Old 11-10-2008, 02:47 PM   #1
rojo-toro
Member#: 193753
Default were i can find a good headers for my ej16
Hi
I have a 2004 1.6 ej16 fwd impreza.
I started to improve the car; the next step is a decent headers.
The engine is not modified aggressively.
Does borla have solution for me?
Thank you
rojo-toro is offline   Reply With Quote
Old 11-10-2008, 06:54 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Does the car have dual port exhaust or single? Solutions exist for both but you may need slight custom work to mate it with the rest of your exhaust.
Old 11-11-2008, 12:00 AM   #3
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Originally Posted by rojo-toro View Post
Hi
Thank you
How long did it take you to do all that formatting?
I doubt Borla has anything, as they're based in the US, and to my knowledge, there has never been a 1.6l Subaru sold here. Custom, or a manufacturer that would have access to a 1.6 would be your best bet.
Counterfit is online now   Reply With Quote
Old 11-11-2008, 08:42 PM   #4
lonely_driver
Member#: 165531
2006 impreza 2.0i
they released the 1.6L in japan. i dont know much about the 1.6L but one would assume as it is also a H4 engine, there should be option from borla or replicas out there, depending on if it is single or dual port
lonely_driver is offline   Reply With Quote
Old 11-11-2008, 11:43 PM   #5
God
Member#: 148482
2085 CRYSMORE
LE BARON
why do you want a header for it?
God is offline   Reply With Quote
Old 11-12-2008, 12:01 AM   #6
Subaru_Pork_Wagon
Member#: 194069
I'd probably try the junkyard or maybe Kmart. I know it sounds silly but I've seen them there.
Subaru_Pork_Wagon is offline   Reply With Quote
Old 11-12-2008, 12:30 AM   #7
Counterfit
Member#: 124254
"The Scoobinator"
Yes, it's a boxer. The only Subaru's available with an inline engine are their Keicars (R1/R2, Pleo, Stella), the Sambar, and the Justy.
I also just checked Borla's site, like I figured, they don't have anything for the 1.6. Your best bet either Europe or the Middle East, since those were the only regions to officially get that engine in 2004.
Old 11-12-2008, 03:12 PM   #8
ciper
Member#: 15543
90BJ Legacy LS ABS
For farks sakes guys you act as if the EJ16 is a triangle or something. It shares essentially the same outward dimensions as the ej15 and ej18.
If it has single port heads then the later ej22 manifolds will fit. If it has dual port heads then any of the other manifolds will fit.
where can i get an ignition module (dis4-03 made by hitachi) for my ej16 spongemjc Private 'Wanted' Classifieds 9 06-17-2006 05:54 PM
Where can I find a good clutch for my car? ImprezaTs Canada Region Forum 4 01-30-2006 01:46 PM
Were I can Find or Buy a STI HID headlight adapter harness? thunderay Interior & Exterior Modification 7 10-23-2005 04:03 PM
Were Can I Get A Plug For My Recirc Hose On My Bov!!? wowthatisrandom Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 10-03-2004 11:23 PM
Were I can Find or Buy a HID Leveling switch and harness? thunderay Electrical & Lighting 1 09-03-2003 01:18 PM
