Old 11-06-2008, 02:37 PM   #1
yzracer758
Member#: 59938
2009 MB C300
Subiesport Featured GC8
Default Getting ready for swap, What else should I buy?
I am in the process of waiting for my V6 motor to arrive so in the mean time I was wondering what things I should buy that way I can install the parts while the motor/trans are out of the car.
-I'm thinking a clutch for the JDM transmission, shift bushings, etc...
Any and all help would be much appreciated!
Thanks
-Jeremy
yzracer758 is offline   Reply With Quote
Old 11-06-2008, 06:49 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
clutch/friction disk
belt/idler pullies/tensioner
thermostat
belts
fluids
motor mounts
headders/uppipe -if so desired
heat shrink/e-tape/flex loom
pblaster
Old 11-06-2008, 07:02 PM   #3
yzracer758
Member#: 59938
2009 MB C300
Most of these parts are basically 02 -03WRX parts correct?
Old 11-06-2008, 10:47 PM   #4
mannac
Member#: 161038
2005 LGT
'72 Datsun 240Z
thermostat
belts
fluids
motor mounts
pblaster
The timing belt is so easy to change when you have the engine out and at your chest level
mannac is offline   Reply With Quote
Getting headgaskets swapped, what else should be done while motor is open? kaisersouse New England Impreza Club Forum -- NESIC 1 11-18-2005 10:07 AM
What else should I replace during center diff swap? zombiedog Transmission (AT/MT) & Driveline 9 04-23-2005 04:54 AM
Doing a rear diff. swap (non LSD to LSD); what else should I do while I'm at it? powerlabs Transmission (AT/MT) & Driveline 8 12-31-2004 01:14 AM
what else should i get p/p besides by vf22? djcttb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-12-2004 04:19 AM
Mods List - What else should I get? I am Imprezed Normally Aspirated Powertrain 10 08-11-2003 11:01 AM
