Old 11-11-2008, 12:04 AM   #1
ScubyMedic
Member#: 98203
2005 Spaceship/03WRX
both WRB
Default Car is NOT starting.... 05 Legacy LE. "ER CH" reading....
Hey guys, Got a tech question for you:
So one of my brothers customers has a 05 Legacy Limited Edition i. Auto, 40k miles. He says that for a week now, his car wont start. When he puts the key to 'On' position, the ODOMETER READS "ER CH". He had the car looked at to see if the Starter had problems, but it reads fine. He bought the car second hand, so he wanted to know if you guys might know whats wrong. I did a google and nothing came up.
Thanks guys.
Scubymedic
ScubyMedic is offline   Reply With Quote
Old 11-11-2008, 12:53 AM   #2
soulhassorrow
Member#: 150732
2011 WRXXXX
LRP
it could be alot of things bro, when did the customer last do a tune up. Usually if it's not the starter/alternator, it's an ignition problem. gl with the fix and hopefully you can narrow down the problem!!!
soulhassorrow is offline   Reply With Quote
Old 11-11-2008, 11:55 AM   #3
ScubyMedic
Member#: 98203
both WRB
I think the last time was about 5k miles ago.
What does ER CH mean anyway? I cant find it in the forums.
Old 11-12-2008, 11:40 PM   #4
ScubyMedic
Member#: 98203
both WRB
Bump.. customer still needs help with this.
Old 11-12-2008, 11:54 PM   #5
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
A guess mind you, but it probably means "Error-Charge". An 05 is awfully new to be having serious tuneup related problems. A fuse, an ignition/charging system short or loose connection, maybe even a faulty battery. Can't believe a diagnostic computer doesn't give you at least a clue. Good Luck
Buck Rogers is offline   Reply With Quote
Old 11-13-2008, 12:35 AM   #6
kingbobdole
Member#: 85055
1989 XT-6
so does it crank but not start or just not crank?
kingbobdole is offline   Reply With Quote
Old 11-13-2008, 11:52 AM   #7
ScubyMedic
Member#: 98203
both WRB
^^ it doesnt crank. only lights come on when in 'ign' but no turnover, no 'clicking' from the starter.
Old 11-13-2008, 11:53 AM   #8
ScubyMedic
Member#: 98203
both WRB
Ill let him know to double check all the fuses.
Old 11-13-2008, 12:37 PM   #9
Cocoa Beach Bum
Member#: 17355
That car can't issue "ER CH" but it can issue "Er HC" which means problem with high-speed CAN (Controller Area Network). General diagnosis procedure is at http://thel7.com/TSB/11-81-06.pdf but car probably should be towed to dealership.
Cocoa Beach Bum is offline   Reply With Quote
Help me my car will not start!!!!! 4npower Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-01-2003 11:36 AM
Car will not start!?! Bryan C Electrical & Lighting 6 08-01-2003 10:27 PM
car will not start after installing CAI? Solomon Legacy Forum 25 07-30-2003 10:38 AM
Now the car is not starting Redneck Ricer Normally Aspirated Powertrain 13 12-23-2002 04:05 PM
Car will not start, at Evanston for Repair Yotsuya Mid West Subaru Owners Club Forum -- MWSOC 14 01-23-2001 11:34 AM
