Old 11-07-2008, 09:01 PM   #1
pDubs
Member#: 149317
'95 BMW M3 (E36)
'05 Kawi ZX6R, '73 CB350F
Default Vf39 with td04 wastegate
Well I purchased a used vf39 from a guy off clubwrx.net to find that there is a td04 wastegate installed. here's some pics. Look at how close the vacuum line nipple things are and how close it is to the coolant line.
Here's my stock td04, notice the same wastegate (they both have the ring indented into the wastegate.
They are the same wastegates and as you can tell the guy drilled an extra hole so it will mount on the 39.
Here are pictures I have gathered of vf39s and their wastegates, notice that there is no ring and it is spaced farther.
The wastegate is completely different. So my question is why would he do this? I'm imagining it will hurt performance, I just installed blue 565cc injectors, walbro 255 fp, catless uppipe and am waiting to put this turbo in. My friend has a vf43 and the wastegate looks identical, could I swap wastegates? His turbo has shaftplay so I don't want to run the 43.
pDubs is offline   Reply With Quote
Old 11-07-2008, 09:47 PM   #2
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Wastegate actuator. He mightve done it because he either bought the VF39 without one or it started to fail. Or he was running (really) low boost. I dont seeing the actuator causing too much problems..its all about which one youre tuned for.
Old 11-07-2008, 11:54 PM   #3
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Looks great for running wastegate boost
Noah is offline   Reply With Quote
Old 11-08-2008, 10:56 AM   #4
pDubs
Member#: 149317
'95 BMW M3 (E36)
Is it going to hurt performance? Will I be able to run Cobb's OTS map because I need to in order to drive to get protuned? Thanks guys.
Old 11-08-2008, 11:30 AM   #5
03WRX-WRB
Member#: 167879
2005 Impreza
midnight blue
the spring pressure on a TD04 to a VF39 is only 2 psi different.
td04 is 8 psi wastegate
vf39 is 10 psi wastegate
it will not hurt the performance..
another good thing is the td04 wastegate you can tighten or loosen the spring pressure. you just need to add a little WGDC in the map and it will be good to go.
if you cant tune the map like i said just keep tightening the wastegate arm till you get you boost you are set for.
03WRX-WRB is offline   Reply With Quote
Old 11-09-2008, 12:10 AM   #6
pDubs
Member#: 149317
'95 BMW M3 (E36)
So does anyone know how bad this will affect the Cobb OTS map, is it going to be safe to drive 2 hours to get tuned?
Old 11-09-2008, 06:09 AM   #7
2.5ReallySexy
Member#: 167943
yes you can drive it to get tuned just be easy on it and try not to boost it too much
2.5ReallySexy is offline   Reply With Quote
Old 11-09-2008, 12:06 PM   #8
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
lower pressure wastegates are actually easier to tune with... they might hurt performance slightly by slowing spool...
You should be perfectly fine running the td04 wastegate... I suggest reading up on the basics of how tuning works and then log the car while driving to see if anythings wrong...
gto7419 is offline   Reply With Quote
FS: Used TD04 turbo with Internal wastegate actuator $150 Shipped OBO-PayPal ScoobyNubieToo! Engine/Power/Exhaust 18 01-18-2011 10:06 PM
06 wrx td04 turbo with forge wastegate Slightlymodified06 Engine/Power/Exhaust 8 07-01-2009 11:01 AM
vf39 with wastegate crack Clever23 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 07-22-2007 07:38 PM
VF39 Thread #1380392: Not hitting target boost (but seeing more with TD04 pill) ghibli99 AccessPort 8 09-09-2006 02:50 PM
TD04 with external wastegate Hondaslayer Normally Aspirated with bolt-on Forced Induction Powertrain 2 07-24-2002 11:09 PM
