Old 12-05-2010, 11:12 AM   #276
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Originally Posted by MRDOBNS View Post
what do i do if i open my remote and there is no sticker with the serial number?
What does your remote look like?
RexyGirl is offline   Reply With Quote
Old 12-05-2010, 11:13 AM   #277
RexyGirl
Member#: 63616
with mods :)
Originally Posted by B Norton View Post
Good stuff here. Thanks REXYGIRL for the info you started.
I have had some issues with mine. Now mainly trying to get the other 3 doors to unlock with the fob after unlocking the drivers door. I usually have to press it three or four times before getting it to work.
Man I wish I had a trunk release button on the key fob for my 2.5i. My 2010 Forester does and I love it!
You're welcome....
Have you checked the battery?
Old 12-05-2010, 11:29 AM   #278
MRDOBNS
Member#: 261165
2004 Forester STI
Tear drop remote
MRDOBNS is offline   Reply With Quote
Old 12-05-2010, 08:34 PM   #279
stimanmark
Member#: 235859
2004 WRX STI
World Rally Blue
I noticed the directions on the back of my remote (i have an 04 STi) about buzzer chirp ON/OFF and i did it when i first got my car. I wanted it to chirp to ensure that i was arming my car......one day it stopped doing it, tried to reprogram it and the only time it beeps is when i hit the arm button the 3rd time.....i would like to get it to chirp everytime i lock or unlock with the remote...........help please
stimanmark is offline   Reply With Quote
Old 12-05-2010, 09:22 PM   #280
Donzo
Member#: 95337
2012 Jeep Overland
The "chirp" on my '06 stopped working in second year I owned the car. The dealer didn't want to fix it either. Not sure why. It's not an issue anymore since I usually just lock 3 times until the Supertones beep.
I'm looking for a good remote start system for my girlfriend's 2011 Impreza (fully loaded with the TomTom). Any suggestions?
Donzo is offline   Reply With Quote
Old 12-16-2010, 10:01 PM   #281
carlosdevil10
Member#: 221625
2002 WRX Bugeye
blue
my factory alarm does not respond to the remote at all, i already change battery and no result alarm wont stop making noise when door is open cant disarm the alarm
carlosdevil10 is offline   Reply With Quote
Old 12-16-2010, 10:14 PM   #282
RexyGirl
Member#: 63616
with mods :)
Make sure you put the battery in the right way...sounds stupid, but it happens.
If that doesn't work, the remote is probably toast...
Old 12-17-2010, 07:27 AM   #283
Gluis
Member#: 245584
07 Impreza WRX STI
Originally Posted by Gluis View Post
Hello,
My Alarm does not work. It chirps and blink the lights while arming/disarming, it honks the horn if I keep the lock button pressed, but if I open a door or the trunk while armed it does not activate.
I have a TT installed, but I disconnected it to test if that was the problem, with no success. I also disabled DRL's, which I had not tested to see if that is the problem yet.
It used to work before, when my car was stock. I then extensively modified it, but besides some led Lights, that's all I had done electrically.
Any help will be appreciated
Regards,
GS
Hello Again,
Any suggestions on this?
My alarm still does not sound or blink lights if doors or trunk are opened while "armed"
Please help.
Best regards,
GS
Gluis is offline   Reply With Quote
Old 12-17-2010, 11:39 PM   #284
carlosdevil10
Member#: 221625
2002 WRX Bugeye
blue
that was my first idea but know i already change the battery for a new one. And still the remote does not do anything could it be the remote or the alarm ?
Old 12-19-2010, 05:20 PM   #285
99imprezd
Member#: 198964
2015 WRX
crystal white pearl
Ive got a 2003 Impreza TS. Car didnt come with a remote start controller but I am assuming its prewired for one. At the local Upull it I can find a few in 99-2000 outbacl legacies, will these work? Also, heres a pic of my wires under the dash that I think go to the remote start.. am I correct? http://s829.photobucket.com/albums/zz220/dviousdsign/?action=view&current=harness.jpg
99imprezd is offline   Reply With Quote
Old 01-02-2011, 02:29 AM   #286
AWD>
Member#: 173936
Default 02 Blue and red button work for an 07?
Hi all, happy new year! I recently sold my bugeye and found an extra key fob (blue and red button) that wasn't programed for the car and I already had two. I have an 07 hawkeye that only came with one key/fob. I'm wondering if the unprogrammed blue and red fob can be programmed for my 07, has anybody tried this with success? Help? Thank you!
AWD> is offline   Reply With Quote
Old 01-09-2011, 09:21 PM   #287
kieranlavin
Member#: 248178
05 WRX
I skimmed this topic and didn't see any similar problems. I did a search as well and didn't see anything either. Kind of odd problem (story of my life!)
My wife and I went out for dinner tonight and took her car (05 wrx non sti) We came home and getting out of the car the remote didn't work to lock the car. She thought it was the battery so I went inside. She came in, replaced the battery and the remote didn't work so she threw it at me and asked me to fix it. I went out with both remotes and neither worked. I tried re-programming them and nothing. I came inside and decided to play with the contacts. On my car the remote was dead even with a known fresh battery so I wound up needing to pry the contacts into position on the negative side. I pried them up a bit on her remote and also discovered that... she had put the battery in backwards. Voila... problem solved, right? Wrong. The remote works but it ONLY works when you are either in the car, immediately next to the driver side door, or on the passenger side but with the remote touching the glass.
So the problem seems to be the range. The problem is that there is no range Below is a list of things I've tried... wondering if anyone has any suggestions:
- replaced batteries with known fresh ones (I recently went through problems with the remote on my car and all of the batteries wound up being good once I figured out the problems with the remote itself.
- pried up the negative contacts to hopefully give better contact/conductivity
- cleaned all contacts with rubbing alcohol
- successfully reprogrammed both remotes
- put it into and out of valet to see if that made a difference
Any ideas? Seems like it's an issue on the receiving (car) end of things?
kieranlavin is offline   Reply With Quote
Old 01-12-2011, 10:00 PM   #288
kieranlavin
Member#: 248178
05 WRX
Problem mysteriously solved itself just as mysteriously as it started
Old 01-14-2011, 04:06 PM   #289
sab0nis
Member#: 269124
2005 WRX STI EJ207
Blue Mica
I installed Apexi TT according manual:
http://www.scoobymods.com/turbo-time...=&threadid=228
You can either connect the harness, or splice into the factory wires if you did not get a harness. Only attach the 12+ and the Ignition wire, do not attach the accessory wire to the turbo timer.
The accessory wire at the ignition juction must be tapped and a length of wire must be run to the alarm module located above the fuse panel. Look directly above the fuse panel and you will see it. Remove the connector and look for a dark green wire with a black strip (there are two green/black wires, make sure it's the darkest green of the two). Cut the wire and attach the length of wire to the module side. Tape off the extra green/black wire.
Another juction must be made from the accessory wire from the ignition harness. This must go to the other alarm module located in the center console.
Remove the plastic piece that surrounds the parking brake (piece where the mirror controls are). Pull up from the back, it's just a snap in piece.
There is a grey wire that goes to the sensor module. You must cut this wire and splice the accy wire on the module side. Tape the extra grey wire to the side. This splice will allow the alarm to be set while the TT is counting down.
Ground the TT, and then mount the remote panel.
Test it out and then put the car back together and have fun.
but I can't lock my car and arm security system while TT is counting down. Perhaps, I chose wrong black/green and grey wires?
Some pics of the wires:
http://www.imgplace.com/viewimg220/5287/75tt2.jpg
http://www.imgplace.com/viewimg152/1940/25tt.jpg
Please, help. Thank you.
sab0nis is offline   Reply With Quote
Old 01-14-2011, 04:15 PM   #290
sab0nis
Member#: 269124
2005 WRX STI EJ207
Blue Mica
Old 01-16-2011, 08:50 AM   #291
jtslc
Member#: 158211
I have an 05, lost the remote and just changed the battery. Every time i unlock the car, the alarm sounds. I see the 3 key turn solution but is there anyway to reset the alarm without the remote, so this does not happen any more? I understand this has probably been addressed, so my apologies in advance for my newbness. Try to search as much as possible. Thanks.
jtslc is offline   Reply With Quote
Old 01-17-2011, 10:53 PM   #292
.David.
Member#: 114774
Originally Posted by amac04sti View Post
for all those attempting to disengage the valet mode for a 2004 and up sti. please disregard this thread and read your owners manual under section 2-17. it is written in plain english with 2 steps rather then "see above" on the beginning of this thread where it tells u 10. all u do to engage the vallet mode is press and hold the lock button for 2 seconds or more on your remote while the drivers side door is open and everything else is closed. and the same goes for disengaging it, but instead you hold the unlock/disarm button while the drivers side door is open for 2 or more seconds.
Ahh.. thank youuuu
.David. is offline   Reply With Quote
Old 01-22-2011, 11:54 PM   #293
StealthWagon
Member#: 30823
2004 WRX STI
Blue/Gold
This seems similar to a problem I am having right now. My car was not responding to any keyfob buttons so I replaced the battery, resynced it and everything semed back to normal...the next day same thing happened so I knew it wasn't the battery. I realized that the only location that this happens is if I park on the street in front of my condo building. If I park in the back or sides it works fine, but for some reason directly in front of the building (for the whole block) the key will not work.
Today I parked out front and found that the alarm system worked if the key was touching the car, but one step away it didnt. It seems that something is blocking/limiting the range of my key when I am in this location, (everywhere else the key has good range). Besides not parking here, does anyone have any ideas?
StealthWagon is offline   Reply With Quote
Old 01-23-2011, 12:40 AM   #294
stimanmark
Member#: 235859
2004 WRX STI
World Rally Blue
The horm/chirp does not work when I press lock or unlock. There is no sound:
**Try seeing if your alarm chirp/horn is disabled. (See above)
**If not, try information in this thread:
http://forums.nasioc.com/forums/showthread.php?t=608657
If I forgot anything, let me know and I will add it!!
One thing that will help people jump to the final fix on the link above.......the DIY fix is on page 17
Old 01-25-2011, 09:42 PM   #295
Tesh
Member#: 266270
Chapter/Region: HIIC
'11 GR.STI.SDN
Originally Posted by wolverine_man View Post
Would it be too much to ask for someone to create a switchblade key for the 2011 WRX? I mean, the fob is bigger than my balls and the the key, well, it's huge.
THIS> AutoLoc FlipKey Kit
Tesh is offline   Reply With Quote
Old 02-10-2011, 04:56 AM   #296
zephyr2oo5
Member#: 273251
I have an issue that I didn't see discussed but may have missed it, has anyone had a problem with keyless entry reprogramming where a turbo timer is present? I had my 02 WRX at the dealer on Monday and they couldn't get it to program either, and said that it may be due to the timer. Anyone else have this problem? Any ideas how to get it to work? Anything will help thanks
zephyr2oo5 is offline   Reply With Quote
Old 02-23-2011, 01:39 PM   #297
csmith335
Member#: 150530
my problem may be similar to the one above me but i have removed my turbo timer:
i busted my old keyless entry fob (02 blue/orange one) so i ordered a new one and took it to the dealership to program and after trying for a while, they said that for some reason it wouldnt work and it has something to do with the car itself?
I do have an accesport hooked up and never had problems with the keyless entry before i got the new fob. They said it owuld be $100 and hour to diagnose problem!!
PLease help, im sure this has happened to someone else. Dk if it matters but i used to have a turbo timer installed and the one wire had to be cut so the alarm wouldnt go off while cooling at idle..have since removed. PLease HELP GUYS!!
csmith335 is offline   Reply With Quote
Old 02-23-2011, 11:36 PM   #298
jobywrx
Member#: 115036
2005 WRX
Default Keyless not doing anything
I cant seem to find a scenario on here where the factory keyless entry system/alarm completely doesnt work. Ive done all the procedures to reprogram the remotes, changed batteries, and checked fuses. One morning i went to unlock my car and nothing. I cant get it to do anything. Ive tried messing with the contacts and also tried with my spare remote.
Thanks
jobywrx is offline   Reply With Quote
Old 02-28-2011, 10:53 PM   #299
r2t2
Member#: 275191
2002 Impreza WRX
Question Flashing Security Light
When I removed the clock to do the 510 resistor fix I noticed that the Security light was indicating the car was in Valet Mode. I've searched and tried just about every possible combination of pressing/holding the remote buttons to to get it turned off. No such luck! It flashes twice, pause and flashes twice. I've opened the door and held the Unlock/Disarm button down until my thumb started to cramp... To no avail... Any ideas? Should I disconnect the battery? If so, how long until the ECU is reset?
Help!!! Help!!! Help!!!
r2t2 is offline   Reply With Quote
Old 03-16-2011, 03:34 PM   #300
fugawe54
Member#: 195556
Default Is it the alarm
Lights are flashing will not turn off had to pull fuse hazard/horn no turn signals were to look 06 wrx
fugawe54 is offline   Reply With Quote
Factory Alarm + Keyless entry from 04 FXT Skidd Interior/Dressup/Audio & Security 0 01-22-2009 08:26 PM
Factory alarm/keyless entry install - Anyone want to help?! NickWRX Tri-State Area Forum 3 07-06-2008 09:22 PM
All you need to know about ass hair. WRick Off-Topic 22 01-23-2006 07:22 PM
Factory Alarm / Keyless entry Woody Vancouver Impreza Club Forum -- VIC 3 04-21-2002 11:51 PM
Factory alarm/keyless entry on MY01 Safir Car Audio, Video & Security 1 02-08-2001 01:01 PM
