#26 |
Member#: 115149
Vehicle:07 STI Murdered & Loud |
Great numbers!! What cams were used with this setup? Why does torque fall off so quickly after 4750 rpm?
That must feel like a fricken rocket!!
#27 |
Member#: 152080
South East
Vehicle:6266 Precision'd Big Cam'd 2.55l 6spd Bugeye |
Wow must be fun to drive.
#28 |
Member#: 32122
Vehicle:09 Kuota |
quick as hell!
#29 |
Member#: 102948
Vehicle:2006 STI |
Going to pick up the car today from Hill - stay tuned for vids and more pics...
Hill and the whole crew at Agile Auto have provided me with years of excellent customer service! I want to thank them again for taking great care of my Subi and being extremely tolerant of my boost addiction... Hill has been modding my car since I purchased it new in 2006 and it just keeps getting faster and faster... ![]() Based on what Hill has told me about the cars performance and looking at the dyno charts it should be a fun car to driver, I'll let you know later tonight ![]() Some naked pics of the build for your enjoyment... Special thanks to Ron @ Raw Performance for a killer Signature series block short block, Dave from HeadGames Motorworks for the most amazing head work, Geoff from Full-Race for building the baddest Subi manifold on earth and Robi from Robispec for the chasis and suspension package! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#30 |
Member#: 102948
Vehicle:2006 STI |
#31 |
Member#: 102948
Vehicle:2006 STI |
#32 | |
Member#: 127670
Vehicle:2007 HTA GT3794 Darton Sleeved |
Nice build, what I want to know is whether the car has stock sized valves and why the power is falling off at 6000 rpm. If it has heads and cams, it should make power at least to 7K before tapering, and you should be running the car to 7500-8K. That power band looks alot like what I had with my stock cams before changing to Kelford .264's. Did Hill do any AVCS adjustments? Also, what's with the peak power at 80 MPH? Tuned in 3rd gear? Load changes as you move into higher gears, I hope you don't overboost in 5th gear on the highway. |
#33 |
Member#: 81102
^^^odd set of questions..why would he be tuned in 3rd anyway?
#34 |
Member#: 87653
South East
Vehicle:07 STI / 97 Supra 1700whp of fun |
Oh no, Philthy invading the Subaru crew?
#35 | |
Member#: 143039
Vehicle:2007 STI Satin White Pearl |
I'm pretty sure Hill does mostly 4th gear pulls when he dynos.
Correct me if I'm wrong ppl... Quote:
#36 |
Member#: 102948
Vehicle:2006 STI |
The cams are Kelford race cams, 282's and the valvetrain is Ferrea with stock size valves - I can ask Dave to comment on the heads if you guys want to get into a deep technical discussion, but my request was for a roadrace setup that would not be lazy on the street, based on those requirements Dave recommended we use the stock size valves...
Hill can comment on his tuning methods, but I can tell you that there's no over boosting - I've tested all gears on the way home ![]() |
#37 |
Member#: 77470
Vehicle:04 sti 10.51@138.5 on e85@ 30psi--spinning |
which head gskts did Ron recommend to use with the o-ringed block and how thick of o-ring did he use.
#38 |
Member#: 102948
Vehicle:2006 STI |
#39 |
Member#: 77470
Thanks I appreciate the info--I have totally pushed the stock sleeved block to its limits and its time to get serious and I really liked the o-ring job done on your block.Your motor is super clean looking I hope it does everything you need it to do.
#40 |
Member#: 127670
I missed the no AVCS, and apparently I wasn't thinking about the car being an 04 with shorter gears, since I am running to ~96mph in 3rd at 8K and 128 in 4th. Sometimes you post funny things when you are tired. I hope to see the car at MIR tomorrow!
#41 |
Member#: 143039
^^^Yeah our 07 gears are nice, haha.
#42 |
Member#: 102948
Vehicle:2006 STI |
The car is an 06 - the 07 gears are definitely a more ideal ratio IMO... I have plans to switch over to them once my tranny needs to be rebuilt - as of right now it's in perfect shape so that mod will be coming sometime in the future...
#43 |
Member#: 41149
SCIC
Vehicle:04 09 FXT SSM |
I think you would pick up a lot of power if you went to a "real" 35r. Power should not be falling off like that with cams that huge and head work. As others have said, you should be able to make good power to 7k+ with cams that hot.
#44 | |
Member#: 175453
Vehicle:AE86 GT-S coupe i <3 alqonquin homosauce |
The stock location is holding it back a bit with the inlet and exhaust housing. The peak numbers look great, but it's not holding it as I would have hoped. |
#45 |
Member#: 143039
PPhilthy, are you coming down the Agile's fall open house next Saturday?
#46 |
Member#: 102948
Vehicle:2006 STI |
Next step for me is the Full-Race 40r... Geoff is selling these turbos and wanted to get some real world test data and here it is... It's a great turbo for the stock location!
#47 |
Member#: 102948
Vehicle:2006 STI |
One other note - I just looked at a couple of rotated 35r setups that have been posted, Melo, ScubaSteve, etc... If you over lay my numbers on their charts (scaling) I'm spooling a lot faster than the both of them, make just about same peak power and all the setups dynos fall off at the same points... Interesting...
I think their shall be improvement in carrying power out on all setups with a better designed intake manifold over the stock one, something like the new Cosworth... |
#48 |
Member#: 102948
Vehicle:2006 STI |
#49 | |
Member#: 5591
Vehicle:2002 WRX EJ257 Gt35r |
+1 waiting for data on the new intake manifolds! nice numbers though!!! My thoughts are since the 282's are in there they need MORE intake and exhaust flow than the 272 or 278 duration cams that most people run. That's why the power peaks at 6k and makes more torque than most others. It's flowing like crazy at the beginning and choking up at the finsh. I bet there is still plenty of power to be had with this setup. |
#50 |
Member#: 122393
Vehicle:02 WRX WRB |
wow that is a sweet turbo!!!
| Thread Tools | |
| Display Modes | |
| Agile Tuned 04 Sti - FP Red/Q16 1/4 mile run | 04fpgreensti | Proven Power Bragging | 19 | 07-24-2009 04:23 PM |
| Agile tuned AEM Fp Red STi 500ft/lbs 536whp!! | trbowrx | Proven Power Bragging | 65 | 12-08-2008 07:51 PM |
| AVO 500 STi Agile tuned. | trbowrx | Proven Power Bragging | 72 | 02-04-2007 07:45 PM |
| NEW BEST! Agile tuned EWG stage 2 sti! | trbowrx | Proven Power Bragging | 26 | 11-08-2006 12:01 PM |
| 373whp 331wtq '04 sti sr55 Agile Tuned | size18boarder | Proven Power Bragging | 6 | 09-30-2006 01:06 AM |
