Old 12-09-2010, 11:12 AM   #126
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
I hope this engine issue has been solved... I just picked up a 2011 sti.
Is it suggested to put EM on the car sooner than later?
Louie is offline   Reply With Quote
Old 12-09-2010, 01:17 PM   #127
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
Originally Posted by trick3d View Post
He is talking about you specifically. They want details as to your personal experience.
The details of my failure have already been posted and shared in multiple threads along with my personal findings and opinions on why this problem occurs. Also shared are opinions from SOC regional managers, tech line specialists as well as notable tuners and racers with direct involvement in factory efforts.
There is plenty of info out there if someone would like access to it.
mapleleaf is offline   Reply With Quote
Old 12-09-2010, 06:02 PM   #128
flat4doniz
Member#: 263475
i was on stock tune for almost 20k then stage1 ap a week after i hit stage 2, so i doubt it matters when you switch EM.
just keep knocking the wood.
flat4doniz is offline   Reply With Quote
Old 12-09-2010, 07:12 PM   #129
krinkle
Member#: 264311
2011 Impreza WRX STi
white
Originally Posted by mapleleaf View Post
There is a ton of info out there explaining many of the contributing factors and issues.
Yes there is, but it's scattered all over. From what I can understand there are several things ...
1) ECU update form Subaru to help fix this problem due lean condition at rev limiter
2) Possible piston/ring issue, usually shows up in cylinder 4 first.
3) Engine not properly broken-in.
4) Tuning
That is what I found searching BEFORE I posted. Is that it? Did Subaru change anything other than the newer ECU program? Update pistons/rings in newer cars? Is going stage 1 or 2 not a good idea?
This is what I got from my searches, I was wonder if someone had and official or unofficial word from Subaru. I'm not canceling my order. Just trying to be informed.
At the end of the day it seems this might be a very small percentage of STi's sold, I guess I'll roll the dice. I have no plans on doing even a Stage 1 at this point, just some overlays for the godaweful tail lights.
krinkle is offline   Reply With Quote
Old 12-09-2010, 08:14 PM   #130
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
I thought people suggested that having a different EM would possibly prevent the lean high rpms. However, I didn't know if that was the only real variable other than manufacturing issues.
Old 12-15-2010, 02:51 PM   #131
steelsnow
Member#: 124721
2006 WRX
Stock w/forged pistions
Model year: 2006 wrx
Build date:
Purchase date: 5/06
Failure date: 11/10
Mileage at failure: 116k
ECU recall performed? no
Was car modified? no
I know this is supposed to be for 08+ sti's, but my 06 wrx ended up with a broken piston on #4. It definitely wasn't new, but I didn't beat on it too much. Most of my miles are freeway miles and ~3k rpm on the freeway type stuff. I am going with forged pistons so hopefully I won't have this problem again. I will make sure there isn't a ecm reflash out for it before I drive it too much.
steelsnow is offline   Reply With Quote
Old 12-15-2010, 03:37 PM   #132
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
Build date:
Purchase date: 5/06
Failure date: 11/10
I would suggest getting a tune to go with those pistons.
I'm sure you will have to bore the cyl's...
Old 02-16-2011, 11:58 PM   #133
frsh2
Member#: 177908
2010 STI
Satin white pearl
Model year:2010
Build date:06/09
Purchase date:04/10
Failure date:11/15/10
Mileage at failure:12,207
ECU recall performed?no?????????
Was car modified? cobb stage 2 CAI map
pistons #2 + 4. paying for it myself voided warranty. forged pistons all the way... don't trust the 2011's either, stock or modded. I didn't even beat on the car, it was one week shy of going into winter storage... I will never buy a subaru again. this has been going on since 07?! andd the service dept. denies everything said on the forums and told me my car was overreved to create this problem.... bull****.
frsh2 is offline   Reply With Quote
Old 02-17-2011, 01:02 PM   #134
dakrat
Member#: 272840
2011 STI
Originally Posted by frsh2 View Post
Model year:2010
Build date:06/09
Purchase date:04/10
you gotta pay to play man. thats just how it is. void the warranty and it is a costly repair. the only source that the service dept. should listen to is SOA, not internet experts. I have always wanted to get the cobb accessport but its not worth voiding the warranty
dakrat is offline   Reply With Quote
Old 02-17-2011, 01:16 PM   #135
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Hmm, I wonder if I'll have a problem. I asked the dealership specifically about the piston failures. They told me that even with cobb AP and bolt-ons would not void the warranty. This is before I bought the car, and confirmed 2 weeks ago.
When I asked about the STi failures on NASIOC and IWSTi, they also mentioned that for the most part it is a representation of a small community and that the failures are a small population of vehicles.
Old 02-17-2011, 01:23 PM   #136
xcoder
Member#: 186660
08 STi
Spark Silv
I agree that if you want to play, you'll have to pay.
I do not agree that in this example, the aftermarket parts caused the failure. Granted, we will never know, but for the folks here with the issue, factory or otherwise, I believe that if the problem is going to happen, it will regardless of upgraded, aftermarket, or factory parts.
xcoder is offline   Reply With Quote
Old 02-17-2011, 07:06 PM   #137
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
Don't worry, they like to blow up stock too...
Old 02-17-2011, 07:18 PM   #138
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
Better get that in writing bro...
Old 02-17-2011, 07:56 PM   #139
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
I know my thoughts as well. However, Annapolis Subaru (a vendor here) seems to have a reputation of being a mod friendly dealership. They even sell blouch turbo's.
Old 02-18-2011, 12:43 AM   #140
flat4doniz
Member#: 263475
true so as fort wayne subaru.......& libertyville subaru too,
Old 02-18-2011, 07:51 AM   #141
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
My dealer is pretty understanding as well. I had the whole ringland conversation with the GM and regional rep before I bought the car and had their assurance that they would take care of me if I had a failure, which I did.
Most dealers just flat out lie to you though...
Old 05-19-2011, 11:40 PM   #142
Franko
Member#: 193628
2010 STI
SSM
Im on board..
Model year:2010
Build date:01/10
Purchase date:07/10
Failure date:05/19/2011
Mileage at failure:15,500 KM
ECU recall performed? No
Was car modified? Stage 2
Yep.. happened today..
Car is a 2010 STI with 15,000 km on it. Stage 2 flash with absolutely no knock. IAM was at 1.0 with no knock history. Ive been running this tune ever since I have had the car so its not lean.
Today after a few pulls I notice that something isnt right. It just didnt 'feel' right. No smoke or anything but still.. so I stopped and checked the motor and it seemed to be shaking very strangely. To me it was the shake a missing cyl and therefore a broken ringland. I go home and hook up the laptop and see misfires on cyl #2. I take the plug out, looks fine.. no oil. Compression test the cyl.. 60 psi! Well crap.. broken ringland for sure.
Im bringing it to the dealer tomorrow..
Here it is, your moment of zen..
Franko is offline   Reply With Quote
Old 05-20-2011, 10:29 AM   #143
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
Model year: 2008
Build date: ??
Purchase date: Dec 2008
Failure date: July 2009
Mileage at failure: 20,xxx
Was car modified? (If so, list mods)
Cobb AP stage 2
Motor was warrantied and rebuild from a local dealer. The same failure occurred again 7,000 miles later and warranty was void. Ended up going after market 30k miles so far an no issues.
bhhamblin is offline   Reply With Quote
Old 05-20-2011, 10:48 AM   #144
Paidfor
Member#: 267815
Be in awe
dont hate .)
This thread should be called (STi ringland failures) in general. The hypercast pistons used in 04 thru present models is crap!!!!! Pull off the lot in your new STi, install forged slugs and be done.. My 04 blew #4 ringlands at 46000 bone stock!
Paidfor is offline   Reply With Quote
Old 05-20-2011, 03:04 PM   #145
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
After owning a WRX and 2 STI's, including the 2008 STI, I won't buy another turbo charged Subaru until they go back to forged, modifiy the pistons to be more robust, or maybe go DI to keep from detonating pistons to peices. The 02 WRX and 05 STi never had issues, but the 2008 lost #2 and #4 at 3500 miles and #4 again at 11,000 miles. 02 and 05 were stage 2 and had custom tunes by reputable tuners. The 08 had a dyno tune and many, many, many hours of road tuning to get it just right and still went through 2 engines. Ended up with forged pistons (mahles) in a new factory short block and it seemed to be running fine at 30,000 miles, but started burning lots of oil after 8k miles so I got rid of it. The first time it blew it was stock, second time was a safe stg 1 tune, and it was on a safe stg 2 tune when it started burning oil again on the forged pistons. Though the pistons are roughly the same from 04 - 11, it's the ECU's that changed. Once Subaru reflashed the 04 STi ECUs, they were fine and all 04 - 06 STi's seemed to easily hold up to stg 2 setups very well. 07+ is when the serious problems really started and worsened with the 08+. I have to believe it is primarily a function of how the ECU works and prevents detonation, as a good safe stg 1 or 2 tune doesn't seem to make any difference in the 07+ cars. These are just my experiences and observations, so subaru fan bois, please don't attack me.
silver arrow is offline   Reply With Quote
Old 05-20-2011, 05:25 PM   #146
trick3d
Member#: 202146
2010 evoru
GG
Great write up and detail. I'm also leaving Sub. Too many asshats and blown rings.
trick3d is offline   Reply With Quote
Old 06-03-2011, 02:43 PM   #147
YFZ450Lynx
Member#: 260299
2011 STi
Plasma Blue
I think mine just went, its a 2011 STi I am getting alot of blue smoke at morning start and WOT. ECU CEL goes on saying misfire on Cyl# 2 car idles very rough and alot of blow-by coming out the oil cap. Alot of oil in the intercooler as well. I have 3,000 Miles on it and I will be pulling this motor out myself no way I will trust anyone doing this kind of work on my motor. Plus warranty will just put the same junk made pistons back in it, I will go aftermarket now.
YFZ450Lynx is offline   Reply With Quote
Old 06-03-2011, 02:48 PM   #148
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
What kind of gas do you use?
Old 06-03-2011, 03:09 PM   #149
Bruins1982
Member#: 240365
2011 WRX Premium
Sedan WRB
Do you plan on replacing the short block with one that has mostly forged parts or just the pistons? Just curious.
Bruins1982 is offline   Reply With Quote
Old 06-03-2011, 04:00 PM   #150
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
The only component in the stock short block that isn't already forged is the pistons.
stock 2007 sti cracked ring lands 07pearlwhiteSti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 64 12-30-2008 01:41 PM
Anyone know OEM 2.5 sti piston ring thickness? bugeyes Built Motor Discussion 4 06-30-2006 11:14 AM
FS: 06 sti pistons rings rods and pins 4goodtime Private 'For Sale' Classifieds 1 03-06-2006 10:10 AM
sti piston ring spec one wicked wrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 02-15-2005 05:38 PM
is OEM STI piston rings strong enough?? skyline31 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 01-15-2005 11:17 AM
