Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 11-05-2008, 03:02 PM   #1
GST Motorsports
Vendor
Vendor Sales Rating: (8)
Member#: 130434
Default *Proudly offering BLOUCH Turbos*
GST Motorsports is proud to announce we are offering Blouch Turbos!
Need a quality turbo that has even better manufacture backing with a reasonable lead time? Look no farther than our new friends at Blouch. Most of you have heard of Blouch but for those of you that have not then check them out http://www.blouchturbo.com/history/. Ask about any of the Blouch turbos but below are just some of our recommendations based on local customers results over the last couple of months. Blouch turbos are bolt-on stock location turbos that require no modification to oil feed, oil drain, coolant or exhaust connections for installation complete with braided stainless steel oil feed line, turbo oil drain tube and coolant lines.
Dominator 3.0R
Yes-the innovators at Blouch Performance Turbo have done it again! Garrett GT full ball bearing performance and efficiency in a WRX/STi bolt-on package complete with braided stainless steel oil feed line, turbo oil drain tube and coolant lines. We call it Dominator 3.0R and it has no equal (at least not yet-but it won't be long until our competitors attempt to copy our success).
The WRX/STi Dominator 3.0R features a state-of-the-art 52 lb/min Garrett GT compressor wheel, a high efficiency Garrett GT turbine wheel, Garrett GT full ball bearing system, adjustable upgrade wastegate actuator calibrated at 15 PSI and ported turbine housing capable of delivering 520 HP at boost pressures up to 33 PSI. (Chassis dyno results repeatedly indicate 400+ wheel horsepower and torque easily attainable with the Dominator 3.0R and supporting mods).
TD06H-20G
The WRX/STi TD06H-20G enhances high boost pressure performance by substituting the larger TD06H high flow turbine for the TD05H turbine to reduce exhaust manifold/turbine housing backpressure while maintaining good throttle response. The 44 lb/min Mitsubishi 20G compressor wheel is installed in a true TD06 compressor housing and is paired with a 7 cm2 nozzle area turbine housing. Standard wastegate actuator is calibrated at 9 PSI and optional upgrade actuators are available in incremental pressures from 10 PSI to 19 PSI. To maintain proper boost control, the TD06H-20G requires a ported turbine housing that is included in the price of the turbo.
TD05H-18G 8cm2
Perfect for your 400 HP WRX/STi project, the TD05H-18G features the 40 lb/min performance of the Mitsubishi TD06 18G compressor wheel in a true TD06 compressor housing to maximize compressor efficiency. (Do some comparison shopping and you will find our competitors using a TD05 compressor housing with an 18G or even 20G compressor wheel to maximize their profit margin and supply you with a less efficient turbocharger.)
Optimal turbocharger response is achieved through the use of the Mitsubishi TD05H turbine wheel combined with an 8cm2 turbine housing that produces an additional 20 to 30 lb/ft peak torque over the 7 cm2 turbine housing.
Have any questions about supporting modifications or what turbo is best for your driving style/power needs? Please PM us!
GST Motorsports is offline
Old 11-07-2008, 02:10 AM   #2
Spec_C
Member#: 91423
Chapter/Region: HIIC
2004 PSM STi on Meth
Tuned by Chris [email protected]
price for 20g shipped to 96740.
Spec_C is offline
Old 11-07-2008, 05:31 AM   #3
gc8awdsti
Member Sales Rating: (27)
Member#: 192848
1998 GC8 rsti
BDP
can you do a 90degree inlet like on the JDM spec turbos? PM me price and info on the 18g. thanks.
gc8awdsti is offline
Old 11-07-2008, 07:45 PM   #4
GST Motorsports
Vendor
Member#: 130434
PMs sent.
Thanks,
Greg
Old 11-07-2008, 08:32 PM   #5
castsnoshadow
Member Sales Rating: (4)
Member#: 162859
2006 AW STI-Sold
Now: 2007 SWP STI Stage 2
Greg,
This is Dominic Here. I came in on Thursday night with my buddy, talked realistically about doing a Dom3 set up on my 06 white sti and u gave me a print out. You will never guess what happened to me later that night.
Check out my other thread!
http://forums.nasioc.com/forums/show....php?t=1633144
castsnoshadow is offline
Old 11-10-2008, 03:43 PM   #6
GST Motorsports
Vendor
Member#: 130434
I saw that man, so sorry to hear that. Crazy that happened! Let me know when everything gets back together and you sell your bike.
-Greg
Old 11-13-2008, 03:39 PM   #7
GST Motorsports
Vendor
Member#: 130434
Old 11-20-2008, 04:40 PM   #8
GST Motorsports
Vendor
Member#: 130434
Up!!!
Old 11-26-2008, 02:40 PM   #9
GST Motorsports
Vendor
Member#: 130434
Old 11-26-2008, 05:06 PM   #10
Da C Egg
Member#: 192095
05 GDE + 93 S13
Wrong Fitment Crew #008
Do you guys have TD06 20G with 8cm?
How much is the price installed locally ?
Thanks!
Da C Egg is offline
Old 11-28-2008, 11:44 PM   #11
raheezy69
Member Sales Rating: (10)
Member#: 163078
MARG BAR DICTATOR
LONG LIVE IRAN!!
price on 18G?
raheezy69 is offline
Old 11-30-2008, 07:47 PM   #12
im2ninja4u
Member Sales Rating: (8)
Member#: 183389
Price on a dominator 4?
im2ninja4u is offline
Old 11-30-2008, 09:51 PM   #13
flipn0y
Member#: 157288
1995 STi
Dark Blue
price on 18g shipped to residential 78239?
flipn0y is offline
Old 12-01-2008, 08:12 PM   #14
GST Motorsports
Vendor
Member#: 130434
PMs sent.
Thanks,
Greg
Old 12-10-2008, 03:47 PM   #15
GST Motorsports
Vendor
Member#: 130434
Old 12-12-2008, 05:11 PM   #16
GST Motorsports
Vendor
Member#: 130434
Page 1!
Old 12-14-2008, 06:21 AM   #17
four us four
Member#: 166356
Default TD05H-18G 8cm2
cost + shipping to 96816.
Thanks
four us four is offline
Old 12-15-2008, 08:17 PM   #18
GST Motorsports
Vendor
Member#: 130434
PM sent.
Thanks,
Greg
Old 12-19-2008, 08:22 PM   #19
GST Motorsports
Vendor
Member#: 130434
Friday Bump!
Old 01-02-2009, 05:43 PM   #20
GST Motorsports
Vendor
Member#: 130434
2009 bump!
Old 01-02-2009, 10:37 PM   #21
mikercp
Member Sales Rating: (40)
Member#: 166465
1994 Civic Cx
Frost White
Price for td05 18G **I have ej20 would you recommend 7CM or 8CM** shipped to Corona, CA 92879 ?
mikercp is offline
Old 01-04-2009, 12:13 PM   #22
theSlothy1
Member Sales Rating: (12)
Member#: 173321
2007 SWP WRX
dom2.5xtr w/ meth & 6spd
Could I get a price for a TD05H-18G 8cm2 shipped to Nova Scotia, Canada
Thanks
theSlothy1 is offline
Old 01-06-2009, 08:15 PM   #23
sideways7
Member Sales Rating: (7)
Member#: 49428
bump for awesome turbos and great vendor
sideways7 is offline
Old 01-07-2009, 04:03 PM   #24
GST Motorsports
Vendor
Member#: 130434
PMs sent! Thanks sideways7!
Cheers,
Greg
Old 01-13-2009, 08:03 PM   #25
GST Motorsports
Vendor
Member#: 130434
Closed Thread
Cobb Access Ports 2.5 WRX/STI Back in Stock! TurboXS*Invidia*Perrin*Blouch Turbos Spun Autosports Engine/Power/Exhaust 42 08-23-2007 03:48 PM
TurboXS Silly Exhaust Deals! {Cobb Access Ports} {Blouch Turbos} Invidia/Perrin/Blitz Spun Autosports Engine/Power/Exhaust 25 08-09-2007 01:46 PM
Free Overnight on Cobb Access Ports*TurboXS*Perrin*Invidia*Blouch Turbos*Greddy*Blitz Spun Autosports Engine/Power/Exhaust 39 08-01-2007 01:46 PM
Free Overnight on Cobb Access Ports, Insane TurboXS, Blouch Turbos, Perrin, Invidia! Spun Autosports Engine/Power/Exhaust 50 07-17-2007 12:23 PM
