Welcome to the North American Subaru Impreza Owners Club Sunday January 25, 2015
Old 11-10-2008, 02:09 PM   #1
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
Default Will ACT streetlite flywheel for 98-03 fit 07?
Looking for a lightweight flywheel for my car (07 2.5i). ACT told me their streetlite #600185 will fit up to 03 RS only. They recommend to call the dealer and find out if an 02, for example, uses the same flywheel as an 07. If it does, then I am ok to use the 03 sreetlite for my 07.
Interestingly, here is what I found out:
Flywheel subaru # for 07 is 12342AA061
Flywheel subaru # for 02 is 12342AA040
Although they are different part #'s, the "061" is now sold as replacement for "040", except, one has to use 07 flywheel bolts. What does that tell us?
I guess we still don't know if the reverse is true--if 02 flywheel will fit an 07 (with the 07 bolts!).
Has anyone actually installed the streetlite on your 06-07 car?
Jerry Xu is offline   Reply With Quote
Old 11-11-2008, 01:29 PM   #2
Jerry Xu
Member#: 36629
07 2.5i
Anyone?
In fact, has anyone install any brand of light weight flywheel on a 2.5i ?
Old 11-11-2008, 09:18 PM   #3
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
Originally Posted by Jerry Xu View Post
Anyone?
if I remember correctly they make the i throw codes.
Subyroo2.5 is offline   Reply With Quote
Old 11-11-2008, 11:31 PM   #4
soulhassorrow
Member#: 150732
2011 WRXXXX
LRP
i think it'll only throw codes if you run a lightweight pulley with the lightweight flywheel!!!search in the drivetrain forum you'll def. find your answer
soulhassorrow is offline   Reply With Quote
Old 11-12-2008, 10:22 AM   #5
Jerry Xu
Member#: 36629
07 2.5i
Throw codes is ok with me. The fitment is my concern. I don't want to take everything apart and find out it doesn't quite fit...
ACT promised to call me back. But they haven't after 4 days.
Old 02-11-2009, 05:41 PM   #6
RoughSilver
Member#: 202652
Did you ever figure this one out? I am having the same trouble trying to find a flywheel for an 06 2.5i. The local clutch shop has even been on the phone with exedy, and all they can tell him is that there is a difference. It could only be weight, or something more severe. It will be nice to finally have an answer for this one!!
RoughSilver is offline   Reply With Quote
Old 02-12-2009, 01:42 AM   #7
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
yes it will fit. i have the ACT prolight on my 07 2.5i
olsen726 is offline   Reply With Quote
No longer looking. minifreak VIC Private Classifieds 0 04-23-2010 02:48 PM
Bully Stage 3 Clutch w/ ACT Streetlite Flywheel (06-07 WRX) BOTH FOR ONLY $500!!! kwan_1104 Canada Region Private Classifieds 1 08-06-2009 05:14 PM
FS:WA Exedy stage 1 clutch kit / ACT streetlite flywheel for 02-05 WRX (NIB) Jakes02 NWIC Private Classifieds 7 08-19-2007 03:16 PM
FS Socal: ACT Streetlite Flywheel for 5 speed WRX ComTekAuto Drivetrain 12 06-09-2007 11:05 AM
FS: Excedy Stage 1 clutch w/ ACT Streetlite flywheel for 04 STi chopchop Drivetrain 2 02-08-2007 06:26 PM
