Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Old 11-08-2008, 09:10 AM   #1
CoBB_tHiS!
Member#: 171730
2013 WRX Limited
Default Low Budget Handling!
I currently have an 2005 2.5rs with almost a fully stock suspension ( everything but 04 sti springs).
I will be purchasing the 17x7.5 Tarmac 2s in a few months and i want to keep my car flush without losing performance!
the sti springs feel stiff and handle very well. I have been reading about how everyone is having issues with lowering springs on stock struts but i don't have the money to spend on coilovers and just want to keep the stock struts unless one blows out.
Would it be safe for me to run Cobb Lowering Springs for a wrx on stock struts?
I need some advice and possibly pictures of everyone with Cobb springs!
thanks alot
CoBB_tHiS! is offline   Reply With Quote
Old 11-08-2008, 01:39 PM   #2
kumanchu
Member#: 146696
cobb springs will only put you in danger of : decreasing cornering performance and blowing your struts quickly
no danger of bodily harm, however they will make your car look pretty nice.
kumanchu is offline   Reply With Quote
Old 11-08-2008, 02:45 PM   #3
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
If you want to improve handling, you'd probably get more bang for your buck going with larger diameter sway bars (hell - you can pick up an OEM rear 20mm bar for under $100)
DrD is online now   Reply With Quote
Old 11-08-2008, 02:56 PM   #4
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Learn how to performance drive. An Autox school is < $100. Seriously.
When you get older, you'll learn it's the experience, no the equipment that matters (and not just with cars).
chimchimm5 is offline   Reply With Quote
Old 11-08-2008, 03:01 PM   #5
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
340Duster is offline   Reply With Quote
Old 11-08-2008, 03:11 PM   #6
ishmehb3n
Member#: 161866
2004 Subaru WRX
Java Black Pearl
YES! definitly. pick up a pair of swift springs. i have the same ones. work well with stock struts and handling is better. and definitly pick up some sway bars. cheap mod!
ishmehb3n is offline   Reply With Quote
Old 11-08-2008, 03:16 PM   #7
aveisone
Member#: 171364
2006 STi
im running 04 sti struts on jdm pink springs. nice solid ride with out too much bouncyness. minimal wheel gap and i can rock mad tyte jdm stickers yo! check the classifieds for some used sti struts already set up with springs. best budget suspension upgrade in my opinion.
aveisone is offline   Reply With Quote
Old 11-08-2008, 03:25 PM   #8
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
thanks alot
on a strict budget....this isnt happenin
look koo
or
performance
pick one
Old 11-08-2008, 09:39 PM   #9
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
If you want good handling on a budget - here is the absolutely cheapest way I can think of:
-RE070 takeoffs from an STi can be had pretty cheap - these are excellent summer tires - can't use em in the snow and probably not in the cold
-STi takeoff springs which you already have - ideally on upgraded struts, but they'll do okay on stock struts - $50
-Used swaybars in the 22-24 mm range - $150
-Camber bolts in the rear - $20?
-Used camber plates in the front - $100
That covers all the major areas and won't set you back a lot of money.
As Uncle Scotty points out though, if you want the car "flush" - by this I assume you mean you want to minimize wheel gap - you are giving up performance. The Cobb springs are too damned low.
As the Lowering Spring FAQ says in really big letters
http://forums.nasioc.com/forums/show...10&postcount=1
Two quick rules to remember before buying lowering springs:
1) Most lowering springs suck.
2) If it looks sweet, it's probably too low.
Butt Dyno is offline   Reply With Quote
Old 11-08-2008, 10:58 PM   #10
starcraft227
Member#: 193773
2004 WRX
JBP
save it up and buy shock/strut combo.
starcraft227 is offline   Reply With Quote
Old 11-08-2008, 10:59 PM   #11
starcraft227
Member#: 193773
2004 WRX
JBP
And swaybar will help a lot. look on sell/trade thread you will find a good deal.
Old 11-08-2008, 11:01 PM   #12
Butt Dyno
Member#: 17301
is the "dark side"
I hope you are not post whoring just to post a URL...
Old 11-09-2008, 12:05 AM   #13
Uncle Scotty
OK buy Nates beans
nah...just posting fs stuff
Old 11-09-2008, 08:53 AM   #14
CoBB_tHiS!
Member#: 171730
2013 WRX Limited
Now that i see the same comment from everybody, the sti springs on my car are starting to look lower and lower haha
Alrighty then, if i skip the springs and wait till later on when i need new struts, i want to buy sway bars!
With sway bars, i have found front sway bars for an RS but haven't seen a rear setup for my car. Is it the same for a wrx?
Please help
If i go 22mm in the front, what should i be looking to purchase for the rear?
thanks alot
Old 11-09-2008, 09:21 AM   #15
mla163
Member#: 104922
2013 BRZ
Get used sway bars and links. The springs you have are pretty damn good. I'm pretty sure the rear is the same for a wrx and an RS. The RS has a different front due to the headers. If you get a 22mm front, you'll want a 20-22 in the rear to balance it out. check the stickes.
mla163 is online now   Reply With Quote
Old 11-10-2008, 02:29 AM   #16
lostdrift
Member#: 192325
1998 98 2.5GT Legacy
Snow White
Yeah swap bars and new links would be best, you can truely feel the diffence.
lostdrift is offline   Reply With Quote
questions about service crew for a low budget rally team whitenoise77 Motorsports 13 03-17-2004 08:21 PM
A true low budget dinner meet. jetfan8178 Tri-State Area Forum 46 01-20-2003 12:53 PM
Come to Nino's low-budget IHOP meet and use the money you save to buy my P1's! Strider Tri-State Area Forum 2 01-16-2003 02:28 PM
('93-'01) Low-budget Impreza? Possible? HELP! Blitz Impreza Forum 17 07-31-2001 09:30 AM
Seeking Low Budget Advice akuhner Car Audio, Video & Security 19 01-29-2000 11:23 PM
