#: 193676
94 legacy GT
silver (grey soon!!)
I'm in the midst of swapping a 20G into my 22T powered legacy. I'm very broke from it already!!! so the stock boost controller for the tiny turbo off the 22 will only run like 8psi or so right. Getting an intercooler so what doe's the early G's run stock like 12psi or somthing would it be okay to use a MBC to get it up to 10-15psi???? I'm getting a boost gauge and Oilpress gauge before I evin think of rasing boost!!!!! is the comp just set to certin perameters to let the waste gate move a certin amount??? so it will be running at a certin % of flow to the turbine?? maybe it will run at a higer boost than the 22's turbo baised on the fact that it's bigger?????????????
94 GT is offline   Reply With Quote
Manual Boost Control for 04 rex Shifty Eyes Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-05-2004 10:53 AM
What does a Manual Boost Controller do? PinoCchiOy Newbies & FAQs 21 04-14-2004 04:14 PM
Joe P manual boost controller for sale Flyboy-1 Private 'For Sale' Classifieds 0 11-12-2003 08:11 AM
stock WRB wing, GFB manual boost controller for sale BoostdScubaru Private 'For Sale' Classifieds 0 10-27-2003 08:12 PM
Whats the best electronic boost controller for a WRX? MCCSpear231 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-11-2001 12:13 AM
