Old 05-22-2012, 09:33 PM   #451
Manny830
Member#: 317111
2002 Wrx impreza
Rally blue
Ok so my keys and remote got stolen from my work car,sadly they stole my wrx 2002 keys. There's a guy in town that can get me the remote for ninety bux but that includes programming. Well seeing here I can do it myself,right? He gets the remote through the Internet I think. My question is is there a specific kind of remote the the above procedure follows. The one he was trying to seller is the blue and orange button. Which is the one I had.
Manny830 is offline   Reply With Quote
Old 05-22-2012, 09:54 PM   #452
airkareem
Member#: 293700
My understanding is the 2011-2012 legacy key fob will work with standard 2011 impreza
airkareem is offline   Reply With Quote
Old 05-23-2012, 01:58 PM   #453
ChillyTilly
Member#: 321100
Default Flashing red key
Hi
Not sure if this is relevant as this car is not available in the US but its driving me nuts,
I have a Special Edition WRX STI WR1 (only 500 made) and when I remove the key I have a flashing red key symbol in the middle of the dash. I have tried all the solutions on here but to no avail
My key only has one button on it that opens and locks the doors.
Any help would be gratefully received
regards
ChillyTilly is offline   Reply With Quote
Old 05-28-2012, 07:45 AM   #454
Vinymac
Member#: 318417
Hi,
I just had an 02 WRX built put together for me and there's a few pieces missing. I'm told that one of the pieces that I'm missing is the keyless entry module. Can I buy a used module from a different year and program my 02 remote with it? Is there anything else I would need to have besides the module to get my keyless working?
Vinymac is offline   Reply With Quote
Old 05-28-2012, 10:36 AM   #455
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Originally Posted by ChillyTilly View Post
Hi
regards
Sounds like you might have an aftermarket system, according to the description of the remote, and the factory system was over ridden.
What year is your vehicle?
RexyGirl is offline   Reply With Quote
Old 05-28-2012, 11:53 PM   #456
CSVT_2004
Member#: 182213
1999 Contour SVT
Hi
regards
More than likely part of the anti theft system of the coded key / keysense. Nothing to worry about. Just indicates the key is not inserted for the most part. Lots of other cars for example, some hondas do the same thing.
Here is a Honda example, was having trouble finding a subaru pic.
Originally Posted by Vinymac View Post
Hi,
Viper 211HV, aftermarket, better range... same functionality, and more than likely cheaper...
CSVT_2004 is offline   Reply With Quote
Old 05-29-2012, 12:45 AM   #457
Jablooglius
Member#: 321585
2004 Impreza OBS
Green/Grey
Outback Sport Another Issue
Just a quick hello, this is my first post, glad to be part of a huge Subie club like this one.
I've tried searching all over this thread but I didn't see anyone with the same problem I'm having... I replaced the battery on my fob but when I press any of the 2 buttons the little LED stays on for a good couple of mins. If I press the opposite button it doesn't turn off the LED either. Sometimes when I press a button the LED only flashes with the button press. I didn't start fidgeting with the contacts bc I don't want to waste my time if someone here knows for sure the fob is dead but at the same time, in Montreal at the dealer a fob is $105 and there aren't any second hand ones on any classifieds site.
Jablooglius is offline   Reply With Quote
Old 05-29-2012, 07:37 AM   #458
iiibbb
Member#: 227273
7&11 Imprez$Forester
http://forums.nasioc.com/forums/show...8#post37071178
iiibbb is offline   Reply With Quote
Old 05-29-2012, 10:01 PM   #459
CSVT_2004
Member#: 182213
1999 Contour SVT
Crack it open and make sure none of the solder for the battery contacts have got loose at the solder joints.
Old 06-08-2012, 07:48 AM   #460
jamesalex02
Member#: 322570
Exclamation Replaced ignition barrel, car won't start
Hi all,
First time poster to be gentle.
I recently had my 1999 WRX Impreza broken into, I had to buy a second hand ignition barrel and had it installed, got the key for it aswell. It is now installed, all the dash lights come on when i put the key in but when i go to start it the engine sounds like it will start but it doesn't kick over. Also the battery was replaced because the old one went flat.
Any help would be greatly appreciated, Im stuck as to what i can do?!?!?!?!
jamesalex02 is offline   Reply With Quote
Old 06-10-2012, 01:04 AM   #461
CSVT_2004
Member#: 182213
1999 Contour SVT
Welcome, sounds like an issue other than the ignition cylinder if it's at least cranking and not starting. I'm assuming they tried to steal something from your vehicle, please check your fuses to make sure nothing was shorted out and that your fuel pump shut off was not tripped. At least I'm assuming this vehicle has a fuel pump shut off switch, I could be wrong.
Old 06-23-2012, 02:43 PM   #462
solort
Member#: 261484
I have an 07 2.5i with no remotes. I cannot get past the 10 ignition turns and get one beep. When I make sure it is out of valet mode, I get the chirp, which means it is activated, but no "AL on" or "AL off" when deactivated. it seems to work as far as the alarm, but no odometer display. I disconnected battery for 10 min to see if resetting ECU would help, but no change. Will I need to take it to a stealer and let them program it (quoted $110!!)? Any suggestions are greatly appreciated
solort is offline   Reply With Quote
Old 06-26-2012, 06:38 AM   #463
thehanz123
Member#: 318418
rally blue
soo how do i program the alarm mode and trunk open mode? 02 wrx.. :/
thehanz123 is offline   Reply With Quote
Old 06-26-2012, 05:28 PM   #464
solort
Member#: 261484
Ok. I finally had a Subaru dealer quote of $50-60 to program both. Took car there, and they said they could not get them to program because "remotes can only go to one vehicle". So $190 later, I purchased a new remote and it programmed perfectly! So is this fact or crap, and do I need to call Subaru customer service?
Old 07-09-2012, 02:42 AM   #465
Chuck2012
Member#: 324568
2005 Wrx Sti
Are the Keys waterproof? Not the remote but just the key. I was wondering if I could just leave the remote in the car and take the key with me when I go tubing on the river and if I'd have any problems with it?
Chuck2012 is offline   Reply With Quote
Old 07-09-2012, 11:24 PM   #466
I3eXa
Member#: 30732
2002 Legacy GT, 2004
Impreza OBS
ok so I've got a bit of an issue on my 2004 OBS.
My horn works as normal by hitting it
my exterior lights flash when locking/unlocking (so I'm not in valet mode)
but NO HORN when locking/unlocking
I've tried the unlock, then hold both buttons, and then the lights flash twice, but still no horn. I've also done that step again and the exterior lights then only flash once, but still no horn. I'm at a loss. Btw, I've got the orange/blue 2 button style remote
I3eXa is offline   Reply With Quote
Old 07-10-2012, 02:08 PM   #467
MightyImprezive
Member#: 325714
2006 Impreza
Regal Blue Pearl
Hi. New at this, so bear with me. I have an 06' Impreza. The remote has stopped working . The dealer wants $120 for the fob + labor.....uggh pretty much robbery. So, I did some checking online... Found some fobs (already programmed) for a little under $120. But I also noticed the 06' Outback remote is far less. Is it possible to program the 06' Outback fob for my Impreza? Kind of a long shot, I know. Thanks!
MightyImprezive is offline   Reply With Quote
Old 07-10-2012, 02:53 PM   #468
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
Mighty, I would try checking on ebay. I got 2 teardrop remotes for $20 for an 07 Impreza and programmed them myself.
Hotsho111 is offline   Reply With Quote
Old 07-10-2012, 03:55 PM   #469
RexyGirl
Member#: 63616
with mods :)
Was there ever an after market system on the vehicle? Try disconnecting the battery for a minute to reset it.
Old 07-10-2012, 03:58 PM   #470
RexyGirl
Member#: 63616
with mods :)
I'm trying to figure out how they would be pre-programmed for your vehicle
(FYI: Not possible with a Subaru alarm system)
The Outback remote should work with your vehicle, depending on the aftermarket remote. If it was an OEM Subaru remote it would work.
You get what you pay for with aftermarket remotes and 9 times out of 10 they don't work for your vehicle.....
Old 07-10-2012, 06:11 PM   #471
I3eXa
Member#: 30732
Impreza OBS
No aftermarket alarm that I can tell. All stock. I've tried disconnecting the battery as well with no luck....
Old 07-11-2012, 11:11 PM   #472
MightyImprezive
Member#: 325714
2006 Impreza
Regal Blue Pearl
Rexy, I kinda laughed at the whole preprogrammed thing. Maybe just a white lie to get you to buy it, thinking you won't have to do any work. Ha. Thanks for the input! The outback remote is OEM, so I may try that out. Thanks for the input. Greatly appreciated! Being remoteless is kindof a pain. Oh, and thx Hotsho, I never thought to check Ebay!
Old 07-29-2012, 10:06 PM   #473
wirebiter
Member#: 327574
Default security light
I have a 2002 wrx, and understand that the security light blinks when the system is armed, however mine blinks when the car is on. Is there a problem? I know the fob is broken and only works intermittently, getting a replacement soon.
wirebiter is offline   Reply With Quote
Old 07-29-2012, 10:13 PM   #474
RexyGirl
Member#: 63616
with mods :)
It all depends on 'how' it's blinking. Check the first post in this thread to see if its normal.
Old 07-30-2012, 12:02 AM   #475
wirebiter
Member#: 327574
I have looked at the first post, and it blinks once every three seconds. I have gotten it to go into and out of valet mode the 2 blinks every second, but it goes back to blinking once every 3 seconds after that.
Factory Alarm + Keyless entry from 04 FXT Skidd Interior/Dressup/Audio & Security 0 01-22-2009 08:26 PM
Factory alarm/keyless entry install - Anyone want to help?! NickWRX Tri-State Area Forum 3 07-06-2008 09:22 PM
All you need to know about ass hair. WRick Off-Topic 22 01-23-2006 07:22 PM
Factory Alarm / Keyless entry Woody Vancouver Impreza Club Forum -- VIC 3 04-21-2002 11:51 PM
Factory alarm/keyless entry on MY01 Safir Car Audio, Video & Security 1 02-08-2001 01:01 PM
