Old 11-06-2008, 03:53 PM   #1
AMR
NASIOC Manufacturer
Member#: 171509
Default 2008 Subaru STi - AMR Race FMIC / AMR T60R / AMR Direct Port Meth / 25psi @ 3800rpm
We apologize to the moderators for having "links" to our store.
Update:
Well after finishing up all of the customers vehicles, I had some free time to play with mine. Here is the conclusion!
Modifications:
- AMR BMI Cold Air System
- AMR T60R Bolt-on Turbocharger
- AMR 750cc Injectors
- AMR Race Front Mount Intercooler
- AMR TGV Deletes with match P&P
- AMR Direct Port Meth Injection
- AMR Electronic Boost Control Solenoid
- Turbo Hard-Pipe Inlet
- Equal Length Headers
- COBB AP v2.0 tuned by AMR
"STOCK vs NOW" Dyno Sheet:
Tuning Notes:
Boost: 25psi by 4000rpm
AFR: 10.5
Timing: Conservative
Thoughts:
Well all I can say is WOW. With just cam tuning and AFR's still in the 10.5 area I was able to achieve 25psi with the T60R by 4000rpm. The car is extremely violent. Breaks all tires loose. I know what you all are thinking, why dont I lean it out make more power? Well I am already 60wtq past the limit in which we take stock engines to (stock 201whp) and 19whp above the limit I take the HP too.
You can tell by the HP falling off near redline that the car could use some more timing along with bringing the AFR's to 11.5 should net another 20-30whp. Not to bad for 3-4 dyno pulls! But for now, I will leave her here!
New Product:
The release of our AMR Race Front Mount Intercooler!!!
What separates our FMIC from competitors?
- Perfect Fitment!!!
- Fits with FOG LIGHTS!!!
- NO eliminating of factory components!!!
- NO clearance issues!!!
- NO cutting to fit piping!!!
- Counter clock wise flow!!! (keeping the heat with the heat)
- 6061 U.S. Made Aluminum!!!
- Mandrel Bent Tubes for smooth flow!!!
- AMR HUGE 4" Thick 1000HP RACE CORE!!! (available in black or silver)
- T-Bolt Clamps!!!
- Available in wrinkle red, wrinkle black or brushed aluminum!!!
- Available with TiAL Blow off Valve or Flange for factory/aftermarket blow off valves.
- Made in the U.S.A. (in-house)
Quick Pictures:
-Rob
AMR is offline   Reply With Quote
Old 11-06-2008, 04:59 PM   #2
jbayless10
Member#: 141536
2006 20G'd WRX
Grey
looks great! I have been looking at the T60R for a little while know and have been wondering what it would look like on my 06 wrx. I have a 20g now and it spools good but lacks the top end power that I am looking for. Great turbo guys!
jbayless10 is offline   Reply With Quote
Old 11-06-2008, 05:46 PM   #3
wrxhard
Member#: 108091
Am I in the twilight zone? I thought there was a thread on this already? What happened?
Edit: Oh, the linking... I see. Great job anyways AMR. Keep it real.
wrxhard is offline   Reply With Quote
Old 11-06-2008, 05:46 PM   #4
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
I want your FMIC kit for my STI...too bad I'm not going to upgrade my turbo this year or probably next unless I come across some very spare cash
But the T60R seems like a great choice!! Can we get some specifics about this turbo? Numbers look great.
Steve.804 is offline   Reply With Quote
Old 11-06-2008, 06:38 PM   #5
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
How much of that core is behind the bumper skin?
Zornorph is offline   Reply With Quote
Old 11-06-2008, 07:40 PM   #6
jbpsti
Member#: 192057
04 WRX STI
JBP
Wow that looks amazing.
jbpsti is offline   Reply With Quote
Old 11-07-2008, 02:12 AM   #7
sysfailur
Member#: 135993
08 AW STi GTX3071
V-Mount, 18x12, 335 R888
BEASTLY! That looks so good.. uhg!
sysfailur is offline   Reply With Quote
Old 11-07-2008, 09:17 PM   #8
mrcoder
Member#: 93785
2005 STI
Default stupid fm
That's the stupidist front mount IC design i've ever seen.
Did AMR ever hold an IR camera to that thing to check the temps across it?
When both the hot pipe and cold pipe are at the top of an intercooler, as with this one, you can bet that 80% of the fins below the top 5 rows of cooler channels never get hot nor transfer any heat to the atmosphere.
That intercooler is 80% appearance, and 80% wasted metal.
AMR should have had the hot pipe enter at the bottom. If you did, your temp drop would have been better. The airflow would have not been impacted at all compared to the thing in the pictures.
mrcoder is offline   Reply With Quote
Old 11-09-2008, 01:29 PM   #9
SuperSTI
Member#: 67182
2004 Subaru STi
11.0 @ 128mph - 93/Meth
SICK!!
AMR +1
Hey Rob, my perrin fmic is going up for sale...guess what is next on my purchase list
SuperSTI is offline   Reply With Quote
Old 11-10-2008, 08:15 AM   #10
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
That's what I was thinking when I asked what % was behind the bumper skin. Glad someone elaborated the problem better than me.
Old 11-10-2008, 08:53 AM   #11
AMR
NASIOC Manufacturer
Member#: 171509
Our FMIC is designed to keep the factory fog lights and has zero fitment issues. Not only is fitment flawless but nothing is removed/cut off of the vehicle to fit this kit. Running the piping the way you are stating will not do anything as far as flow is conserned. We have done extensite testing and have found no difference in the inlet of the intercooler being in the top, bottom or middle. Tempature drops were the same regardless along with same pressure drop. Not to mention you will not be able to fit the fog lights. It is all about temperature.
We do not make a product just to make it. Our products go through alot of R&D time. Not to mention we track our vehicle to back-up our HP numbers.
The intercooler does its job and very well I might add. The core is extremely efficient. It all about the numbers.
-Rob
Old 11-10-2008, 08:34 PM   #12
DC5edSTI
Member#: 131261
2007 SWP STi 2.5xtr
2003 Corvette ZO6 400whp
Very sexy Rob. I dunno if I should go FMIC now, or just add Meth to the kick ass TMIC i have from you guys.... you guys just make to many kick ass parts.
I'll be stopping by the shop to see whats good over Thanksgiving break.
DC5edSTI is offline   Reply With Quote
Old 11-11-2008, 03:38 AM   #13
MRF582
Member#: 48219
. Always drive
the race line .
Especially considering that a bar/plate flows really well so there is not as much motivation for the air to go through the lower channels.
IR camera to check for heat. Brilliant. Do you think Sony's Nightshot camera could be rigged up to check for heat patterns? Maybe through some software or something?
MRF582 is offline   Reply With Quote
Old 11-11-2008, 07:25 AM   #14
smileyou
Member#: 152045
2003 PIA wrx
wrb..future ppg/fggreen
gg amr i give you a handclap for posting a suby finally. =) you have a late start...start kicking some ass in subies now.
smileyou is offline   Reply With Quote
Old 11-11-2008, 09:49 AM   #15
WRXPowa112
Member#: 158527
2006 STi BABY!!!!
10.72 @ 131mph
No one in the subaru community knows what that comment means.
AMR has been here since Subaru started and building/fabricating parts and race cars for over 50 years.
search button is our friend.
Great Job AMR!
What do you think about that cosworth ECU coming out?
WRXPowa112 is offline   Reply With Quote
Old 11-11-2008, 12:03 PM   #16
praedet
Member#: 56446
Any chance you will make the modifications necessary to run this on the 05-09 LGTs?
praedet is offline   Reply With Quote
Old 11-11-2008, 09:35 PM   #17
smileyou
Member#: 152045
2003 PIA wrx
Great Job AMR!
i was merely saying i wanted to see a sick amr subaru be posted. Next time read into the statement funnyguy.....****
