Old 11-06-2008, 09:56 AM   #1
guiltyone311
Member#: 189401
2004 sti built!!
jbp w/fp red&meth
Default buying a sti with blown headgasket
im looking at buying a 05 sti with a blown headgasket supposibly hadnt been driving on the blown head gasket but does start up fine, was wondering if this would be a good idea im getting it pretty cheap was just making sure the odds on the heads being warped on this is it a common problem for the heads to warp or should i just pass up on this deal and wait thanks
guiltyone311 is offline   Reply With Quote
Old 11-06-2008, 10:33 AM   #2
jays05
Member#: 78165
05 STI 35r + e85
When my last motor blew a head gasket here's what it needed:
One new CP piston
One Pauter rod needed to be cleaned up at the machine shop because the small end bushing was deformed
Block rehoned
New CP rings
Heads resurfaced
All new bearings and gaskets
Cost to repair the engine was around $1500-2k. Plus more for removal/reinstallation/etc.
You should always resurface the heads when they are off even if the look straight with a straitedge. Otherwise it will blow again. Ask me how I know....
jays05 is offline   Reply With Quote
Old 11-06-2008, 12:00 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
if i had the knowhow and facilities to do all the work myself
or
could get the work done cheap
id be all over a good deal on an sti with a bad headgasket
Old 11-07-2008, 05:40 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Like the others have said. The blown headgasket could be as simple as replacing one gasket or as bad as needing machine shop work and new rings. Some of the 2.5 normally aspirated engines would overheat so bad that a new shortblock was the cheapest repair.
Can you start the car and listen to it?
Old 11-08-2008, 01:09 PM   #5
rick-l
Member#: 33868
2003 wrx
srp
You wanted opinions so here is mine.
jays05 engine sounds like the gasket blew because of overboost.
Sometimes headgaskets just let go. Do you know any of the cars history or mods?
I have never done it on a SUbaru but a head gasket kit is about $200 and I would bet a valve job another couple hundred.
With the current economy buying this thing to fix it and make any money would be risky unless you got it super cheap. On the other hand if (like me) you like doing this stuff and just wanted to drive it for a while and were willing to risk losing money or at best breaking even go for it. The other downside is some of my projects have been unaticipated expensive disasters.
rick-l is offline   Reply With Quote
2009 so far: 2 cars with blown headgaskets and a cracked sewer main line...$$woes$$ doubledribble Off-Topic 13 01-02-2009 06:02 PM
98 forester with blown headgasket- great shape DCsubieSTI Private Vehicle 'For Sale' Classifieds 6 02-11-2008 03:56 PM
98 forester with blown headgasket- great shape DCsubieSTI Tri-State Area Private Classifieds 7 10-31-2007 11:07 PM
Wanted: Impreza/Legacy/Forester with blown headgaskets jamesfacts NESIC Private Classifieds 9 01-17-2007 10:32 PM
Guys with blown headgaskets, rate your driving style MaddMax Legacy Forum 16 06-16-2004 11:00 AM
