Old 04-26-2001, 06:03 AM   #1
Kalins1
Member#: 484
2003 Baja
Custom Silver and Red
Question Help! What is that squeek!
Has anyone had a squeek coming from underside their car while they were rolling or under slight power (under 10 mph)?
Thanks,
Sean
Kalins1 is offline   Reply With Quote
Old 04-26-2001, 06:48 AM   #2
cd3575
Member#: 5456
2001 RS
Post
I had a really annoying squeek comming from under my shifter and I took it to the dealer to have it looked at. It took them like 2 hours to find and 2 seconds to fix,
There was a peice of metal, like and exhaust hander that was not bent all the way back and was rubbing the frame, nothing major they just bent it back with some vice grips
cd3575 is offline   Reply With Quote
Old 04-26-2001, 07:03 AM   #3
Kalins1
Member#: 484
2003 Baja
Post
Hmmm....This sounds like a rotational squeak. I hope it isn't that dreaded rear wheel bearing/differential problem! It has never made any sounds before.
Sean
Old 04-26-2001, 07:24 AM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Question
again...i say... stock or aftermarket exhaust?
i had an annoying squeak... ended up being the exhaust bumpin and grindin...
j. www.subiegal.com
Old 04-26-2001, 07:26 AM   #5
J Colman
Member#: 1259
1999 Impreza RS
Rally Blue Pearl
Post
I've got a shake, rattle, and roll. My heashield is a little loose
J Colman is offline   Reply With Quote
Old 04-26-2001, 07:29 AM   #6
JayE
Member#: 5023
1998 RS
RBP
Post
Sean, my car has an occasional squeak at low speed that i'm 99% sure is just the brake pads. If you pads are worn, they will definately squeak to let you know, but sometimes they are noisy anyway. Easier to check that a wheel bearing, too.
JayE is offline   Reply With Quote
Old 04-26-2001, 09:23 AM   #7
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Post
My car occasionally does the left-front-wheel squeak. It is very annoying and can get very loud. At first I thought it was a a rock caught between the stone-shield and rotor but after taking the wheel off, the caliper off, and rotor off, and the stone shield off... nada.
Squeak came back, the very next day.
It is a rotational scuffing squeak sound, almost like the semi-metallic brake pads are hitting the rotor and squeaking part-way around the revolution. But I had this noise *before* I put on the Axxis pads.
Subaru dealer won't even acknowledge it and I quite frankly don't have the money to take it back so they can lie to me some more.
So I just turn up the damn radio.
-Marc
remarcable is offline   Reply With Quote
Old 04-26-2001, 09:26 AM   #8
Kalins1
Member#: 484
2003 Baja
Post
That sounds like what mine is doing, Marc. But unfortunately, I don't have my brakes on when it does it. I'm going to pull the rear drums off tomorrow to see if they are worn. Maybe they are all the way out and are not letting go of the drums when I let off the brake. I hope...I hope, I hope.
Hey, JayE, are you going to the meet at Old Man's Cave on Sat.? I won't be there if I can't this problem fixed.
Old 04-26-2001, 09:29 AM   #9
Homer
Member#: 6056
Post
Yeah, JayE, you should come to Hocking with us.
Sean, now that you mention it I do have a sound sort of like that. I always associate it with the brakes, just a whining sound, but it's intermitent...
-Silas
Homer is offline   Reply With Quote
Old 04-26-2001, 09:34 AM   #10
Kalins1
Member#: 484
2003 Baja
Post
Silas....trying to fool us by changing your name? ha ha....Must be running from the cops.
Mine is a definite squeal.....It is like the normal metallic brake pad squeal that you normally hear when you apply the brakes but now it is doing it without the brakes being applied.
Old 04-26-2001, 01:02 PM   #11
Poseidon
Member#: 4864
2004 WRX
Post
Have you checked the CV-joint?
Jordan
Poseidon is offline   Reply With Quote
Old 04-26-2001, 01:08 PM   #12
remarcable
Member#: 2362
1999 Legacy Outback
Post
This is a perfect description of what my car is doing.
It is going to have its 30k checkup pretty soon so I will get that addressed.
Old 04-26-2001, 01:22 PM   #13
Kalins1
Member#: 484
2003 Baja
Post
The CV joints aren't clicking when I am making hard turns, so I don't think it is them. I'll do a visual inspection though.
Old 04-26-2001, 06:38 PM   #14
Kalins1
Member#: 484
2003 Baja
Have a Nice Day?
Darn it....I drove her hard going home from class tonight and couldn't get it to make the noise! This really sucks.
Old 04-27-2001, 12:26 AM   #15
RedBrighton96
Member#: 1246
2011 WRX
Post
I'm sure Jay will proably tell you, but he can't make it to the meet. Well last time i talked to him he couldn't. His parents are in town for the weekend so he'll have to make the next one i suppose.
Hey Jay, i'll see you at work sometime. Go UPS!!
Hey Sean, when you are driving in a straight line while it is squeaking and you slightly turn the wheel one way or the other, does the squeak go away? WHen my brakes were squeaking when i was driving straight, a slight movement of the steering wheel would make it go away. And once i had my brakes cleaned and adjusted it went away and hasn't come back since. And it would just do it all of the time even when i wasn't using the brakes.
Rob
[This message has been edited by RedBrighton96 (edited April 26, 2001).]
RedBrighton96 is offline   Reply With Quote
Old 04-27-2001, 12:45 AM   #16
Homer
Member#: 6056
Post
Yeah, this is my at work identity. I figured I'd go with one of my modern day heros! Only problem is I'm now spending too much time on the I-club at work and at home...
-Silas
Old 04-27-2001, 12:45 AM   #17
Kalins1
Member#: 484
2003 Baja
Post
That is exactly what it is doing, but only at low speed. And it ocilates...it goes squeak, squeak, squeak as the wheels turn. It isn't a long continuous squeal.
Thanks,
Sean
What is that noise? tirkish Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 07-08-2010 03:44 PM
What is that thing called that the water company has JjSwee Off-Topic 5 03-09-2005 05:44 PM
Quick question; what is that paint that has the effect of marble you can get wal-mart ChosenWon Off-Topic 6 11-24-2003 03:05 PM
What is that place that makes Magnetic Decals??? mykrrrr Mid West Subaru Owners Club Forum -- MWSOC 4 01-09-2002 02:03 PM
