Old 12-20-2008, 03:35 PM   #26
XRWITS
Member#: 157870
0407 STi's
One Black, One White
Originally Posted by RP31 View Post
Were you lucky enough to buy the car after Subaru realized the first round of '04s had pinging issues?
Don't run arco 87 octane **** gas and it won't ping
XRWITS is offline   Reply With Quote
Old 12-27-2008, 10:16 PM   #27
Wrekaro
Member#: 80972
2002 Impreza WRX
Model year: 2008
Build date: No Idea
Purchase date: July 08
Failure date: August 08
Mileage at failure: 1800
ECU recall performed? yes
Was car modified? (If so, list mods) No
Want to add that although the loss of a brand new engine was a bummer the dealer I went to handled this very well. Better then expected and I expected a lot.
Wrekaro is offline   Reply With Quote
Old 12-27-2008, 11:05 PM   #28
soundslikeboxer
Member#: 131915
2007 WRX
sexy white pearl
I think its important state which cylinder failed as well. #4 Seems to be a big problem
soundslikeboxer is offline   Reply With Quote
Old 12-28-2008, 12:56 AM   #29
MasterKwan
Member#: 98961
2003 WRX
Maybe subaru needs to hire someone to tell them how to turbo modern engines. If Dodge can do it with the SRT-4, and GM with the Cobalt SS, you'd think Subaru could get this right.
I was just reading about Porsche Boxsters. Apparently, they're getting an estimated 20% failure rate on Boxster engines.
http://www.thetruthaboutcars.com/wil...gine-failures/
http://www.flat6innovations.com/reliability.htm
Old 01-02-2009, 06:02 PM   #30
blue_mazi
Member#: 198691
Default 2008 ring land failure -- new addition
picked up a 2008 sti new at thanksgiving (as part of the $6500 off offer). engine failed on december 10 with less than 2000 miles. break in was done correctly (afaik, as the car had 200 miles on it at the dealer), no mods, no track. #4 cylinder is affected. the reflash apparently HAD NOT been performed.
SOA is going to repair the affected cylinder (not replace the engine). i am concerned as two dealers have told me they should replace the engine.
i am looking for input as to what i can expect. sounds like it will fail again after repair looking at this forum. i'd appreciate any help/advice as i am completely new here and to the sti (coming from an m3). i've asked SOA to replace the engine and they've refused. thanks.
blue_mazi is offline   Reply With Quote
Old 01-02-2009, 06:10 PM   #31
hella_sti
Member#: 139289
2003 WRX Wagon
talk to the regional manager and demand that they replace the ENTIRE engine under warrenty sighting the two other dealerships' recomendations or just take it to one of the other two.
hella_sti is offline   Reply With Quote
Old 01-02-2009, 06:29 PM   #32
PGT
Member#: 57283
2014 4.7L of TT Fury
w/ 4Matic
it's SOA's call, not the dealer's. Perhaps while the motor is pulled, he could get the dealer to replace all four at the same time (at his cost....which would be my choice if I was in that situation). Then, I'd fight with SOA for the cost.
PGT is offline   Reply With Quote
Old 01-02-2009, 06:55 PM   #33
flycaster
Member#: 60142
2011 WRX
Grey
Better yet, just hand the mechanic a set of forged pistons and new rings under the table and pocket the OEM replacements - then sell 'em on E-Bay. What's $500 for a little piece of mind? You sure as hell won't be back in for another piston failure, plus you can then mod the car to your heart's content. That's a lot of free labor there, boys.
flycaster is offline   Reply With Quote
Old 01-02-2009, 07:22 PM   #34
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
I'm screwed, I own an 08 STI and a Boxster.
silver arrow is offline   Reply With Quote
Old 01-02-2009, 07:26 PM   #35
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Did any of you guys with Mods have a problem with warranty denial?
Old 01-02-2009, 07:55 PM   #36
PGT
Member#: 57283
w/ 4Matic
exactly.
Old 01-03-2009, 08:03 PM   #37
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
Default First oil change was today...
You poor bastard!
Just about rolled over 3,000 miles on the STI today (and though the build date was 02/08 I didn't buy it until November), so things are looking good ... so far.
Coati is offline   Reply With Quote
Old 01-03-2009, 09:58 PM   #38
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Asking again. Did any of you guys with EM or TBE get warranty hassles, or is SOA just fixing them because they know there is a problem?
Old 01-03-2009, 10:13 PM   #39
PGT
Member#: 57283
w/ 4Matic
if you take your car with an AP and TBE installed, you're not doing yourself any favors.
Old 01-03-2009, 11:12 PM   #40
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
I understand that, but the question is to the guys that had ring failure and had mods. Did they cover it or give you a problem?
Old 01-03-2009, 11:22 PM   #41
PGT
Member#: 57283
w/ 4Matic
umm....read between the lines a bit?
Old 01-03-2009, 11:55 PM   #42
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
How does Subaru know if you reved it to the rev limiter? Did they start recording when you hit the rev limiter on the ECU like Porsche does in order to deny warranty work?
Old 01-03-2009, 11:58 PM   #43
PGT
Member#: 57283
w/ 4Matic
rev limiter and fuel cut are separate things. It would be hard to believe a manufacturer that includes a user programmable shift light on their car would deny warranty.
Old 01-04-2009, 02:13 PM   #44
blue_mazi
Member#: 198691
Default thanks for your suggestions
thanks for you suggestions. will let you know how this goes with SOA.
Old 01-07-2009, 11:05 AM   #45
Boxer4u
Member#: 115149
07 STI
Murdered & Loud
i thought the casting process was different for the 07+ STI's than the previous model year STI's.
Boxer4u is offline   Reply With Quote
Old 01-07-2009, 12:34 PM   #46
Clark_Kent
Member#: 114299
+1...
Clark_Kent is offline   Reply With Quote
Old 01-22-2009, 10:13 AM   #47
animator659
Member#: 181376
2008 STI
How can I determine my build date on my 08 STI?
animator659 is offline   Reply With Quote
Old 02-23-2009, 10:50 PM   #48
M427
Member#: 203457
I have 12,000 miles on my 08 STI purchased in June of 08. It is 100% stock and I have been looking at doing some tuning but every time I drive it hard it pings even on 93 octane. So I don't tune it and continue to drive it like a toyota. I purchased it as a track day car but it is easy to tell after spending some time with it the engine is fragle. Think I will pass on oem fixes and build the short block before any tuning or track time.
M427 is offline   Reply With Quote
Old 03-04-2009, 01:16 AM   #49
CGM_SCOOBY
Member#: 129314
2003 EVO VIII
2012 Veloster
Bought my STi last week with 700miles on it..been sitting at dealer for a long time. Ended up going to another dealer in KC for oilchange, and it came up as being affected. That dealer did the reflash, hope nothing during first 700miles has caused damage. Kinda pissed that dealer where I bought didnt do the reflash while car was still there.
CGM_SCOOBY is offline   Reply With Quote
Old 03-04-2009, 11:41 AM   #50
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Mine #4 went on Sunday at it's first autocross with 3500 miles. Car had 90 miles when purchased, had reflash before picking up, was a stop sale car and supposedly checked out fine. I got a conservative STU tune, everything else stock, at 1000 miles. Car started running rough and smoking on drive home Sunday, initially diagnosed as a stuck PCV. After PCV replaced, CELs lit up and compression test showed #4 to be toast. Dealer is replacing engine. PCV valve may have caused the detonation that killed mine.
Has Subaru fiqured out why these are dying. Many speculate it's the tune, different metallurgy in the pistons, the fuel injectors, improper ring gaps from the factory. I don't understand, my 02 WRX and 05 STi were very robust and I abused the hell out of them without a single failure. Why are the 07-09 so prone to failure?
stock 2007 sti cracked ring lands 07pearlwhiteSti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 64 12-30-2008 01:41 PM
Anyone know OEM 2.5 sti piston ring thickness? bugeyes Built Motor Discussion 4 06-30-2006 11:14 AM
FS: 06 sti pistons rings rods and pins 4goodtime Private 'For Sale' Classifieds 1 03-06-2006 10:10 AM
sti piston ring spec one wicked wrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 02-15-2005 05:38 PM
is OEM STI piston rings strong enough?? skyline31 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 01-15-2005 11:17 AM
