Old 11-06-2008, 09:12 AM   #1
mpaone
Member#: 3
2012 Geeteeeye
and 71' VW Gulf Beetle
Question newb AVC-R questions
OK, I've read the install and tuning guide 4 times and am still unclear on a couple of things...
1. I assume you retain the stock MAP sensor and t-in the new "pressure sensor" since the ECU still needs a MAP reading correct?
2. I've heard of check engine issues after removing the stock Boost solenoid. a resistor would work but which should I use on an EJ20G?
Lastly, since I had a PFC Boost control kit prior, are there any other settings I need to change back aside from turning the boost controller off?
TIA!
-Mike.
mpaone is offline   Reply With Quote
Old 11-06-2008, 10:29 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
1&2 yes keep them in place
but you have a power fc so you shouldn't need to keep bcs
and dunno
Old 11-06-2008, 10:40 AM   #3
mpaone
Member#: 3
2012 Geeteeeye
and dunno
OK well thanks for the response. 1- kinda thought that so good to confirm. 2- I'll try without the resistor and see if I get a CEL. 3- we'll see.
May just need to limp it over to my tuner and have him change what's needed.
BTW, anyone know what resistor to use? What voltage, resistance, etc (I'm NOT experienced in electronics)
-Mike.
Old 11-06-2008, 05:59 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
only way to tell would be to put a meter on it .. i would think it would need a higher watt rating
Old 11-10-2008, 04:30 PM   #5
mpaone
Member#: 3
2012 Geeteeeye
Lightbulb
Got everything in and after setting gear judge and a conservative boost of 1.0 bar and 60% duty it runs like a champ (no CEL for stock boost solenoid)
Getting it tuned Friday
-Mike.
Newb brake/rotor question pl1ght Brakes, Steering & Suspension 2 09-12-2005 05:14 PM
newb Initial D question Caddy Daddy Off-Topic 20 03-30-2005 05:30 AM
Newb with a question LotusGeun Newbies & FAQs 7 11-22-2004 04:00 AM
I am a newb, and have questions Minion Newbies & FAQs 25 05-17-2003 09:18 AM
newb Tranny Fluid question no1ukn0w Transmission (AT/MT) & Driveline 5 02-19-2003 11:55 AM
