Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 01-04-2012, 08:27 PM   #376
Rickh_779
Member#: 305882
2012 Impreza 5-door
Metalic gray
Default remote start
Do you know a way to keep the car running when you use the remote start to start the car. When you open the door the car turns off and you have to restart it. Can you by pass this option so you dont have to restart it just put the key in and turn it to "run"?
Rickh_779 is offline   Reply With Quote
Old 01-07-2012, 08:32 PM   #377
abooker13
Member#: 306184
2006 Impreza RS
car: '06 impreza rs, auto transmission, type "a" factory audio
1. i just installed a new pioneer head unit (no new speakers) into my car with the guides on the forum and everything went fine with the install. my problem now is that my remote to the car (factory lock/unlock only) doesn't work - lock, unlock, panic (hold lock) nothing.
i think it's probably something easy but i have checked all my connections and they look solid and i couldn't find anything in the search function. the remote was working fine literally right before i did the install and i've tried the battery and that didn't fix it.
2. also, i think this is unrelated, but since it occurred during installation i wanted to see if this is common or heard of: the interior light above the center console went out completely. i reckon it's just a bulb but i wanted to throw that in here in case someone heard of this happening when wiring the audio up.
anyone have any suggestions or had these happen? thanks for the views and replies in advance.
[edit]: fixed by changing one fuse, 20A
abooker13 is offline   Reply With Quote
Old 01-14-2012, 07:51 PM   #378
Browzer
Member#: 306433
2005 Subaru WRX
I have an 05 wrx, but the dealer gave me the tear drop one.
is this a mistake? can I program this keyless entry to my car? or do I have to get a new one...which Id like to not have to do
Browzer is offline   Reply With Quote
Old 01-14-2012, 09:08 PM   #379
It_wasntt_me
Member#: 300955
2004 WRX
Java Black Pearl
It will work fine
It_wasntt_me is offline   Reply With Quote
Old 01-14-2012, 09:21 PM   #380
Browzer
Member#: 306433
2005 Subaru WRX
Originally Posted by It_wasntt_me View Post
It will work fine
Thanks man! gonna give it a shot now
Old 01-15-2012, 05:30 AM   #381
SamOntario
Member#: 302645
2005 Impreza RS
Red
Works on my 05 2.5RS and I have to program it with 04's method. Actually the tear drops came with the car and I bought 2 more used.
SamOntario is offline   Reply With Quote
Old 01-15-2012, 12:55 PM   #382
theoutbackdream
Member#: 301179
2013 WRX Limited
Question... I got the teardrop key to work on my outback sport, but thing is that it kind sometimes doesn't respond to the clicks.
Like I have to click the button a few times before the car will actually respond to it. Is this normal or should I try programming?
theoutbackdream is offline   Reply With Quote
Old 01-15-2012, 03:39 PM   #383
SamOntario
Member#: 302645
2005 Impreza RS
Red
You may need a new battery.
Old 01-16-2012, 01:30 PM   #384
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
The old style remotes are no longer available and the teardrops are being used as the replacements.
It will work fine
RexyGirl is offline   Reply With Quote
Old 01-16-2012, 01:32 PM   #385
RexyGirl
Member#: 63616
with mods :)
It it works once and awhile, it is a remote issue, probably not a programming issue.
Try replacing the battery first (its a watch battery). Also, make sure there is no interference in the area......(the owners manual describes the types of interference that influence how the remote works). Also, make sure you are close enough to the vehicle.
Old 01-18-2012, 12:57 PM   #386
BugeyedWREX
Member#: 141734
02 BUG-I WAGON
EJ25 Hybrid, 314HP- 280tq
My alarm won't disarm after turning key 3 times. What could be my problem? I've reset the battery, unplugged the turbo timer, and reconnected the green wire to the keyless entry module.
BugeyedWREX is offline   Reply With Quote
Old 01-23-2012, 08:45 PM   #387
RexyGirl
Member#: 63616
with mods :)
Unplug the green connector under the dash.....(your check engine light is probably flashing
It's also possible it's an aftermarket alarm
Old 01-27-2012, 01:17 AM   #388
shawnleechang
Member#: 295786
2005 WRX
I called in the dealership and they asked for $130 for a keyless remote. I decided to buy from ebay for $40. Hopefully, it works because it's definitely much cheaper.
Also, I'm buying an additional keyless remote, does that mean I have to reactivate my current fob right after I program the new one?
shawnleechang is offline   Reply With Quote
Old 01-30-2012, 10:56 AM   #389
BugeyedWREX
Member#: 141734
02 BUG-I WAGON
I have a cel but it's from my maf. It is def the factory alarm, and keyless entry.
Old 02-02-2012, 09:54 PM   #390
Asanti185
Member#: 296249
03 wrx wagon
white
I have an 03 wrx with the factory security system. Recently I had the fuel line recall done by a dealership and after getting it back the lights dont flash when I lock/unlock my car and the security light blinks 2 times, pause, then 2 times untill I turn the key to the on position.
I called the dealer and they said I need to come back so they can hook something up to reset it but their hours are the same as mine so I was wondering if there is a different way to reset it so it works again.
Asanti185 is offline   Reply With Quote
Old 02-03-2012, 11:40 PM   #391
Asanti185
Member#: 296249
03 wrx wagon
white
^Anyone??
Old 02-04-2012, 11:45 AM   #392
theoutbackdream
Member#: 301179
2013 WRX Limited
^Make sure its not in valet mode. Look at first post in this thread about it.
Old 02-04-2012, 02:14 PM   #393
Asanti185
Member#: 296249
03 wrx wagon
white
Thats what I thought it was in at first but did what it said and did not work.
Old 02-17-2012, 05:01 PM   #394
shawnleechang
Member#: 295786
2005 WRX
I'm going to program my sisters Impreza 06. You have two programming methods for the 2006, which one do I use?
I programmed my 2005 WRX easily with the teardrop key fob but i'm not sure which method i'm suppose to be using for the 2006 impreza.
Old 02-18-2012, 05:01 PM   #395
cphillips515
Member#: 310148
I just bought an '05 Impreza 2.5RS wagon, but it didn't come with a key. I bought a teardrop remote on eBay, and I was able to get the unlock button to work, but not the lock button. I thought a teardrop should work on an '05...any suggestions?
cphillips515 is offline   Reply With Quote
Old 02-20-2012, 04:32 AM   #396
juan03
Member#: 309763
thank you! that always bugged the crap out of me
juan03 is offline   Reply With Quote
Old 02-21-2012, 06:16 PM   #397
shawnleechang
Member#: 295786
2005 WRX
I'm trying to do the 2006 impress. After doing the 10 turns, I hear nothing but when I open and close the door, I hear the tone sound for 30 sec. Do I need to hear the chirp/horn after turning 10 times?
Old 02-22-2012, 02:25 PM   #398
Doug02wrx
Member#: 226670
2002 Wrx
I have an 02 wrx and I just want to completely disable the security system and just lock/unlock the car manually. No alarm or anything. This stupid thing now randomly unlocks and doesn't lock with the fob. Any suggestions?
Doug02wrx is offline   Reply With Quote
Old 02-22-2012, 04:19 PM   #399
RexyGirl
Member#: 63616
with mods :)
Put it in valet mode....this way the alarm will not go off when you open the door with the key.
However, your alarm will no longer function.
Something is wrong with the remote....try a new one or replace the battery
Old 02-22-2012, 05:35 PM   #400
Doug02wrx
Member#: 226670
2002 Wrx
You think its the remote? That would cause it to unlock as soon as I hit the lock button (both on the fob and if I try to lock it with the button inside the car)? It also will unlock itself after a certain amount of time usually overnight.
Factory Alarm + Keyless entry from 04 FXT Skidd Interior/Dressup/Audio & Security 0 01-22-2009 08:26 PM
Factory alarm/keyless entry install - Anyone want to help?! NickWRX Tri-State Area Forum 3 07-06-2008 09:22 PM
All you need to know about ass hair. WRick Off-Topic 22 01-23-2006 07:22 PM
Factory Alarm / Keyless entry Woody Vancouver Impreza Club Forum -- VIC 3 04-21-2002 11:51 PM
Factory alarm/keyless entry on MY01 Safir Car Audio, Video & Security 1 02-08-2001 01:01 PM
