Old 03-24-2002, 10:22 AM   #1
wrxspeed
Member#: 16119
Silver Wagon
Question What is a safe EGT temp?
Read all the threads no clear answer.
What is a safe EGT (on the upper end) for our cars?
I seen 1600f (and climbing-autometer egt only goes to 1600) last night at 117mph in 4th with .11 boost on 93 octane fuel. M2 uppipe is only temp helper.
Please don't respond with "theory" only if you have a clue.
wrxspeed is offline   Reply With Quote
Old 03-24-2002, 01:53 PM   #2
shabby
Member#: 2682
93 Eagle Talon AWD
Theres really no answer here, most egt gauges have a 1650f/900c "redline" and thats what most people go by.
Normally if your going past that your probably running too lean and getting too much timing retard and loosing power.
If you want to be a dear and go past that and tell us that you put a hole in your piston, then by all means do so.
Personally my dsm is tuned to around 800-825c, anything past that and im getting knock and my timing is being pulled.
shabby is offline   Reply With Quote
Old 03-25-2002, 08:56 AM   #3
wrxspeed
Member#: 16119
Silver Wagon
Does anyone here have a clue? Subaru tech maybe? Or tuner by trade?
How hot is to Hot? - EGT's?
Old 03-25-2002, 11:53 AM   #4
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
aluminum melts at around 1700, so there are a lot of people that say 1600 is safe, but I like to think of this as a little close
picture plastic- yea, it melts at a certain temp, but approaching that temp, it'll bend and become pliable, so the same concept would apply to aluminum as well.
so you have the egt probe connected through the uppipe- if you do, I would even add some temp to that figure, just to be safe.
that's all your running and you got that temp? no boost controllers or anything like that?
my random thoughts
speed safely
Brian
Slvrblt is offline   Reply With Quote
Old 03-25-2002, 12:35 PM   #5
Z1 Performance
Member#: 9327
Depends where the probe is installed, and what probe you ahve, but assuming its a good quality one and in the #3 runner of the exhaust manifold, 2-6 inches from the head, we tune to a highest temp of 800C, or about 1500 F at the top of third gear...lean enough to make good power, rich enough to keep everything nice and happy...and together
Z1 Performance is offline   Reply With Quote
Old 03-25-2002, 12:48 PM   #6
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I've got my Defi proble installed about 6 inches outside the #2 cylinder, an the highest I've seen is 1550F under at about 15 PSi in 4th gear. Everything stock.
Tim
Old 03-25-2002, 04:35 PM   #7
odyss3y
Member#: 13621
so i guess if a probe was installed at the bottom of the downpipe, the gauge would be giving a bunch of crap data, right? i just had it installed today and the gauge is VERY slow, nothing like any videos i've seen of EGT gauges... (60mm greddy)
odyss3y is offline   Reply With Quote
Old 03-25-2002, 04:40 PM   #8
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
God has his on the DP when he made 311 RWHP and he says no more than 1,400 is the safe margin.
Leo
Leonardo is offline   Reply With Quote
Old 03-25-2002, 06:26 PM   #9
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
i had a 1600 reading in my egt at around 15lbs... what can i do to lower it?
YaZahX is offline   Reply With Quote
Old 03-26-2002, 02:38 AM   #10
WRxednEffect
Member#: 13105
I have stage zero and still get high egts, so unichip wont do it fully. you have to eithe tap dance between high egts or detotontion. I just shift when it gets to hot ,change yorudrivng style.
WRxednEffect is offline   Reply With Quote
Old 03-26-2002, 03:00 AM   #11
nmyeti
Member#: 4980
Yep thats about the worst place in the world for the probe. Might as well put it in the trunk at that point.
I put mine in the manifold just under #3. My max EGTs were about 910C a few short times long ago. My heads had cracks in them on the combustion chamber where the spark plugs come in... Seems 900C may just be a bit hot
The car seemed to make the most power at around 840-850C. Anything higher was just lean.
-Nathan
nmyeti is offline   Reply With Quote
Old 03-26-2002, 09:31 AM   #12
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Brian
the melting temperature of pure aluminum might be 1700F but we're talking about an alloyed aluminum. The material is safe past 1600F. Just realize that the longer you spend at that temperature, the faster diffusional breakdown of the material will be (heat speeds diffusion). If you're cruising on the highway for an hour at 1600F, then YES you ARE doing damage. But if you take the car up to 1700F just once for a couple seconds, then you're probably not really damaging anything, as long as you give it a cooldown afterwards. By cooldown, i mean coasting in gear with no throttle applied. That will really suck the heat out of the exhaust.
Remember that even though your exhaust temp might be 1600, that DOESN'T mean that the material in the engine block is 1600F. Heat transfer from gas to solid is pretty slow.
nhluhr is offline   Reply With Quote
Old 03-26-2002, 10:11 AM   #13
rak328
Member#: 3858
My car must be a freak cuz I only get 800c max and that only happens uphill at full boost. I got the Greddy EGT with the probe in cylinder #3. Mods are TXS stage 2 w/ up-pipe and mbc. I guess thats nice, clean, safe power!
rak328 is offline   Reply With Quote
Old 03-26-2002, 11:41 AM   #14
odyss3y
Member#: 13621
same here, i hit 750c uphill WOT in 5th... i have a CAI also which i'm told should raise egt's.
Old 03-26-2002, 03:32 PM   #15
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
with a spring-and-ball type MBC or TurboXS Stage2, you'll actually hit the highest temperatures at less than wide open throttle. I can cruise along at about 80% throttle or so (full boost) and the temp climbs rapidly but as soon as i floor the throttle, the temperature drops and stabilizes around 1450F.
Old 03-26-2002, 03:35 PM   #16
odyss3y
Member#: 13621
ya, in 5th on levelground i could only raise egt's by barely using the gas, boost was around +.5 bar, once i started going uphill WOT was the only way to raise the egt's
Old 03-26-2002, 04:19 PM   #17
WRxednEffect
Member#: 13105
what is it in the stage two that is reducing temps so much as compareed to stage zero and stage one?
Old 03-26-2002, 04:31 PM   #18
Vishnu Performance
Vendor
Member#: 14494
WRX Porsche 996
blue & black
Hello,
We measure EGTs off Cylinder One, which is the last cylinder on the fuel rail, and thus the one most likely to go lean and have the highest EGTs. We expect, within 4 inches of the exhaust port in for Cylinder One, EGTs of 1550-1600. That's what we consider a normal peak temperature to reach, depending on your fuel (race gas seems to run about 50 degrees colder than 91 octane). That's what our customers report (those who have mentioned EGTs). Remember that the engine is liquid cooled and water does a great job of pulling all that heat from the block. Higher than about 1600ish is starting to get a little hot for our tastes, but remember that some gauges read high when it's cold out.
On the race car (www.teamsmr.com), we see extended periods (races or practices that last 20-40 minutes) of 1550 degrees. These temps pretty much last all the time since the car is at WOT most of a race. The last time we took the motor out, the heads had no signs of any heat-related damage. Overheating is pretty obvious in aluminun so we're comfortable knowing that probably none of our customers will "test" the effects of high EGTs like the race car - and if they do, the race car has shown us that those temps are just fine.
Joel
Vishnu Performance is offline   Reply With Quote
Old 03-26-2002, 04:52 PM   #19
JenisonWRX
Member#: 6049
02 WRX & 99 RS
God I love iclub. Thanks Joel.
I have mine 3 - 4 inches from the the #2 piston. I get my highest egts when I'm partial throttle, about 1450 - 1500 F. I run 94 octane gas all the time
JenisonWRX is offline   Reply With Quote
Old 03-26-2002, 04:58 PM   #20
WRxednEffect
Member#: 13105
thx joel. hurry up with stage one damnit!
What is maximum safe boost? SupersonicWRX Newbies & FAQs 17 08-06-2004 11:40 PM
what is a safe way to send someone cash... Keith Off-Topic 17 03-25-2004 07:25 PM
What is the ideal EGT temp.? Leonardo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 12-22-2002 05:49 PM
Safe EGT temp range and...? BruceC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-12-2001 03:13 PM
