Old 11-07-2008, 10:42 PM   #1
Cobb Tuning
Member#: 4803
Default Cobb 09 WRX Stage 1 Results
Just finished tuning our first 09 WRX, we are very pleased and impressed with the results! I think we will be seeing a lot of trade-in's in the near future... I'll let the graph speak for itself and have Mr. Bailey chime in a bit later This is all done on our in house Mustang Dyno.
Mods:
stock + SPT Catback
230 whp
238 wtq
Stage 1:
AccessPort stage 1 Tune
268 whp
290 wtq
Brandon
Surgeline Tuning
Old 11-07-2008, 10:43 PM   #2
Cobb Tuning
Member#: 4803
We just finished some initial testing with a new 2009 wrx. The results indicate that this car is a whole new beast and is indeed MUCH more capable that the 2008 version of this car.
The first major fact to relay regarding this car is that the turbo is bigger. The 2008 car was left nearly impotent with a tiny little turbo that was done before the fun started. Like many fans of turbo cars I think that bigger is better and in this case the choice for the new 2009 is perfect. In almost every regard this car performs as though the turbo is similar to an STi.
Now onto the specific results of our testing:
Baseline runs – Stock car with an SPT cat back exhaust
- Air Fuel Ratio: Note that the stock car stays near 14:1 at full boost until nearly 4000 RPM. This is a risky tuning strategy that best meets the standards of increasingly stringent emissions tests but by all rational standards has a negative impact on torque, responsiveness, and engine longevity. This “lean under full boost” tuning strategy has become the standard for all turbo Subaru’s.
- Boost: The stock calibration is a nearly flat boost curve of 14 PSI tapering to 12 PSI. This is a very flat boost curve in contrast to the 2008 car which peaks and tapers heavily.
Stage 1 testing – Stock car with SPT cat back exhaust and Cobb AccessPORT beta calibration
- Air fuel ratio: Lean under full boost is not acceptable. For this beta calibration I first changed the open to closed loop delays and switch points to allow appropriately rich Air to Fuel ratio’s as boost comes on. This richer AF ratio allows more consistent ignition timing. Under these conditions power and torque abound. In fact, I was able to make considerably more power and torque under these conditions with stock boost levels.
- Boost: With the fuel and timing strategies in place I began to raise the boost. After some trial and error I settled on a peak boost of 16.5 psi tapering down to 13 psi. The torque and power gains are impressive and in fact I was able to make MORE power and torque with slightly higher boost.
The next series of testing will be conducted after we install a Cobb Tuning downpipe. Overall I am absolutely impressed with this car and the performance is more STi than any prior WRX. Since the 09 wrx can be had for 24K, it represents a huge performance bargain. I’d be willing to bet the stage 2 tune will yield results VERY similar to a stage 2 STi.
Best regards
Tim Bailey
SurgeLine Tuning - A Cobb Tuning Premier Facility
As an aside its worth noting this turbo might just be the best upgrade option available for all you 2008 wrx and legacy owners.
Old 11-07-2008, 11:54 PM   #3
MattPersman
Member#: 139385
tuned by Tim or Jeff or you?
how does the car drive braking and handling wise compared to the 06-07 WRX cars? thanks
Matt
P.S. say hey to Tim for me
MattPersman is offline   Reply With Quote
Old 11-08-2008, 12:11 AM   #4
fastwrx25
Member#: 126441
03 bugeye
very impressive for stg 1. I wonder what stg 2 would look like on this dyno
fastwrx25 is offline   Reply With Quote
Old 11-08-2008, 12:30 AM   #5
BBaller018
Member#: 100465
08' legacy
quartz silver
sorry hard to read. Does that say 269 whp? with only spt catback + Tune? That's very impressive!
BBaller018 is offline   Reply With Quote
Old 11-08-2008, 01:27 AM   #6
Cobb Tuning
Member#: 4803
This was tuned by Tim Bailey. Added numbers in original post for those having a hard time making out the #'s
Initial driving impressions:
The top end on stage 1 is phenomenal! This easily feels like a stage 2 WRX from the previous years.
I didn't get a chance to drive the car with the stock suspension, it's running Cobb springs right now but the ride is very smooth and refined. Definitely daily driving friendly and suitable for spirited drives.
Braking is responsive and more than enough for the stage 1 setup, time will tell if pads would be recommended on a stage 2 setup.
Brandon
Surgeline Tuning
Old 11-08-2008, 01:43 AM   #7
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Stage 2 I would guess another 20hp/tq added. Impressive! Stage 2 + meth would be a monster -- 11's?
Dave D. is offline   Reply With Quote
Old 11-08-2008, 01:43 AM   #8
Cyni
Member#: 161822
2008 WRX
Dark Grey Metallic
Brandon, can you throw up an '08 WRX sheet or even an '08 STi dyno graph for comparison on your dyno??
Would help to see how well this turbo actually performs.
Cyni is offline   Reply With Quote
Old 11-08-2008, 02:22 AM   #9
jbpsti
Member#: 192057
04 WRX STI
JBP
Wow looks great. Seems like some high numbers for a mustang, but other than that 09 WRX's seem great.
jbpsti is offline   Reply With Quote
Old 11-08-2008, 02:39 AM   #10
Cobb Tuning
Member#: 4803
Matt
I tuned this one Matt. Hope all is well in the midwest.
Yes. I do need to make a trip back home.
Regards
Tim
Old 11-08-2008, 02:41 AM   #11
Cobb Tuning
Member#: 4803
Brandon or I will put up some comparisons from 08 WRXs and an STi or two.
I agree, this will be a great way to see the relative differences
Old 11-08-2008, 08:38 AM   #12
MattPersman
Member#: 139385
yes you NEED to make a trip back home, you need to ride in my car with the new setup ya know these nice back roads are itching to be terrorized
Regards
Tim
Old 11-08-2008, 10:21 AM   #13
sidewayz
Member#: 5810
2001 S366 2.5RS
Tim, did you make any timing changes when you tuned it or did you just tune for fuel and boost targets?
sidewayz is offline   Reply With Quote
Old 11-08-2008, 10:41 AM   #14
nhmtns
Member#: 94283
'05 OBXT
Min bil är svart
So...... how long until I can order an AP for my '09? Any chance I can pre-order one?
nhmtns is offline   Reply With Quote
Old 11-08-2008, 11:55 AM   #15
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Wow the 09's look to be quite promising. Does anyone know specs of this new, larger turbo? Is it still a mitsubishi turbo or is the WRX also equipped with an IHI VF series of sort?
I assume the size is right between the old TD04 and the STI's VF-39,43,48...
Steve.804 is offline   Reply With Quote
Old 11-08-2008, 12:06 PM   #16
jim1969
Member#: 34877
2005 Legacy GT sedan
Can you post up a graph of the stage 1 2009 WRX versus a stage 1 LGT? Us LGT owners have been waiting to see if the VF52 is a nice upgrade over the VF40/46.
jim1969 is offline   Reply With Quote
Old 11-08-2008, 12:11 PM   #17
jim1969
Member#: 34877
Also, what size injectors and fuel pump does the 09 WRX use comapared to an 05 LGT?
Old 11-08-2008, 12:28 PM   #18
juniordc2
Member#: 32481
2007 Impreza WRX
Satin White Pearl
good stuff, thanks for the testing and dyno graphs. i happened to drive an 09 WRX265 the other day and it was definitely an improvement over the previous year.
juniordc2 is offline   Reply With Quote
Old 11-08-2008, 01:26 PM   #19
VTGT
Member#: 132119
This might eat into Subaru's STi sales a bit. Good for us Bad for them.
That is until they bump the STi's power
VTGT is offline   Reply With Quote
Old 11-08-2008, 01:36 PM   #20
The Crowd
Member#: 189231
2009 WRX Hatch
Ok so I have an 09 WRX, and an SPT exhaust. So could I buy one of those $160 Tactrix cable setups and go down to my local tuner then? Forgive my ubernoobness.
Thanks.
The Crowd is offline   Reply With Quote
Old 11-08-2008, 02:28 PM   #21
The Crowd
Member#: 189231
2009 WRX Hatch
Also, would it be safe to assume the car would be capable of a high 12 second E/T when we start seeing Stage II setups?
Old 11-08-2008, 02:32 PM   #22
reaper702
Member#: 191827
2016 WRX
CWP
when does the accessport come out for the 09 wrx?? I told myself when I bought the car that I wouldn't mod until early to mid 2009, but with results like this ITS A MUST LOL. Those numbers are insane and can't wait to see stage 2.
reaper702 is offline   Reply With Quote
Old 11-08-2008, 03:07 PM   #23
milab21
Member#: 157833
2017 WRB STI
2007 WRB STI-sold
im sold on buying a 09 wrx now!!
milab21 is offline   Reply With Quote
Old 11-08-2008, 03:43 PM   #24
chanke4252
Member#: 173427
2009 WRX Sedan
Spark Silver Metallic
any idea when the maps will be released? or do they require more tunes before they decide what will work for a one size fits all map?
chanke4252 is offline   Reply With Quote
Old 11-08-2008, 03:47 PM   #25
law
Member#: 36842
2008 2007 Exige S
AW, Black
Or until they just get rid of the STI... You never know with the US market.
Unfortunately it "shouldn't" eat into STI sales at all, but too many buyers sit and focus on magazine times and HP figures, especially true in the US of A
Hell, all you have to do is read all of the 09 WRX is the greatest threads to figure that one out
I am HAPPY with the 09 WRX, great car for the money but put me in the STI any day. I had my 03 WRX for 6 years and that car really impressed me over the years, and since it was modified to near STI power I did not notice much of a difference there going from 03wrx to the 08sti. I for one HOPE they bump the power and go direct injection for 2010. I have to decide if I want to trade in the 08 sti for the 10' or keep the STI and throw down on a 08/09 M3... Decisions... or a house I guess
law is offline   Reply With Quote
09 WRX Stage 1 reflashed today fulltimeW.O.T. Car Part Reviews 9 08-27-2012 07:16 PM
Cobb 09 WRX Stage 2 Results Cobb Tuning Proven Power Bragging 214 04-08-2011 08:58 AM
09 WRX stage 1 jaysuss AccessPort 2 11-03-2009 06:56 PM
07 wrx stage 2 vs 09 wrx stage 1 alphaomega0 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 38 07-28-2009 07:39 AM
09 Wrx Stage 1 Vs Stage 2? STEELHQ AccessPort 34 07-17-2009 06:51 PM
