Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 03-23-2002, 01:26 PM   #1
HudsoN456
Member#: 11462
1999 Integra GS-R
Super Sonic Blue Pearl
Question Oil, Water, Fuel pump question
Does anyone know what the typical replacement times on the oil pump, water pump, and fuel pump are for a 2000 Impreza 2.5RS?
These items aren't listed in the Subaru maintenance guide, so I was just curious. Since they're not in the manual, maybe they never need replacement?
Thanks
HudsoN456 is offline   Reply With Quote
Old 03-23-2002, 04:57 PM   #2
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
Are you asking "what is the recommended replacement interval" or are you asking "how long does it take to replace it, labor time"?
There is no replacement interval for the Oil Pump, Water Pump, or the Fuel Pump, if that is your question. They are not considered "wear items".
SubyTechMaster is offline   Reply With Quote
Old 03-23-2002, 08:08 PM   #3
HudsoN456
Member#: 11462
1999 Integra GS-R
Thanks for the info,
I was asking if Subaru recommended replacing these parts after a certain amount of mileage was on the vehicle. Since these are non-wear items like you said, I am relieved!
Does anyone know if it is common for these pumps to fail, and what happens if they do? If your oil pump failed, I would imagine serious problems to the engine because of lack of lubrication!
-Thanks
Old 03-24-2002, 01:44 PM   #4
newbie sewbie
Member#: 10615
ok, the oil and fuel is a no wear parts, but i have to disagree on the water pump....try bringing your car in when you need a new timing belt and see what the service writer is going to tell you bout the water pump
newbie sewbie is offline   Reply With Quote
Old 03-25-2002, 12:55 PM   #5
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Yeah, water pump should be replaced when timing belt is changed. The water pump is exposed when you change the timing belt is removed anyway.
tmat3 is offline   Reply With Quote
Old 03-25-2002, 01:38 PM   #6
Kyle Paton
Member#: 1184
2012 Impreza
Dark Grey Metallic
We have 88 Loyales come in with 130,000 mile with the original oil pump.
Its kind of a judgement call. If you do regular oil changes you shouldn't have to worry.
Kyle
Kyle Paton is offline   Reply With Quote
Turbo pipes, oil cooler, fuel pump, Microtech LT10 JabroninWARRIOR Engine/Power/Exhaust 1 12-13-2009 11:34 AM
FS apexi turbo timer , blue injectors , TMIC , oil pan , fuel pump more MAKE OFFER!! calweezy SCIC Private Classifieds 27 10-10-2009 05:30 PM
where are the squirters, oil, and fuel pump? wildchild Newbies & FAQs 1 07-27-2005 09:04 PM
IC Water Spay pump Question Quick WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-20-2002 07:23 PM
fuel pump question Walbro vs Supra unit IMPBOY Normally Aspirated with bolt-on Forced Induction Powertrain 26 10-15-2001 07:08 AM
