Old 08-10-2012, 02:36 AM   #476
haxornator
Member#: 328672
2012 STi(Canadian), factory alarm with factory shock sensor. I'm wondering is there a way to tell if the alarm went off at some point but I didn't hear it? i.e. does the car make any different chirps when I come back to unlock it?
haxornator is offline   Reply With Quote
Old 08-13-2012, 12:08 PM   #477
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Originally Posted by solort View Post
Ok. I finally had a Subaru dealer quote of $50-60 to program both. Took car there, and they said they could not get them to program because "remotes can only go to one vehicle". So $190 later, I purchased a new remote and it programmed perfectly! So is this fact or crap, and do I need to call Subaru customer service?
You can program and reprogram subaru remotes multiple times....including to different vehicles (but not at the same time that I know of).
They fed you hogwash.
It's possible that they were knock-offs and that's why they didn't work, but having been programmed to another vehicle before doesn't matter.
RexyGirl is offline   Reply With Quote
Old 08-13-2012, 12:10 PM   #478
RexyGirl
Member#: 63616
with mods :)
Originally Posted by thehanz123 View Post
soo how do i program the alarm mode and trunk open mode? 02 wrx.. :/
You don't. Not with an OEM remote. It wasn't an option then.
Old 08-16-2012, 10:34 PM   #479
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
Great info in this thread, thanks for posting it. I had a dead keyfob that would was not fixed by swapping in a new battery. The three-key-cycles trick worked like a charm.
scotty305 is offline   Reply With Quote
Old 08-27-2012, 04:39 PM   #480
gaby3123
Member#: 192744
2002 wrx
aspen white
Hi, I have a Wrx wagon 02 with factory alarm. Near the turbo its a little horn but it doesnt sound. A friend told me that its like Sti open close horn. How can i make it sound?
gaby3123 is offline   Reply With Quote
Old 08-27-2012, 11:05 PM   #481
MikeB82
Member#: 230995
05 aspen white WRX
I have an '05 wrx and my fob is acting up. The lock button works, but the unlock button isn't. Would this most likely be an issue with the fob or is it possible it could be an issue with the keyless entry unit itself? Thanks
MikeB82 is online now   Reply With Quote
Old 08-28-2012, 02:05 AM   #482
CSVT_2004
Member#: 182213
1999 Contour SVT
Take fob apart, put new battery in, check contacts. for buttons and battery.
CSVT_2004 is offline   Reply With Quote
Old 08-28-2012, 11:47 AM   #483
RexyGirl
Member#: 63616
with mods :)
More than likely, it's the fob.
If you open the remote and take out the circuit board, you will probably find that the 'tab' for the unlock button has come off. It's pretty small, so ope the remote on something where you will be able to see. it. Seeing that it is only held on by very small weld points, if you drop it too many times, the weld points break.
I have been successful in 'crazy gluing' the tab back on, but you have to properly line up the weld points to the tab with a VERY small amount of glue. There are 4 of them, and if just one is not making a connection, the remote will not work.
Old 08-28-2012, 08:22 PM   #484
MikeB82
Member#: 230995
05 aspen white WRX
I actually tried that before I posted, but forgot to mention it. Thanks for the response though.
The tab is intact. Checked the welds with a magnifying glass and all look fine. I think the button is simply worn out. Thank you for the advice. I never would've thought of that!
I bought a used one on ebay earlier today. Hopefully you're right and it's just the fob. If not, at least I'll have two now
Old 09-04-2012, 09:29 AM   #485
grog71
Member#: 228279
Is there a way to shut off the horn beeps when remote starting the factory remote start in my 12 impreza? looked in the manual but could not find anything.
grog71 is offline   Reply With Quote
Old 09-04-2012, 10:49 PM   #486
Scooby_BugEye
Member#: 291244
02 Subaru WRX
Ok, so i think my car is in valet mode because the lights do not flash now when i unlock/lock it, my remote works because my power locks still work, but now my security light no longer lights up at all, and my starter is disabled, somehow it happened before and i unplugged the security module underneath my center console because i needed the car to start . It was just working just fine but i did sit in the car for a little while installin some stuff.. I plugged it in an it started fine, but now all of a sudden it wont .. I am going to try to take it out of valet mode first but again my security light is not coming on at all .. yet power locks do still work so i figure its not the fuse ? Is there a separate fuse for just the factory alarm. and yes i only have factory alarm . 02 WRX
Scooby_BugEye is offline   Reply With Quote
Old 09-05-2012, 08:06 PM   #487
RexyGirl
Member#: 63616
with mods :)
Try locking and unlocking the car with remote and trying to start it again. If the car was unlocked and the door was opened and closed without starting the car, sometimes it turns on the start interupt. By locking and unlocking the car, it resets it. Or try turning the key in the ignition 3 times fast.
Old 09-08-2012, 04:26 PM   #488
rdowner22
Member#: 329284
02 WRX Sport Wagon
02 bugeye wrx - trying to program teardrop remote. I bought it on ebay, how would I get my transmitter ID?
rdowner22 is offline   Reply With Quote
Old 09-08-2012, 08:58 PM   #489
spoonmectr
Member#: 326770
delete
spoonmectr is offline   Reply With Quote
Old 09-08-2012, 09:50 PM   #490
spoonmectr
Member#: 326770
delete
Old 09-09-2012, 07:58 AM   #491
Scooby_BugEye
Member#: 291244
02 Subaru WRX
Car started just fine 15 later must have done what u said without knowing , but anyway, Can anyone explain why my security light does not come on at all now ? It is definitely plugged in underneath my center console and it is not In passive mode if that would make a difference. Is there a fuse for the security/alarm that I may have blown ? Power locks work perfect so it's not that fuse I'm guessing.
Old 09-09-2012, 02:43 PM   #492
RexyGirl
Member#: 63616
with mods :)
You don't need an ID...just program it using the steps in the first post for your model year.
Hopefully it works, seeing it is from EBAY...not many people have luck with those.
Old 09-09-2012, 03:13 PM   #493
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
does anyone know if adding a $50-100 aftermarket keyless system to a 2012 imp would pose a security risk?
goregasm is offline   Reply With Quote
Old 09-09-2012, 08:13 PM   #494
MikeB82
Member#: 230995
05 aspen white WRX
So, I bought a used teardrop fob off of ebay and went to program it the other day.
I can't get past the step where you turn the key in the ignition 10 times within 15 seconds. I don't hear the horn beep.
I'm definitely completing it in 15 seconds. I used the stopwatch on my cell phone. My car isn't in valet mode. Also, my horn does work.
Any ideas?
Old 09-09-2012, 08:18 PM   #495
rdowner22
Member#: 329284
02 WRX Sport Wagon
Any ideas?
Trust me. You'll get it. It's easier then you think. Open/shut door.
Key in. Turn from off to the farthest position without starting the car and do it 10 times. It doesn't have to be fast or anything.
If you don't get it after 10 turns then start over and by start over I mean open and shut the door again with the keys out
Old 09-09-2012, 08:50 PM   #496
RexyGirl
Member#: 63616
with mods :)
Any ideas?
Try resetting the system by disconnecting the battery.
Old 09-13-2012, 12:16 AM   #497
B-SILVER
Member#: 285412
2004 WRB STi JRTuned
424whp/427wtq E85!
Recently I noticed that when I lock/unlock with the key fob the lights do not flash. It does lock and unlock and the horn sounds when locking but no flashing light when I press the buttons. Any ideas?
B-SILVER is offline   Reply With Quote
Old 09-13-2012, 01:34 AM   #498
B-SILVER
Member#: 285412
424whp/427wtq E85!
nevermind its on the first page
Old 10-07-2012, 06:09 PM   #499
Jason06iwagon
Member#: 330582
2006 Impreza 2.5I
Default Not even beginning to work...
Hi.
I'm extremely frustrated. I'm starting the process, turning the key from LOCK to ON 10 times very quickly, and not even so much as hearing an electronic tone...
Maybe I'm in valet mode? Do i need to be out of valet mode to program remotes?
Jason06iwagon is offline   Reply With Quote
Old 10-17-2012, 06:51 PM   #500
gsmith304
Member#: 302159
2003 WRX
Sonic Yellow
Originally Posted by Jason06iwagon
Hi.
Yes disconnect the battery for a minute or so and try again. That's what I had to do to program mine. Mine was in valet and took it out and now it's back in valet again? Even after programming my new fob? Lolwut
gsmith304 is offline   Reply With Quote
Factory Alarm + Keyless entry from 04 FXT Skidd Interior/Dressup/Audio & Security 0 01-22-2009 08:26 PM
Factory alarm/keyless entry install - Anyone want to help?! NickWRX Tri-State Area Forum 3 07-06-2008 09:22 PM
All you need to know about ass hair. WRick Off-Topic 22 01-23-2006 07:22 PM
Factory Alarm / Keyless entry Woody Vancouver Impreza Club Forum -- VIC 3 04-21-2002 11:51 PM
Factory alarm/keyless entry on MY01 Safir Car Audio, Video & Security 1 02-08-2001 01:01 PM
