Old 03-16-2011, 05:54 PM   #301
h2oridr
Member#: 151936
2003 wrx
Default reprogram
I have an 05 STI cluster in my 03 and went to program a new key fob and the car will not go into program mode. Had battery disconnected tried a bunch of times but no luck. Wondering if the cluster has anything to do with this. Anyone run into the same problem?
h2oridr is offline   Reply With Quote
Old 03-17-2011, 06:57 PM   #302
germotlp
Member#: 182512
2004 WRX Wagon
Default 2007 sti key fob and 2004 wrx wagon key fob
My current key fob for my 04 wrx wagon is acting up. It will sometimes unlock/lock my doors but after mashing the buttons several times. I have already changed the battery, still giving me the same issue. My friend who had a 2007 sti gave me his key fobs. I was wondering if it will work on my 04 wrx wagon?
germotlp is offline   Reply With Quote
Old 03-17-2011, 11:23 PM   #303
xchristhompsonx
Member#: 264602
it should, I didn't have a key fob so I went to the dealership and they quoted me $180 for the fob and to program it. that's nuts. I found one on here for the 02-03(I have an 05) for $20..figured I'd give it a shot, just programed it two nights ago myself and it worked, and it was pretty easy. just search around and follow the steps..good luck man
xchristhompsonx is offline   Reply With Quote
Old 03-20-2011, 01:07 PM   #304
BugeyedWREX
Member#: 141734
02 BUG-I WAGON
EJ25 Hybrid, 314HP- 280tq
I have had problems with my keyless entry/ security system since i bought my car used over a year ago, I eventually just unplugged the module under the center console cause it would go off but i couldnt program it. I found the horn on the passegner side strut tower but its not plugged into anything. Any ideas on what could be wrong?
-Security module
-Unplugged horn on passegner strut (culprit?)
-light on fob works when button is pressed, but fob doesnt lock/unlock/arm/unarm or program.
BugeyedWREX is offline   Reply With Quote
Old 03-23-2011, 03:04 PM   #305
tmaung
Member#: 272351
2011 WRX STI Sedan
Anyone know how i can use my key fob to open the windows?
tmaung is offline   Reply With Quote
Old 03-24-2011, 06:00 PM   #306
germotlp
Member#: 182512
2004 WRX Wagon
@xchristhompsonx dude it worked thanks. Whats weird is the dealer said it wouldnt work at all. Haha. Saved me $177 dollars!
Old 03-25-2011, 01:45 PM   #307
xchristhompsonx
Member#: 264602
not a problem man, glad I could help. they told me the same thing, aha
Old 03-26-2011, 07:32 PM   #308
bkwrx
Member#: 78633
hi guys i have a problem with my 2002 wrx sedan, the horns just started to going off and will not stop. i disconnected the key less entry module but still goes, the exterior lights are not flashing, i do have an viper alarm system but that seems to be working fine, what's the possible fix, i tried what the owners manual says for placing the security system in valet but mine does not have a factory alarm, thanks
bkwrx is offline   Reply With Quote
Old 04-13-2011, 07:52 PM   #309
sube4x4
Member#: 254712
Is there a way to put my car in valet mode with no remote? When I bought the car (2004 WRX Limited) it did not come with a remote. I accidentally left the parking lights on over night and killed the battery. Then I charged the battery and every time I lock my door then unlock it and open the door, BAMMM!, horn starts going off until I cycle the ignition three times. Thanks for the help.
-Cody
sube4x4 is offline   Reply With Quote
Old 04-28-2011, 01:03 PM   #310
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
-Cody
Nope....need a remote. Or disconnect the alarm.
RexyGirl is offline   Reply With Quote
Old 04-28-2011, 05:13 PM   #311
elizerkim
Member#: 222081
2012 Charger SRT8
PitchBlack
sigh...
can't get it to work spend 1 hr on it... and losing my mind lol.
2007 sti.
First off the security light you mean the little red light on the center of your gauge cluster thingy?
Is that supposed to light up when you press the alarm? it does not for me...
Only thing that happens is the hazards flash a couple times. That means its not in valet mode right?
Ok... with the key in the ignition...
i open the door and close it. Then i do the lock to on 10 times...
i cant get it to make a beeping noise...
All doors are unlocked as well.
I have a Acessport stage 2 on it... should i flash back to stock or does that have any effect?
elizerkim is offline   Reply With Quote
Old 04-28-2011, 11:08 PM   #312
RexyGirl
Member#: 63616
with mods :)
Originally Posted by elizerkim View Post
sigh...
2007 sti.
Are you trying to program a remote?
The security light on the dash comes on on your vehicle when the system is armed.
Disconnect the battery for a few minutes to reset the alarm in case it is in valet mode (of you dont have a remote that works) and try the process again. Remember to use the second process to program your remote....the harder one.
Old 04-29-2011, 07:43 AM   #313
elizerkim
Member#: 222081
2012 Charger SRT8
PitchBlack
Ya that's exactly it the little black thing shaped like a nickel.
Is it supposed to flash? Also yes I'm trying to program the keys. I just can't get past the ignition 10x. I'm getting no beep r anything. My car does the beeps when I open up the cars
Old 04-29-2011, 09:34 AM   #314
xchristhompsonx
Member#: 264602
each time you try it, start the steps over from the beginning. like take your keys out of the ignition, open and close the door...and then do the steps...
Old 04-29-2011, 01:14 PM   #315
elizerkim
Member#: 222081
2012 Charger SRT8
PitchBlack
lol thanks for the info.
I keep failing at every turn...
ok 10 turns... open door close door.
Then i get the tone.
I start the sequences of locks then unlock
after the eighth number i get beeps like non stop beeps
it stops when i try the sequence again for the second input
then it ends with a tone that lasts like 2-3 seconds
but it doesn't do the lock /unlock automatically on the doors.
... lol i over wrote my one working fob so i got nothing!
i did get it to make a tone after an input at one point... but on the second input it did the beeps again...lol im failing pretty hard
Old 04-29-2011, 03:32 PM   #316
elizerkim
Member#: 222081
2012 Charger SRT8
PitchBlack
after the 10 key turns i dont get a beep.. but if i open and close the door it will do the tone to initiate the number input.
now my fob that did work doesn't now =(
Old 04-29-2011, 04:27 PM   #317
xchristhompsonx
Member#: 264602
you don't have to hear a beep, still follow the steps and try to program it..mine didn't beep, but worked.
Old 04-29-2011, 06:19 PM   #318
elizerkim
Member#: 222081
2012 Charger SRT8
PitchBlack
k.
Ya i just can't get it to go lol.
I do the numbers... after the 8th number it does beeps... then ill do it a second time... then same thing again... it doesn't do the locking by itself thing.
Old 04-30-2011, 01:08 AM   #319
xchristhompsonx
Member#: 264602
k.
I don't remember if mine did or not either
Old 05-15-2011, 05:55 PM   #320
ukwrxsti
Member#: 282836
2005 Impreza WRX STi
Bluee
My car didnt come with a remote. can I buy on online somewhere or do I have to go to a subaru dealer?
ukwrxsti is offline   Reply With Quote
Old 05-15-2011, 06:52 PM   #321
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
You don't have to go to the dealer. Mine came with 1 and I bought 2 off ebay and programmed both and they work fine.
Hotsho111 is offline   Reply With Quote
Old 05-16-2011, 12:29 AM   #322
Littlebuff44
Member#: 213264
Default 2000 RS Alarm/Keyless entry keeping me from starting my car.
I removed the keyless entry to my car (2000 rs) so i could start my car. But with the keyless entry stuff in the car and plugged in i cannot get my car to start at all. I have tried getting my remote to work and it does not. However it does work on my buddies subie. Can someone please help me out?
Littlebuff44 is offline   Reply With Quote
Old 05-16-2011, 03:58 PM   #323
mutatron
Member#: 231453
2002 Impreza WRX
Default Fob receiver stopped working during cold weather
A few months ago when the temperature got down into the teens in Dallas, my key fob for my 2002 WRX was having a hard time opening the doors. One day it took a little longer than usual for the door to unlock, and then the next time I tried it, it didn't work at all. Got new batteries for both fobs, red light flashes when I hit the buttons, but no action in the car at all.
All the lock motors still work robustly, so I assume that somehow the keyless entry receiver blew out. How do I test for this, and how much would a replacement part cost?
mutatron is offline   Reply With Quote
Old 05-19-2011, 07:38 AM   #324
ConnSVX
Member#: 282694
92 SVX LSi
Pearl white
Default After market remote starter
Can an aftermarket remote starter be put into a 5 speed? I have a 91 5 speed Sport Sedan......
ConnSVX is offline   Reply With Quote
Old 05-20-2011, 03:17 PM   #325
WrxBogdan
Member#: 281716
2005 Impreza Wrx
Platinum Silver Metallic
Originally Posted by RexyGirl View Post
You need to reset your alarm:
**If you have an older model vehicle, 2001 and under, and have a remote, press unlock on the remote
**If you have an older model vehicle, 2001 and under, there is a reset button for the alarm located on the drivers side, left side of steering colum, down near where the dash trim ends. (Your owners manual has a pretty good picture of where it is located and what it looks like) Press and hold button for a second or two until the alarm is reset.
Why does it say 2001 and under twice? what about 2001 and above?
WrxBogdan is offline   Reply With Quote
Factory Alarm + Keyless entry from 04 FXT Skidd Interior/Dressup/Audio & Security 0 01-22-2009 08:26 PM
Factory alarm/keyless entry install - Anyone want to help?! NickWRX Tri-State Area Forum 3 07-06-2008 09:22 PM
All you need to know about ass hair. WRick Off-Topic 22 01-23-2006 07:22 PM
Factory Alarm / Keyless entry Woody Vancouver Impreza Club Forum -- VIC 3 04-21-2002 11:51 PM
Factory alarm/keyless entry on MY01 Safir Car Audio, Video & Security 1 02-08-2001 01:01 PM
