Old 11-09-2008, 04:58 PM   #1
ksavage523
Member#: 192928
2006 wrx ltd
wrb
Default Ticking or fluttering when press gas????
I just put a new DP on and went stage 2 ( actually a local shop put the DP on). I re flashed the software with the AP stage 2 91 oct. I have this weird fluttering sound from the right sid of my engine. It is hard to pinpoint because when the car is in neutral and I rev it it does not happen only when I am driving. this did not happen when I had my stage 1 flash wuth just my catback. does any one have any idea? oh and it is a 2006 wrx and my boost seems to peak at about 14.5 (according to the AP). Thanks
ksavage523 is offline   Reply With Quote
Old 11-09-2008, 05:29 PM   #2
ponamy
Member#: 115511
2005 wrx /w babyseat
2015 Legacy
sounds like your wastegate is fluttering. also i believe the stage 2 should peak closer to 16 or 17lbs of boost
ponamy is offline   Reply With Quote
Old 11-09-2008, 05:32 PM   #3
ksavage523
Member#: 192928
2006 wrx ltd
wrb
is the wastegate fluttering going to damamage anything? should I disconnect my battery and reset the ecu and then re flash it with the stage 2?
Old 11-09-2008, 05:33 PM   #4
Miercoles Cansado
Member#: 166820
my ignore list
Is it ticking or fluttering? Could be two different things. Fluttering may be your wastegate, ticking could be your boost solenoid. Did the shop that did your upgrade use a aftermarket boost solenoid?
Miercoles Cansado is offline   Reply With Quote
Old 11-09-2008, 05:42 PM   #5
ksavage523
Member#: 192928
2006 wrx ltd
wrb
stock solenoid I think?? they just put the DP on.
Old 11-09-2008, 05:43 PM   #6
ksavage523
Member#: 192928
2006 wrx ltd
wrb
it almost sounds like when a kid puts a card on their spoke on a bicycle. it happens between 2500 3500 rpm
Old 11-09-2008, 05:47 PM   #7
jbpsti
Member#: 192057
04 WRX STI
JBP
Flutter happens when gas is pushed under low rpms.
jbpsti is offline   Reply With Quote
Old 11-09-2008, 05:49 PM   #8
ksavage523
Member#: 192928
2006 wrx ltd
wrb
it is hard to explain its like a th th th th th th th, the car seems to run great.
Old 11-09-2008, 05:52 PM   #9
ksavage523
Member#: 192928
2006 wrx ltd
wrb
yes it only happes between 2200 and 3300 ( just wen out and checked) it idles fine and when I rev it in neutral there no flutter. also when I let off the gas it stops. It only happen at low rpms and when I am on the gas.
Old 11-09-2008, 05:56 PM   #10
|Disso|
Member#: 155515
OBP pignose
IG-KuostA
Yes, I get this too. It's more of a fluttering sound, like leaves rustling around. It happens only when you're lightly or moderately applying throttle mid-RPM range. Thing is, I've ALWAYS gotten this sound, from stock, till now where I'm stage 2.
|Disso| is offline   Reply With Quote
Old 11-09-2008, 05:57 PM   #11
ksavage523
Member#: 192928
2006 wrx ltd
wrb
thanks guys, I do not care about the noise I just wanted to make sure nothing was getting damaged.
Old 11-09-2008, 07:18 PM   #12
sprewellnore
Member#: 153007
2007 WRX sedan
Black vf48
i think the fluttering noise are normal for stage 2,the sounds was like a helicopter underneath my car.but i don't have that noise now after turbo swap and tuned.
sprewellnore is offline   Reply With Quote
Old 11-09-2008, 07:20 PM   #13
Shohin
Member#: 170188
2016 STI Limited
Tis the wastegate . . . I hear it to in the RPM band previously posted.
Shohin is offline   Reply With Quote
Old 11-09-2008, 07:33 PM   #14
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Its not going to damage anything because its not a problem. Its the sound of the gasses going past the wastegate flapper as it opens and closes, doing its job regulating boost.
This is a mechanical sound, that you are now hearing because your downpipe is thinner and lets more sound come through to the outside.
When you flash the ECU, it is reset.
As for why your boost is low, that could be a number of things. You need to remember that this is a one size fits all map, so while it will work well on some cars, it will not work well on others. You can try adjusting the wastegate arm, but I usually recommend against this, as you are making a global change to boost, and everything about it will be affected, wastegate boost levels, how fast it spools and such, which makes the off the shelf map an even worse match.
What you need to do is eliminate any mechanical issues, like hoses off/loose and such, then, get a real tune on the car.
Its not going to be a faulty stock boost control solenoid, when those go bad, they just fail totally, leaving you with @7psi. At least 99.9% of the time anyway.
NOW, if you decide you hate the noise, try the WG arm adjustment, some have great results with it. HOWEVER, I highly recommend a tune when you do this. And if you are getting tuned, you may as well do a GM boost control solenoid (or Perrin) while you are at it.
Its just that adjusting the WG, while you can get to your target boost with that (sometimes), it changes how it gets there in such a way that it makes an already not great situation (off the shelf maps work ok, but not amazingly well), a possibly dangerous one.
Defiant Autospeed is offline   Reply With Quote
Old 11-09-2008, 08:17 PM   #15
ksavage523
Member#: 192928
2006 wrx ltd
wrb
thank you so much
Old 11-09-2008, 08:19 PM   #16
Davenow
Member#: 23676
We try
Old 11-09-2008, 11:34 PM   #17
DoucheAlmighty
Member#: 161492
2004 dubyarex 220whp
at 6000ft WRB!!!
it could also be an exhaust leak but most likely not if you havnt lost any performance and you hear it in a specific rpm band. However its just a thought, especially after a DP install
DoucheAlmighty is offline   Reply With Quote
Old 11-10-2008, 10:43 AM   #18
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTORŪ
yep WG flutter is normal to hear with a DP. especially when your reaching max boost. it wont hurt anything.
i used to hear it a lot in my buddied silvia.. sounded like pigeons in the engine bay!
AlxSti is offline   Reply With Quote
Fluttering sound and gas smell bdon22 Newbies & FAQs 17 07-27-2006 10:51 AM
Does anyone do this when pumping gas or is it just me? XyKo Off-Topic 28 04-23-2006 04:07 PM
Gas pedal creaking when pressing down balajc Service & Maintenance 3 06-23-2005 09:16 AM
flutter when acceleration cann STi Forum Archive 4 08-14-2003 07:33 AM
